06-23-2022, 10:37 | #1 (permalink) |
Banned Join Date: Nov 2019 Location: Myawaddy2
Member: 2937752 Status: Offline Sonork: 100.650600 Thanks Meter: 25 | Load NVDATA file error Redmi 9A https://ibb.co/PZM11wZ https://ibb.co/YW4VTJV |
06-23-2022, 11:29 | #3 (permalink) |
Member: 2937752 Status: Offline Sonork: 100.650600 Thanks Meter: 25 | Selected model: Xiaomi M2006C3LC (Redmi 9A) Operation: Repair Software version: 3.6 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM10 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM10 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x8B656186, 0x33023644, 0x0D10C0B7, 0x03E2B17A Get Chip ID... [MT6765] Get SOC ID... [63811B90889871CA10705325DE0D95B65D368D14943DB72248 14E141ED9DC3BC] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100434A54443452046C684FA4A78B Load EMI config from database [DB VER: 206 DB DATE: 05-25-2022] OK [1] Trying EMI [46F6F1CA, 22BA5289, 92392267, EB371E79, C3498624, 7770139F, C0129602, E6CB89A3, CB03FF37, 11593C4B, 33A1CDBE, 7805E65B, DB7E1DC4, E055C125, 6526FBD5] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100434A54443452046C684FA4A78B EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : M2006C3LC Product Name : dandelion Product Device : dandelion Product Board : dandelion Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Fri May 27 20:29:53 CST 2022 Display ID : RP1A.200720.011 Security Patch : 2022-05-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : V12.5.12.0.RCDCNXM Read partition "nvdata"... OK Read partition "nvram"... OK Load NVDATA file error! |
06-23-2022, 11:46 | #4 (permalink) |
Member: 2937752 Status: Offline Sonork: 100.650600 Thanks Meter: 25 | After Downgrade To 12.0 but same error sir... Selected model: Xiaomi M2006C3LC (Redmi 9A) Operation: Repair Software version: 3.6 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM10 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM10 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x8B656186, 0x33023644, 0x0D10C0B7, 0x03E2B17A Get Chip ID... [MT6765] Get SOC ID... [63811B90889871CA10705325DE0D95B65D368D14943DB72248 14E141ED9DC3BC] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100434A54443452046C684FA4A78B Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100434A54443452046C684FA4A78B EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : M2006C3LG Product Name : dandelion_global Product Device : dandelion Product Board : dandelion Board Platform : MT6765 Build ID : QP1A.190711.020 Build Date : Tue Feb 23 20:49:04 CST 2021 Display ID : QP1A.190711.020 Security Patch : 2021-02-01 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : V12.0.11.0.QCDMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Load NVDATA file error! |
06-23-2022, 14:54 | #9 (permalink) |
Member: 2937752 Status: Offline Sonork: 100.650600 Thanks Meter: 25 | Selected model: Xiaomi M2006C3LG (Redmi 9A) Operation: Patch CERT Software version: 3.6 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM20 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM20 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x64E2E342, 0x2340F968, 0x74E48CB2, 0x554AC51C Get Chip ID... [MT6765] Get SOC ID... [90083E9322F3019252A756C8447E5E22CA7D599DED4555D9A6 F036629ECE688F] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100434A5444345204C16F474BA7EF Load EMI config from database [DB VER: 206 DB DATE: 05-25-2022] OK [1] Trying EMI [46F6F1CA, 22BA5289, 92392267, EB371E79, C3498624, 7770139F, C0129602, E6CB89A3, CB03FF37, 11593C4B, 33A1CDBE, 7805E65B, DB7E1DC4, E055C125, 6526FBD5] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100434A5444345204C16F474BA7EF EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : M2006C3LG Product Name : dandelion_global Product Device : dandelion Product Board : dandelion Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Thu Apr 21 19:42:58 CST 2022 Display ID : RP1A.200720.011 Security Patch : 2022-04-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : V12.5.4.0.RCDMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Load partiton for patching... OK Check boot patch possiblity... POSSIBLE WITH BOOT UNLOCK Patching CERT... error(EER_SI_1) |
