Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 09-06-2022, 09:51   #1 (permalink)
Member: 2993836
Thanks Meter: 12
MI Play Lotus after flash no fastboot no mtk connection help [Answered]
problem is: hang on startup logo
wipe data: (Failed)
There is a risk of data loss.
This procedure will erase all User Data
Make sure that you have a backup created. Continue? YES
Host Power Off... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Connect phone to BOX in BROM mode
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Send start cmd... OK
Get HW code from device... 0766
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6765]
Get sec config... OK [000000E7]
Active sec flags: [SBC SLA DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Connect Type-C to HUB... OK
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0]
Device found at COM5 [BROM]
Open port... OK
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID =  0x99BF836B, 0x8D1A4203, 0x6B181424, 0x3A311A7C
Get Chip ID... [MT6765]
Get SOC ID... [F6D9EFF751177A232FFA82DB649665D199501C30394AB7C8B202ACBFADC6C5FC]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [7]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x90014A68433861503E0360711E3936F7
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
   EMMC_ID   : 0x90014A68433861503E0360711E3936F7
   EMMC_BOOT1: 0x0000400000 (4.00Mb)
   EMMC_BOOT2: 0x0000400000 (4.00Mb)
   EMMC_RPMB : 0x0001000000 (16.00Mb)
   EMMC_USER : 0x0E8F800000 (58.24Gb)
RAM INFO:
   INT_SRAM: 0x000003A000 (232.00Kb)
   EXT_RAM : 0x0100000000 (4.00Gb)
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Check A/B state... OK
Read product info... OK
Product Brand        : xiaomi
Product Manufacturer : Xiaomi
Product Model        : MI PLAY
Product Name         : lotus
Product Device       : lotus
Board Platform       : MT6765
Build ID             : O11019
Build Date           : Fri Jan  8 21:43:26 CST 2021
Display ID           : ZAL1722-lotus-build-202101082143
Security Patch       : 2021-01-01
Version SDK          : 27
Version Release      : 8.1.0
Version Codename     : REL
Firmware Version     : V11.0.10.0.OFIMIXM
Format "userdata" partition... error(7) error(7)
flashed upgrade: (format error)
Parse scatter file... OK
Load Rom Images... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [7]
Load EMI config from preloader... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Get scatter info... OK
Build ID             : O11019
Version SDK          : 27
Prepare list for upgrade... OK
Check upgrade list... OK
Prepare format list... OK
Prepare final partition list... OK
Read partition "preloader"... OK
Read partition "nvcfg"... OK
Read partition "protect1"... OK
Read partition "protect2"... OK
Read partition "persist"... OK
Read partition "proinfo"... OK
Read partition "nvram"... OK
Verify checksum... OK
Format EMMC_USER partition( 0x00008000..0x03687FFF )... OK
Format EMMC_USER partition( 0x05688000..0x0B687FFF )... OK
Format EMMC_USER partition( 0x0C800000..0x0CFFFFFF )... OK
Format EMMC_USER partition( 0x10000000..0x101FFFFF )... OK
Format EMMC_USER partition( 0x10500000..0x18E7FFFF )... OK
Format EMMC_USER partition( 0x1CE80000..0xE8BCFBDFF )... error(7)
flashed Download:
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [7]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Build ID             : O11019
Version SDK          : 27
Verify scatter file... OK
Do NAND BMT remark... OK
Setup download info... OK
Get partition table catagory... OK [GPT]
Read mirror partition table... OK
Check partition table layout changed... OK
Read major partition table... OK
Check major partition table layout changed... OK
Download "preloader"... OK
Download "recovery"... OK
Download "efuse"... OK
Download "md1img"... OK
Download "spmfw"... OK
Download "scp1"... OK
Download "scp2"... OK
Download "sspm_1"... OK
Download "sspm_2"... OK
Download "lk"... OK
Download "lk2"... OK
Download "boot"... OK
Download "logo"... OK
Download "odmdtbo"... OK
Download "tee1"... OK
Download "tee2"... OK
Download "vendor"... OK
Download "cust"... OK
Download "system"... OK
Download "vbmeta"... OK
Download "cache"... OK
Download "userdata"... error(2)
Flashing done!
after flashed download there is not mtk usb connect off mode, there is no fastboot mode going when prompt. mobile is still logo hang at startup.
solution??
Old 09-06-2022, 11:39   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,033
Hello. Its memory fault. Replace memory.
The Following User Says Thank You to Z3X For This Useful Post:
Old 09-06-2022, 19:00   #3 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Please Add EMMC Health Check Option
Page generated in 0.15509 seconds with 8 queries
