Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #3 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2010
Member: 1462894 Status: Offline Sonork: 100.1609879 Thanks Meter: 40 | here is log file elected model: OPPO CPH2271 (Oppo A16s) Operation: Write OFP Software version: 3.6 Extract scatter file... OK Read super info... OK Parse scatter file... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM25 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM25 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x0251B8F8, 0x0B3041AB, 0x4C9413E1, 0x604264E0 Get Chip ID... [MT6765] Get SOC ID... [5EADC77B07DE6277F7B2D846766F50D99863A4F3FBA2AE0F4B 462C703683A641] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E47314A395238101453AB4178FF Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E47314A395238101453AB4178FF EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Check partition table layout changed... OK Read major partition table... OK Check major partition table layout changed... OK Download "preloader"... OK Download "recovery"... OK Download "opporeserve2"... OK Download "vbmeta_system"... OK Download "vbmeta_vendor"... OK Download "cdt_engineering"... OK Download "md1img"... OK Download "spmfw"... OK Download "scp1"... OK Download "scp2"... OK Download "sspm_1"... OK Download "sspm_2"... OK Download "gz1"... OK Download "gz2"... OK Download "lk"... OK Download "lk2"... OK Download "boot"... OK Download "logo"... OK Download "dtbo"... OK Download "tee1"... OK Download "tee2"... OK Download "super" part 1... OK Download "super" part 2... OK Download "super" part 3... OK Download "vbmeta"... OK Download "cache"... OK Download "userdata"... OK Flashing done! Selected model: OPPO CPH2271 (Oppo A16s) Operation: Write OFP Software version: 3.6 try only download update download and formate but not working Last edited by pakistan786; 06-23-2022 at 15:23. Reason: need |
![]() | #4 (permalink) | |
Member: 1462894 Status: Offline Sonork: 100.1609879 Thanks Meter: 40 | here is another log Quote:
Read super info... OK Parse scatter file... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM25 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM25 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x0251B8F8, 0x0B3041AB, 0x4C9413E1, 0x604264E0 Get Chip ID... [MT6765] Get SOC ID... [5EADC77B07DE6277F7B2D846766F50D99863A4F3FBA2AE0F4B 462C703683A641] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E47314A395238101453AB4178FF Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E47314A395238101453AB4178FF EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Prepare list for upgrade... OK Check upgrade list... OK Prepare format list... OK Prepare final partition list... OK Read partition "preloader"... OK Read partition "opporeserve1"... OK Read partition "opporeserve2"... OK Read partition "opporeserve3"... OK Read partition "oppo_custom"... OK Read partition "nvcfg"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "persist"... OK Read partition "proinfo"... OK Read partition "ocdt"... OK Read partition "opporeserve5"... OK Read partition "opporeserve6"... OK Read partition "nvram"... OK Verify checksum... OK Format EMMC_USER partition( 0x00008000..0x06387FFF )... OK Format EMMC_USER partition( 0x12C88000..0x15187FFF )... OK Format EMMC_USER partition( 0x17188000..0x1E821FFF )... OK Format EMMC_USER partition( 0x20000000..0x207FFFFF )... OK Format EMMC_USER partition( 0x23800000..0x239FFFFF )... OK Format EMMC_USER partition( 0x2A500000..0x335FFFFF )... OK Format EMMC_USER partition( 0x37600000..0xE8BCF7FFF )... OK Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Check partition table layout changed... OK Read major partition table... OK Check major partition table layout changed... OK Download "preloader"... OK Download "recovery"... OK Download "opporeserve2"... OK Download "vbmeta_system"... OK Download "vbmeta_vendor"... OK Download "cdt_engineering"... OK Download "md1img"... OK Download "spmfw"... OK Download "scp1"... OK Download "scp2"... OK Download "sspm_1"... OK Download "sspm_2"... OK Download "gz1"... OK Download "gz2"... OK Download "lk"... OK Download "lk2"... OK Download "boot"... OK Download "logo"... OK Download "dtbo"... OK Download "tee1"... OK Download "tee2"... OK Download "super" part 1... OK Download "super" part 2... OK Download "super" part 3... OK Download "vbmeta"... OK Download "cache"... OK Download "userdata"... OK Write file "opporeserve1.bin"... OK Write file "opporeserve2.bin"... OK Write file "opporeserve3.bin"... OK Write file "oppo_custom.bin"... OK Write file "nvcfg.bin"... OK Write file "protect1.bin"... OK Write file "protect2.bin"... OK Write file "persist.bin"... OK Write file "proinfo.bin"... OK Write file "ocdt.bin"... OK Write file "opporeserve5.bin"... OK Write file "opporeserve6.bin"... OK Write file "nvram.bin"... OK Flashing done! Selected model: OPPO CPH2271 (Oppo A16s) Operation: Write OFP Software version: 3.6 | |
