GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Pandora’s box (https://forum.gsmhosting.com/vbb/f1110/)
-   -   oppo a54 cph 2239 after repair imei don but imei show nill [Solved] (https://forum.gsmhosting.com/vbb/f1110/oppo-a54-cph-2239-after-repair-imei-don-but-imei-show-nill-solved-3022315/)
niaz muhammad 06-18-2022 06:04
Selected model: OPPO CPH2239 (Oppo A54)
Operation: Repair
Software version: 3.6
Host Power Off... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Connect phone to BOX in BROM mode
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Send start cmd... OK
Get HW code from device... 0766
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6765]
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Connect Type-C to HUB... OK
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0]
Device found at COM35 [BROM]
Open port... OK
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID =  0x1824AFD9, 0xB7C99BF0, 0x6C15811E, 0x4656C3EE
Get Chip ID... [MT6765]
Get SOC ID... [2868EA615A4B25C286855DEDC8620D3E6B017210314C344EAF014B0FB2C41F82]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [7]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x90014A68433861503E030023978A48BF
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
  EMMC_ID  : 0x90014A68433861503E030023978A48BF
  EMMC_BOOT1: 0x0000400000 (4.00Mb)
  EMMC_BOOT2: 0x0000400000 (4.00Mb)
  EMMC_RPMB : 0x0001000000 (16.00Mb)
  EMMC_USER : 0x0E8F800000 (58.24Gb)
RAM INFO:
  INT_SRAM: 0x000003A000 (232.00Kb)
  EXT_RAM : 0x0100000000 (4.00Gb)
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Check A/B state... OK
Read product info... OK
Product Brand        : alps
Product Manufacturer : alps
Product Model        : oplus_mssi_64_cn
Product Name        : sys_oplus_mssi_64_cn
Product Device      : oplus_mssi_64_cn
Product Board        : oppo6765
Board Platform      : MT6765
Build ID            : RP1A.200720.011
Build Date          : Tue Feb  8 15:34:11 CST 2022
Display ID          : RP1A.200720.011 release-keys
Security Patch      : 2022-02-05
Version SDK          : 30
Version Release      : 11
Version Codename    : REL
Firmware Version    : 1644304518397
Read partition "nvdata"... OK
Read partition "nvram"... OK
Read NVDATA files... OK
Read NVRAM files... OK
Repairing IMEI...
  IMEI 1:  357515891502557
  IMEI 2:  357515891502565
Write IMEI [NVDATA]... OK
Load partiton for patching... OK
Patching CERT... already patched, skip
Unlock bootloader... OK
Write IMEI [NVRAM]... OK
Write partition "nvdata"... OK
Repair Security done!
If your phone after repair keeps rebooting - use wipe data option.
Z3X 06-18-2022 08:07
Hello. Read partitions dump (except userdata and cache) and upload it. We will recheck issue.
hardnsoft67 06-19-2022 07:08
Click Read IMEI Button
It will tell you whether nvdata partition is good or damaged
In your case it is damaged
restore nvdata from good backup.Then retry your problem will be solved
niaz muhammad 06-19-2022 12:36
read nv ok but still show imei nill
Operation: Read IMEI Info
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [7]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Version SDK          : 30
Read IMEI... OK
IMEI 1: 357515xxxxxxxxx
IMEI 2: 35751xxxxxxxxxx
Reading IMEI done!
niaz muhammad 06-21-2022 01:40
thanks team my problime slove after full flash again repair don
Page generated in 0.13276 seconds with 6 queries
