Oppo A73 5G Cph2161 Imei Repair Failed. Solution? [Answered] i tried all version off pandora. 2.12/ 3.0/3.2 but always repair failed. also downgrade the security. but again failed here is log Get device info... OK UFS CID (FW VER): KM8V8001JM-B813 (1900) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V8001JM-B813 UFS_FWVER : 1900 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6853 Board Platform : MT6853 Build ID : RP1A.200720.011 Build Date : Fri Jul 23 01:31:17 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-07-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1756300455425 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 359276450177939 IMEI 2: 359276450177921 Write IMEI [NVDATA]... OK Load partiton for patching... error(ERR_LD) |
Hello. Latest version 3.3. Try and post result. |
Operation: Repair Software version: 3.3 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM17 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB3031EA5, 0x8C8A62EB, 0xB5984FC6, 0x0718F8CD Get Chip ID... [MT6853] Get SOC ID... [D153D76302F31CDED349DA325A4FA22D7B0B66583ED1461E6A B06DAE8E1A3AFC] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [15] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM8V8001JM-B813 (1900) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V8001JM-B813 UFS_FWVER : 1900 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Board : oppo6853 Board Platform : MT6853 Build ID : QP1A.190711.020 Build Date : Tue Sep 29 13:52:29 CST 2020 Security Patch : 2020-09-05 Version SDK : 29 Version Release : 10 Version Codename : REL Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 863768035896891 IMEI 2: 863768033900687 Write IMEI [NVDATA]... OK Load partiton for patching... error(ERR_LD) |
Read partitions dump (except userdata and cache) and upload it. We will try to fix this. |
Thanks, we will recheck algo for this phone |
