05-11-2022, 08:20 | #1 (permalink) |
Major Poster Join Date: Apr 2020 Location: iran
Member: 2954982 Status: Offline Thanks Meter: 4 | oppo a93 repair imei failed [Answered] Operation: Repair Software version: 3.4 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xC15AB79F, 0x2120D438, 0xA36D204B, 0xC6FEE531 Get Chip ID... [MT6779] Get SOC ID... [0194E2697EF915858BEE37CB62012B3EFA222658EF3A7D48D3 FC816F2AB3726D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM8V7001JM-B810 (1200) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V7001JM-B810 UFS_FWVER : 1200 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Sat Mar 5 00:31:41 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1646411009679 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 357757104861921 IMEI 2: 357757106861929 Write IMEI [NVDATA]... OK Load partiton for patching... patch impossible |
