Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 02-20-2022, 09:17   #16 (permalink)
Member: 1834763
Thanks Meter: 2
Originally Posted by Z3X View Post
Hello. Dump partitions (without userdata and cache) and upload them. We will fix issue.
https://drive.google.com/file/d/1o0h...ew?usp=sharing
The Following User Says Thank You to bartarbartar For This Useful Post:
Old 02-21-2022, 14:34   #17 (permalink)
Member: 2682141
Thanks Meter: 48
Originally Posted by Rezashz View Post
hi
android 11 ?
if posible downgrade to 10
repair done on 10
What is the model of your oppo phone?
what operation are you doing on this phone?
When your operation is not done on 11.
then you can try downgrade to 10 and repeat operation.
if not solve.
upload dump without user data and cache.
Old 02-22-2022, 07:02   #18 (permalink)
Member: 1834763
Thanks Meter: 2
if not solve.
model cph 2161
You have an Android 10 download link?
Old 02-22-2022, 08:22   #19 (permalink)
Member: 2682141
Thanks Meter: 48
Originally Posted by bartarbartar View Post
model cph 2161
Search google for appropriate Flash file.
Check your handset Software version.
if you cant find andriod 10
downgrade with the lower version of Andriod 11 by which you lower your handset security patch.
and then try with pandora.
Old 02-22-2022, 10:05   #20 (permalink)
Member: 1834763
Thanks Meter: 2
Do you have a telegram or WhatsApp idea to contact you?
Old 02-23-2022, 13:24   #21 (permalink)
Member: 1834763
Thanks Meter: 2
OPPO CPH2161 (Oppo A73 5G) Imei Repair Failed
Selected model: OPPO CPH2161 (Oppo A73 5G)
Operation: Repair
Software version: 2.12
Host Power Off... OK
Switch virtual port to NONE... OK
Connect Type-C to HUB... OK
Host Power On... OK
Connect phone to BOX in BROM/PRELOADER Mode
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0]
Device found at COM68 [BROM]
Open port... OK
Send start cmd... OK
Get HW code from device... 0996
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6853]
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Force switch to BROM... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0xB3031EA5, 0x8C8A62EB, 0xB5984FC6, 0x0718F8CD
Get Chip ID... [MT6853]
Get SOC ID... [D153D76302F31CDED349DA325A4FA22D7B0B66583ED1461E6A B06DAE8E1A3AFC]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [15]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
UFS CID (FW VER): KM8V8001JM-B813 (1900)
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_CID : KM8V8001JM-B813
UFS_FWVER : 1900
BLOCK_SIZE: 0x0000001000 (4.00Kb)
UFS_LU0 : 0x0000400000 (4.00Mb)
UFS_LU1 : 0x0000400000 (4.00Mb)
UFS_LU2 : 0x1DCB000000 (119.17Gb)
RAM INFO:
INT_SRAM: 0x0000070000 (448.00Kb)
EXT_RAM : 0x0100000000 (4.00Gb)
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Check A/B state... OK
Read product info... OK
Product Brand : alps
Product Manufacturer : alps
Product Model : oplus_mssi_64_cn
Product Name : sys_oplus_mssi_64_cn
Product Device : oplus_mssi_64_cn
Product Board : oppo6853
Board Platform : MT6853
Build ID : RP1A.200720.011
Build Date : Mon Aug 23 21:11:09 CST 2021
Display ID : RP1A.200720.011 release-keys
Security Patch : 2021-09-05
Version SDK : 30
Version Release : 11
Version Codename : REL
Firmware Version : 1629723568022
Read partition "nvdata"... OK
Read partition "nvram"... OK
Read NVDATA files... OK
Read NVRAM files... OK
Repairing IMEI...
IMEI 1: 863768033
IMEI 2: 863768033
Write IMEI [NVDATA]... OK
Load partiton for patching... error(ERR_LD)
Old 04-01-2022, 09:24   #22 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,056
Hello. Try with 3.3 version and post result.
Old 04-02-2022, 15:16   #23 (permalink)
Member: 1834763
Thanks Meter: 2
Operation: Repair
Software version: 3.3
Host Power On... OK
Connect phone to BOX in BROM mode
Device found at COM17 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_FWVER : 1900
RAM INFO:
Build ID : QP1A.190711.020
Build Date : Tue Sep 29 13:52:29 CST 2020
Security Patch : 2020-09-05
Version SDK : 29
Version Release : 10
Repairing IMEI...
IMEI 1: 863768035
IMEI 2: 863768033
Old 04-20-2022, 18:00   #24 (permalink)
Member: 1834763
Thanks Meter: 2
Operation: Repair
Software version: 3.4
Host Power On... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0]
Device found at COM3 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_FWVER : 1900
RAM INFO:
Version SDK : 29
Repairing IMEI...
IMEI 1: 355862051232944
IMEI 2: 355862051232951
Load partiton for patching... patch impossible
Old 04-20-2022, 18:30   #25 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,056
Operation: Repair
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_FWVER : 1900
RAM INFO:
Version SDK : 29
Repairing IMEI...
Flash newer 2021 firmware and post result.
Old 04-21-2022, 07:06   #26 (permalink)
Member: 1834763
Thanks Meter: 2
This phone was originally Android 11, I flashed it to Android 10(downgrade), but it didn't work imei repair
Old 04-21-2022, 07:36   #27 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,056
Read my answer carefully.
Old 04-23-2022, 09:15   #28 (permalink)
Member: 1834763
Thanks Meter: 2
You can put the link to the file and I will download it
Old 04-29-2022, 17:18   #29 (permalink)
Member: 1834763
Thanks Meter: 2
Operation: Repair
Host Power On... OK
Device found at COM11 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_FWVER : 1900
RAM INFO:
Read product info... error(6)
Repairing IMEI...
IMEI 1: 3558620512
IMEI 2: 35586205123
flash new version 2021
Old 04-29-2022, 19:25   #30 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,056
Please read info and post log.
Page generated in 0.31290 seconds with 10 queries
