02-20-2022, 09:17 | #16 (permalink) | |
Major Poster Join Date: Nov 2012
Member: 1834763 Status: Offline Thanks Meter: 2 | Quote:
The Following User Says Thank You to bartarbartar For This Useful Post: |
02-21-2022, 14:34 | #17 (permalink) |
Freak Poster Join Date: Feb 2017
Member: 2682141 Status: Offline Thanks Meter: 48 | What is the model of your oppo phone? what operation are you doing on this phone? When your operation is not done on 11. then you can try downgrade to 10 and repeat operation. if not solve. upload dump without user data and cache. |
02-22-2022, 07:02 | #18 (permalink) | |
You have an Android 10 download link? | |
02-22-2022, 08:22 | #19 (permalink) |
Member: 2682141 Status: Offline Thanks Meter: 48 | Search google for appropriate Flash file. Check your handset Software version. if you cant find andriod 10 downgrade with the lower version of Andriod 11 by which you lower your handset security patch. and then try with pandora. |
02-23-2022, 13:24 | #21 (permalink) |
Member: 1834763 Status: Offline Thanks Meter: 2 | OPPO CPH2161 (Oppo A73 5G) Imei Repair Failed Selected model: OPPO CPH2161 (Oppo A73 5G) Operation: Repair Software version: 2.12 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM68 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM68 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB3031EA5, 0x8C8A62EB, 0xB5984FC6, 0x0718F8CD Get Chip ID... [MT6853] Get SOC ID... [D153D76302F31CDED349DA325A4FA22D7B0B66583ED1461E6A B06DAE8E1A3AFC] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [15] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM8V8001JM-B813 (1900) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V8001JM-B813 UFS_FWVER : 1900 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6853 Board Platform : MT6853 Build ID : RP1A.200720.011 Build Date : Mon Aug 23 21:11:09 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-09-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1629723568022 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 863768033 IMEI 2: 863768033 Write IMEI [NVDATA]... OK Load partiton for patching... error(ERR_LD) |
04-02-2022, 15:16 | #23 (permalink) |
Member: 1834763 Status: Offline Thanks Meter: 2 | Selected model: OPPO CPH2161 (Oppo A73 5G) Operation: Repair Software version: 3.3 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM17 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB3031EA5, 0x8C8A62EB, 0xB5984FC6, 0x0718F8CD Get Chip ID... [MT6853] Get SOC ID... [D153D76302F31CDED349DA325A4FA22D7B0B66583ED1461E6A B06DAE8E1A3AFC] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [15] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM8V8001JM-B813 (1900) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V8001JM-B813 UFS_FWVER : 1900 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Board : oppo6853 Board Platform : MT6853 Build ID : QP1A.190711.020 Build Date : Tue Sep 29 13:52:29 CST 2020 Security Patch : 2020-09-05 Version SDK : 29 Version Release : 10 Version Codename : REL Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 863768035 IMEI 2: 863768033 Write IMEI [NVDATA]... OK Load partiton for patching... error(ERR_LD) |
04-20-2022, 18:00 | #24 (permalink) |
Member: 1834763 Status: Offline Thanks Meter: 2 | Selected model: OPPO CPH2161 (Oppo A73 5G) Operation: Repair Software version: 3.4 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB3031EA5, 0x8C8A62EB, 0xB5984FC6, 0x0718F8CD Get Chip ID... [MT6853] Get SOC ID... [D153D76302F31CDED349DA325A4FA22D7B0B66583ED1461E6A B06DAE8E1A3AFC] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [15] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM8V8001JM-B813 (1900) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V8001JM-B813 UFS_FWVER : 1900 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Board : oppo6853 Board Platform : MT6853 Build ID : QP1A.190711.020 Build Date : Tue Sep 29 13:52:29 CST 2020 Security Patch : 2020-09-05 Version SDK : 29 Version Release : 10 Version Codename : REL Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 355862051232944 IMEI 2: 355862051232951 Write IMEI [NVDATA]... OK Load partiton for patching... patch impossible |
04-20-2022, 18:30 | #25 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,061 | Quote:
04-29-2022, 17:18 | #29 (permalink) |
Member: 1834763 Status: Offline Thanks Meter: 2 | Selected model: OPPO CPH2161 (Oppo A73 5G) Operation: Repair Software version: 3.4 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM11 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM11 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB3031EA5, 0x8C8A62EB, 0xB5984FC6, 0x0718F8CD Get Chip ID... [MT6853] Get SOC ID... [D153D76302F31CDED349DA325A4FA22D7B0B66583ED1461E6A B06DAE8E1A3AFC] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [15] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM8V8001JM-B813 (1900) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V8001JM-B813 UFS_FWVER : 1900 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... error(6) Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 3558620512 IMEI 2: 35586205123 Write IMEI [NVDATA]... OK Load partiton for patching... patch impossible flash new version 2021 |
