01-01-2022, 07:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | OPPO CPH2185 (Oppo A15) After Format set dead. Operation: Format Flash Software version: 2.10 This procedure will erase all flash and can damage your device. Make sure that you have a backup created. Continue? YES Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x67F63AE2, 0xB703A456, 0xB9A18468, 0x13921F22 Get Chip ID... [MT6765] Get SOC ID... [12876488A7F8C3B21D91025116D50EF4B320A3998792C73EAD F482D483FC4F42] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445836384D42092021CE8D9747 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100445836384D42092021CE8D9747 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Board : oppo6765 Board Platform : MT6765 Build ID : QP1A.190711.020 Build Date : Thu Nov 26 00:45:15 CST 2020 Display ID : QP1A.190711.020 release-keys Security Patch : 2020-12-05 Version SDK : 29 Version Release : 10 Version Codename : REL Read partition "preloader"... OK Read partition "pgpt"... OK Read partition "opporeserve1"... OK Read partition "opporeserve2"... OK Read partition "opporeserve3"... OK Read partition "oppo_custom"... OK Read partition "nvcfg"... OK Read partition "nvdata"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "persist"... OK Read partition "proinfo"... OK Read partition "nvram"... OK Read partition "ocdt"... OK Read partition "otp"... OK Read partition "flashinfo"... OK Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/OPPO_CPH2185%20(Oppo%20A15)/FORMAT_BACKUP_(2022-1-1_12-38-9)/"directory Create autoformat settings... OK Format EMMC_BOOT_1 partition( 0x00000000..0x003FFFFF )... OK Format EMMC_BOOT_2 partition( 0x00000000..0x003FFFFF )... OK Format EMMC_USER partition( 0x00000000..0x747BFFFFF )... OK Format done! |
01-01-2022, 08:45 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
restore back up it will com on | |
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
01-01-2022, 09:54 | #4 (permalink) |
Freak Poster Join Date: Aug 2021 Location: Pakistan
Member: 2993836 Status: Offline Thanks Meter: 12 | you would not format it, if want to unlock pattern, password, pin then only wipe data. try flash .ofp file hope your device will come back to life. |
The Following User Says Thank You to (:: GSMCity ::) For This Useful Post: |
01-01-2022, 10:00 | #5 (permalink) | |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Quote:
I have tryed to ripier but phone not turn on .only only vibrating | |
