11-11-2022, 15:03 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Nokia 2.4 [TA-1270] Downgrade From 12 To 11 & IMEI Repair Done [Done] Operation Repair Software version 3.10 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VIDPID...0E8D0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER CA00, SW VER 0000, HW SUB CODE 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags [SBC SLA DAA] Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM30 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER CA00, SW VER 0000, HW SUB CODE 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xE6E9C036, 0x87085BE9, 0x2693523E, 0x4622CCA1 Get Chip ID... [MT6765] Get SOC ID... [A8D31CE24B0A3F324F433EC46A19138898CDD9D9B1E30D40DC 15467C9AC7A14B] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID 0x880103534C443332475918AAF523C663 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO EMMC_ID 0x880103534C443332475918AAF523C663 EMMC_BOOT1 0x0000400000 (4.00Mb) EMMC_BOOT2 0x0000400000 (4.00Mb) EMMC_RPMB 0x0000400000 (4.00Mb) EMMC_USER 0x073A000000 (28.91Gb) RAM INFO INT_SRAM 0x000003A000 (232.00Kb) EXT_RAM 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check AB state... OK [A] Read product info... OK Product Brand Nokia Product Manufacturer HMD Global Product Model Nokia 2.4 Product Name Wolverine_00WW Product Device WVR_sprout Product Board MT6762 Board Platform MT6765 Build ID RP1A.200720.011 Build Date Thu Nov 25 220235 CST 2021 Display ID 00WW_2_280 Security Patch 2021-11-05 Version SDK 30 Version Release 11 Version Codename REL Firmware Version 00WW_2_280 Read partition nvdata... OK Read partition nvram... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1 35XXXXXXXXXXXXX IMEI 2 35XXXXXXXXXXXXX Repairing IMEI... IMEI 1 35XXXXXXXXXXXXX IMEI 2 35XXXXXXXXXXXXX Write IMEI [NVDATA]... OK Patch CERT not need for this model! Write IMEI [NVRAM]... OK Write partition nvdata... OK Write partition nvram... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. |
