05-14-2024, 21:24 | #1 (permalink) |
Insane Poster Join Date: Oct 2016 Location: algers
Member: 2636585 Status: Offline Thanks Meter: 9 | oppo reno 8 5g cph2359 imei repair [Answered] phone supported or not log Selected model: OPPO CPH2359 (Oppo Reno8 5G) Operation: Repair Software version: 6.9 Work ID: 28430046 Connect phone in PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1632 (Android),usb2ser.sys,3.0.1504.0] Device found at COM86 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Preloader exist. Skip connection verification. Get ME ID... OK ME_ID = 0x27654F8D, 0xA4AA65C0, 0x09D53C76, 0xF66DB16B Load DownloadAgent... OK Search DA... OK [0] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [PRELOADER] Preloader alive. Skip initializing external RAM Get device info... OK UFS CID (FW VER): MT256GAXAT4U31 (0107) Send preloader... OK Load DownloadAgent... OK Search DA... OK [19] Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT256GAXAT4U31 UFS_FWVER : 0107 BLOCK_SIZE: 0x0000001000 (4,00Kb) UFS_LU0 : 0x0000400000 (4,00Mb) UFS_LU1 : 0x0000400000 (4,00Mb) UFS_LU2 : 0x3B96000000 (238,34Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Checking USB status... USB_HIGH_SPEED [EFUSE INFO]: BROM not disabled Read partitions info from phone... OK Checking A/B state... OK [A] Read product info... [EROFS] ... OK Product Brand : OPPO Product Manufacturer : OPPO Product Model : CPH2359 Product Name : CPH2359EEA Product Device : OP5339L1 Product Board : k6893v1_64_k419 Board Platform : mt6893 Build ID : UKQ1.230924.001 Build Date : Wed Jan 17 22:28:08 CST 2024 Display ID : CPH2359_14.0.0.300(EX01) Security Patch : 2024-01-05 Version SDK : 34 Version Release : 14 Version Codename : REL Firmware Version : S.15ddff4-1 Userdata FS Type : F2FS Read security partition from phone... Decrypting security data... OK Encrypt security data... OK Read partition "nvdata"... OK Read partition "protect1"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read security files... OK Calculating... OK Repairing IMEI... IMEI 1: 868380xxxxxxxxx IMEI 2: 868380xxxxxxxxx Write IMEI and patch CERT [NVDATA]... OK Checking patch type... patch impossible |
05-14-2024, 21:41 | #2 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,127 | Hello. In most cases if you see patch impossible - its not supported. For some models that have much older firmware - you can try to downgrade and check then. |
05-15-2024, 12:09 | #7 (permalink) |
Member: 2636585 Status: Offline Thanks Meter: 9 | Selected model: OPPO CPH2359 (Oppo Reno8 5G) Operation: Flash (Download only) Software version: 6.10 If BROM was disabled and you want write preloader partition not compatible for this model, phone will bricked. Recovery possible only with ISP mode. Continue? YES Work ID: 28465525 Parse scatter file... OK Load Rom Images... OK Connect phone in PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1632 (Android),usb2ser.sys,3.0.1504.0] Device found at COM86 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Preloader exist. Skip connection verification. Get ME ID... OK ME_ID = 0x27654F8D, 0xA4AA65C0, 0x09D53C76, 0xF66DB16B Load DownloadAgent... OK Search DA... OK [0] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [PRELOADER] Preloader alive. Skip initializing external RAM Get device info... OK UFS CID (FW VER): MT256GAXAT4U31 (0107) Send preloader... OK Load DownloadAgent... OK Search DA... OK [19] Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT256GAXAT4U31 UFS_FWVER : 0107 BLOCK_SIZE: 0x0000001000 (4,00Kb) UFS_LU0 : 0x0000400000 (4,00Mb) UFS_LU1 : 0x0000400000 (4,00Mb) UFS_LU2 : 0x3B96000000 (238,34Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Get scatter info... OK Checking USB status... USB_HIGH_SPEED [EFUSE INFO]: BROM not disabled Read partitions info from phone... OK Checking A/B state... OK [A] Read product info... [EROFS] ... OK Product Brand : OPPO Product Manufacturer : OPPO Product Model : CPH2359 Product Name : CPH2359 Product Device : OP5339L1 Product Board : k6893v1_64_k419 Board Platform : mt6893 Build ID : TP1A.220905.001 Build Date : Fri Jun 2 12:51:39 CST 2023 Display ID : CPH2359_13.1.0.560(EX01) Security Patch : 2023-06-05 Version SDK : 33 Version Release : 13 Version Codename : REL Firmware Version : S.10f4acf-59f Userdata FS Type : F2FS Partition "seccfg" changed: addr<0x1E800000>-->addr<0x1E800000>, len<0x800000>-->len<0x3B73800000> Partition table changed! The firmware must be downloaded with "Upgrade" option Prepare list for upgrade... OK Checking upgrade list... OK Prepare format list... OK Prepare final partition list... OK Read partition "preloader"... OK Read partition "nvcfg"... OK Read partition "persist"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "proinfo"... OK Read partition "nvram"... OK Read partition "ocdt"... OK Verify checksum... OK Format "UFS_LU2" partition( 0x00008000..0x0F307FFF )... OK Format "UFS_LU2" partition( 0x11308000..0x1A307FFF )... OK Format "UFS_LU2" partition( 0x1E800000..0x1EFFFFFF )... OK Format "UFS_LU2" partition( 0x22000000..0x3DEFFFFF )... OK Format "UFS_LU2" partition( 0x42A00000..0x3B94FF7FFF )... OK Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Checking partition table layout changed... OK Generate mirror partition table... OK Downloading mirror partition table... OK Read major partition table... OK Checking major partition table layout changed... OK Generate major partition table... OK Downloading major partition table... OK Download "preloader"... OK Download "oplusreserve1"... OK Download "oplusreserve2"... OK Download "oplusreserve3"... OK Download "oplus_custom"... OK Download "vbmeta_a"... OK Download "vbmeta_system_a"... OK Download "vbmeta_vendor_a"... OK Download "md1img_a"... OK Download "spmfw_a"... OK Download "audio_dsp_a"... OK Download "pi_img_a"... OK Download "dpm_a"... OK Download "scp_a"... OK Download "sspm_a"... OK Download "mcupm_a"... OK Download "cam_vpu1_a"... OK Download "cam_vpu2_a"... OK Download "cam_vpu3_a"... OK Download "gz_a"... OK Download "lk_a"... OK Download "boot_a"... OK Download "vendor_boot_a"... OK Download "dtbo_a"... OK Download "tee_a"... OK Download "oplusreserve5"... OK Download "oplusreserve6"... OK Download "param"... OK Download "cdt_engineering_a"... OK Download "logo"... OK Download "super"... OK |
05-15-2024, 12:39 | #9 (permalink) |
Member: 2636585 Status: Offline Thanks Meter: 9 | Selected model: OPPO CPH2359 (Oppo Reno8 5G) Operation: Restore From Backup Software version: 6.10 Work ID: 28455687 Parse scatter file... OK Load Rom Images... OK Connect phone in PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1632 (Android),usb2ser.sys,3.0.1504.0] Device found at COM30 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Preloader exist. Skip connection verification. Get ME ID... OK ME_ID = 0x27654F8D, 0xA4AA65C0, 0x09D53C76, 0xF66DB16B Load DownloadAgent... OK Search DA... OK [0] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [PRELOADER] Preloader alive. Skip initializing external RAM Get device info... OK UFS CID (FW VER): MT256GAXAT4U31 (0107) Send preloader... OK Load DownloadAgent... OK Search DA... OK [19] Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT256GAXAT4U31 UFS_FWVER : 0107 BLOCK_SIZE: 0x0000001000 (4,00Kb) UFS_LU0 : 0x0000400000 (4,00Mb) UFS_LU1 : 0x0000400000 (4,00Mb) UFS_LU2 : 0x3B96000000 (238,34Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Get scatter info... OK Checking USB status... USB_HIGH_SPEED [EFUSE INFO]: BROM not disabled Read partitions info from phone... OK Checking A/B state... OK [A] Read product info... [EROFS] ... OK Product Brand : OPPO Product Manufacturer : OPPO Product Model : CPH2359 Product Name : CPH2359 Product Device : OP5339L1 Product Board : k6893v1_64_k419 Board Platform : mt6893 Build ID : TP1A.220905.001 Build Date : Fri Jun 2 12:51:39 CST 2023 Display ID : CPH2359_13.1.0.560(EX01) Security Patch : 2023-06-05 Version SDK : 33 Version Release : 13 Version Codename : REL Firmware Version : S.10f4acf-59f Userdata FS Type : F2FS Read partitions info from phone... OK Write file "nvdata.bin"... OK Write file "nvram.bin"... OK Restore Backup done! |
05-15-2024, 16:43 | #11 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Pakistan
Member: 2680797 Status: Offline Thanks Meter: 45 | I try on old ver but same ERROR . Please Team Help. . . Code: Selected model: OPPO CPH2359 (Oppo Reno8 5G) Operation: Repair Software version: 6.10 Connect Type-C to NONE... OK Host Power Off... OK Connect phone to [PC] in PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1633 (Android),usb2ser.sys,3.0.1504.0] Device found at COM45 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Preloader exist. Skip connection verification. Get ME ID... OK ME_ID = 0x79645271, 0x0BD91334, 0x878D452B, 0xA6DCC920 Load DownloadAgent... OK Search DA... OK [0] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [PRELOADER] Preloader alive. Skip initializing external RAM Get device info... OK UFS CID (FW VER): MT256GAXAT4U31 (0107) Send preloader... OK Load DownloadAgent... OK Search DA... OK [19] Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT256GAXAT4U31 UFS_FWVER : 0107 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x3B96000000 (238.34Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Checking USB status... USB_HIGH_SPEED [EFUSE INFO]: BROM not disabled Read partitions info from phone... OK Checking A/B state... OK [B] Read product info... [EROFS] ... OK Product Brand : OPPO Product Manufacturer : OPPO Product Model : CPH2359 Product Name : CPH2359EEA Product Device : OP5339L1 Product Board : k6893v1_64_k419 Board Platform : mt6893 Build ID : TP1A.220905.001 Build Date : Thu Nov 23 23:34:45 CST 2023 Display ID : CPH2359_13.1.0.580(EX01) Security Patch : 2023-12-05 Version SDK : 33 Version Release : 13 Version Codename : REL Firmware Version : S.14c4e52_1 Userdata FS Type : F2FS Read security partition from phone... Decrypting security data... OK Encrypt security data... OK Read partition "nvdata"... OK Read partition "protect1"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read security files... OK Calculating... OK Repairing IMEI... IMEI 1: 8633340XXXXXXXX IMEI 2: 8633340XXXXXXXX Write IMEI and patch CERT [NVDATA]... OK Checking patch type... patch impossible |
