04-17-2021, 21:24 | #1 (permalink) |
Junior Member Join Date: Jun 2013 Age: 42
Member: 1968886 Status: Offline Thanks Meter: 8 | Huawei DRA-LX3 Repair Imei Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6739] Get sec config... OK [000000E3] Active sec flags: [SBC SLA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM189 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6739] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xEA113C32, 0x6E509122, 0x3BBFED33, 0xDC4B8E59 Get Chip ID... [MT6739] Get SOC ID... [F381F215DAD5396EDC0A459411A89B013254ECC31DB0306EBD 02CB37D0F05643] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [0] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100464536324D420673D9683545B3 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [2] Trying EMI [FC9B8C75, 50D22373] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100464536324D420673D9683545B3 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x03A3E00000 (14.56Gb) RAM INFO: INT_SRAM: 0x0000020000 (128.00Kb) EXT_RAM : 0x0040000000 (1.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "nvdata"... OK Read partition "nvram"... OK Read NVRAM files... OK Read IMEI... OK Read NVDATA files... OK Read IMEI... OK IMEI: xxxxxxxxxx98541 Set new IMEI to: IMEI: xxxxxxxxxx33190 Write IMEI... OK Format EMMC_USER partition( 0x01F00000..0x03EFFFFF )... OK Repair Security done! |
The Following 3 Users Say Thank You to apunegro For This Useful Post: |
