Pandora’s Box 3.0 Update. Improved repair and patch algo Pandora’s Box 3.0 Update. Repair and patch algo improved! Bugfixes and improvements: - Fixed repair and Patch CERT on some Xiaomi, OPPO, Realme - Fix Wipe Data with UFS - Fixed Load EMI from phone... Skip for MT6768 (in 2.12 version) - Fixed Memory Leak on some operation with ext4 New Oukitel phones added for support: - Oukitel C19 Pro - Oukitel C21 Pro - Oukitel K9 Pro - Oukitel WP12 Pro - Oukitel WP13 - Oukitel WP15 - Oukitel WP16 - Oukitel WP17 - Oukitel RT1 New Blackview phones added for support: - A55 Blackview A55 - A95 Blackview A95 - BL5000 Blackview BL5000 - BV8800 Blackview BV8800 - Oscal S60 Blackview Oscal S60 New Infinix phones added for support: - X662 Infinix Hot 11 - X662B Infinix Hot 11 - X663 Infinix Note 11 - X663B Infinix Note 11 - X689F Infinix Hot 11 - X697 Infinix Note 11 Pro - X698 Infinix Note 11s - X6810 Infinix Zero X Pro - X6811 Infinix Zero X - X6811B Infinix Zero X - X6812 Infinix Hot 11s - X6812B Infinix Hot 11s Dont forget post BUG reports in correct thread. Bug report - HERE New phone adding request - HERE FACEBOOK NEWS - HERE |
nice nice nice i will test now |
dera dera mananaa thanks a lot |
not working on poco x3 gt please fix the problem |
please explain that |
repair imei pocox3gt Quote:
Good Update. Nice Improvements And Bug Fixing. Carry On. |
repair imei pocox3gt not working Selected model: Xiaomi 21061110AG (Poco X3 GT) Operation: Repair Software version: 3.0 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [Sony Mobile Communications,usbser,MTK USB Port,usbser.sys,10.0.19041.1202] Device found at COM131 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [Sony Mobile Communications,usbser,MTK USB Port,usbser.sys,10.0.19041.1202] Device found at COM131 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0950 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6893] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x44B83704, 0xB206672E, 0x68B8C641, 0x306CDBA7 Get Chip ID... [MT6893] Get SOC ID... [A0BD90259423ECF933CD152029D3D77B5744A92B06D3DB663C 55D8693D2B56B7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [19] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KLUEG8UHDC-B0E1 (0200) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KLUEG8UHDC-B0E1 UFS_FWVER : 0200 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x3B96000000 (238.34Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK [A] Read product info... OK Product Brand : redmi Product Manufacturer : Xiaomi Product Model : chopin Product Name : chopin Product Device : chopin Product Board : chopin Board Platform : MT6893 Build ID : RP1A.200720.011 Build Date : Tue Nov 30 10:47:34 CST 2021 Display ID : RP1A.200720.011 Security Patch : 2021-11-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : V12.5.7.0.RKPMIXM Read partition "nvdata"... error(8), skip Read partition "nvram"... error(2), skip Read NVDATA files... error(5) |
force install mtk driver from Pandora folder. |
oppo f11 android 11 imei repair success but bootloops then i downgrade to 10 but now imei null and baseband unknown. any solution plz also fix android 11 and 12 imei repair support. |
Oppo A12 imei null not work...plz help and i need solution 1 Attachment(s) Selected model: OPPO CPH2083 (Oppo A12) Operation: Repair Software version: 3.0 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM21 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x93122103, 0x40344846, 0x05257478, 0xFFF458AB Get Chip ID... [MT6765] Get SOC ID... [0051DFB3C26346555D8461AF1FD00A2AF32CEC354D13604B9F 306AB77BA09065] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100444436384D42024410AACA55D1 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100444436384D42024410AACA55D1 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000400000 (4,00Mb) EMMC_USER : 0x0747C00000 (29,12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x00C0000000 (3,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Manufacturer : OPPO Product Board : oppo6765_19451 Board Platform : MT6765 Build ID : PPR1.180610.011 Build Date : Thu Nov 26 01:43:04 CST 2020 Security Patch : 2020-11-05 Version SDK : 28 Version Release : 9 Version Codename : REL Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 863634047544293 IMEI 2: 863634047544285 Write IMEI [NVDATA]... error(1) Attachment 385433 need the solution ,thx |
hi restore org nv data and nvram and try again with downgrade firmware |
redmi 6 boot unlock not working log Selected model: Xiaomi M1804C3DG (Redmi 6) Operation: Unlock bootloader Software version: 3.0 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM240 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x2E2AA4B8, 0x47112D87, 0xC7588B56, 0x21087055 Get Chip ID... [MT6765] Get SOC ID... [0341D6E7FFD1419D195D689A6B54A31DD00CE5135998882E1C B6A9EC457D4048] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68423861503E011765743865CB Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68423861503E011765743865CB EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0747C00000 (29,12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x00C0000000 (3,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : xiaomi Product Manufacturer : Xiaomi Product Model : Redmi 6 Product Name : cereus Product Device : cereus Product Board : cereus Board Platform : MT6765 Build ID : PPR1.180610.011 Build Date : Wed May 27 17:02:03 WIB 2020 Display ID : SW_S98507AE1_V009_M13_XM_C3D_USR Security Patch : 2020-05-01 Version SDK : 28 Version Release : 9 Version Codename : REL Firmware Version : V11.0.4.0.PCGMIXM Read security partition from phone... OK Decrypt security data... OK Encrypt security data... OK Write security partition to phone... OK Unlock bootloader done! programm say unlocked but not unlocked other tool unlocket without problem please fix problem |
vivo v23 5g Dimensity 920 5G imei not support plz add... |
