06-28-2022, 16:21 | #16 (permalink) |
Major Poster Join Date: Oct 2016 Location: pakistan
Member: 2632752 Status: Offline Thanks Meter: 7 | |
The Following 2 Users Say Thank You to Abaid virk For This Useful Post: |
06-29-2022, 00:10 | #19 (permalink) |
Insane Poster Join Date: Oct 2014 Location: Algeria
Member: 2275199 Status: Offline Thanks Meter: 19 | imei not writing in phone rmx2121 UFS INFO: UFS_CID : KLUDG4UHDB-B2D1 UFS_FWVER : 0900 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Build ID : RP1A.200720.011 Build Date : Mon Mar 14 00:37:02 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1612759478108 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 356645389442031 IMEI 2: 356645389442023 Write IMEI [NVDATA]... OK Checking patch type... [2] Load partiton for patching... OK Patching CERT... already patched, skip Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Selected model: Realme RMX2121 (Realme X7 Pro) Operation: Repair Software version: 3.7 |
06-30-2022, 11:01 | #21 (permalink) |
Junior Member Join Date: Oct 2019 Location: kasur Age: 36
Member: 2931376 Status: Offline Thanks Meter: 1 | hello pandora Box team vivo February update not imei repair fix bug broom disable add new update best reg |
The Following User Says Thank You to mrkasur For This Useful Post: |
07-04-2022, 07:30 | #22 (permalink) |
Crazy Poster Join Date: Oct 2015 Location: Faisalabad pakistan kchery bza
Member: 2475430 Status: Offline Sonork: [email protected] Thanks Meter: 15 | vivo new security 2022 android 12 imei repair plzzzzzzz add |
07-05-2022, 08:04 | #24 (permalink) |
Freak Poster Join Date: Oct 2010 Location: ....
Member: 1414949 Status: Offline Sonork: 100.1626290 Thanks Meter: 32 | its say Job Done but still same Selected model: Realme RMX2121 (Realme X7 Pro) Operation: Unlock network Software version: 3.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0816 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0001, HW SUB CODE: 8A00 Detect chip [MT6885] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM87 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0816 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0001, HW SUB CODE: 8A00 Detect chip [MT6885] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x82756CA0, 0xE95B1AC7, 0xB54955A5, 0x83928D1A Get Chip ID... [MT6885] Get SOC ID... [E7975F912374A58A21434C0D7EA5A75BF5602494866F7CC5EA CC73FF3059EA3E] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [18] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KLUDG4UHDB-B2D1 (0900) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KLUDG4UHDB-B2D1 UFS_FWVER : 0900 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6889 Board Platform : MT6885 Build ID : RP1A.200720.011 Build Date : Sat Jul 3 00:43:33 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-06-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1612759478108 Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... OK Unlock... OK [DF1, DF2, GB1, GB2] Write lock info... OK Write security partition to phone... OK Network Unlock done! |
The Following User Says Thank You to Jeethesh For This Useful Post: |
07-07-2022, 20:53 | #26 (permalink) |
Member: 2475430 Status: Offline Sonork: [email protected] Thanks Meter: 15 | vivo v23e v2116 v2115 android 12 mtk pattern+frp+read right+imei repair plzzzz addd🙏🙏🙏🙏🙏🙏🙏🙏🙏 |
The Following User Says Thank You to muhammadrashid1 For This Useful Post: |
07-15-2022, 22:42 | #28 (permalink) |
Freak Poster Join Date: Aug 2009 Location: turkey
Member: 1105442 Status: Offline Thanks Meter: 46 | Why does Pandora update need a month and add only three models of the same company model So far, all updates are not worthy of the box price and not worthy of a team And the addition of new features does not take this period of time I have been in possession of the box for three months and I have not seen a completely new feature that is not found in any other device I ask the team to speed up the feature additions as we used to from you previously, such as z3x |
The Following 3 Users Say Thank You to hafeez91 For This Useful Post: |
