09-11-2021, 19:49 | #16 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,551 | Quote:
If you want discuss pandora's update or want say that something wrong with it, do it. Also if you have this tool you can post feetback or you can post about bug in correct thread. But if i will see here any discussion regarding other tool, other teams or other things not related to Pandora's box and if after warning someone will continue, then i will ban from section be sure. Its not bazaar for play with worlds, you come to Pandora's section where i have posted thread with Exclusive updates for Pandora users. | |
09-11-2021, 19:51 | #17 (permalink) | |
About layout i will talk with developers, but i think they do all best what they can for such type of MTK tool. | |
The Following User Says Thank You to blang For This Useful Post: |
09-12-2021, 12:15 | #19 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,551 | hello if you will make fud with things not related to pandora i will ban you from pandora forum. If you have create post about bug with your phone already, then developers already looking hot to fix problem. You can continue trace your request in that thread and all comments will be in that thread. |
09-12-2021, 19:55 | #20 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | This is really good update at least am grateful almost all my requests have been added to the box. Good team about a107f am very happy. Do this for all Mtk samsung devices if possible. One other request is to add a partition manager to help write single files without scatter file such as Huawei oeminfo, nvram, nvdata, preloader, boot, recovery, etc |
09-13-2021, 08:01 | #23 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | |
09-13-2021, 10:21 | #24 (permalink) | |
Did you read above? If you have problem - open own thread with exactly model and exactly problem and developers will check. If you want add some new function make request in correct thread. | |
09-13-2021, 14:15 | #25 (permalink) |
Crazy Poster Join Date: Oct 2020 Location: Burundi
Member: 2970322 Status: Offline Thanks Meter: 6 | "Force Preloader To BROM' checkbox. Function for switch from preloader to BROM without testpoint. (Work not anywhere but very useful to connect Samsung phones.)" Hy, which samsung phone does it work on? A325f? |
09-15-2021, 17:31 | #27 (permalink) | |
And then developers will review your request. | |
09-16-2021, 05:31 | #28 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | in new update 2.5 but same result .not working in new update 2.5 but same result .not working. i waiting for this update but unfortunately not give me solution by z3x team Selected model: Vivo PD1913F (Vivo S1) Operation: Reset password Software version: 2.5 This procedure will erase all downloaded apps and their data. Photos, music, and other non-app will be retained. Continue? YES Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM90 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xF60787E6, 0xA251F6C2, 0xF30DF03A, 0xF5FE171E Get Chip ID... [MT6768] Get SOC ID... [35792DAA099D42EE9A78D1A2518E08F7E6A234040194D1EC7D 862775F37576BB] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445636444D4202D8B968E7A6E3 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100445636444D4202D8B968E7A6E3 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read info from phone... OK Processing data #1... OK Processing data #2... OK Reset Password done! |
09-16-2021, 09:46 | #29 (permalink) | |
