Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #46 (permalink) |
Crazy Poster ![]() ![]() ![]() Join Date: Jul 2012
Member: 1786170 Status: Offline Thanks Meter: 3 | Operation: Repair Software version: 4.4 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Waiting for device... OK Device found at COM6 Port: USB\VID_1782&PID_4D00\5&2C27A5E&0&3 Connecting to device... OK Selected processor: Tiger_T610_64 Load files... OK Connect preloader 1... OK Connect preloader 2... OK Connect loader 1... OK Connect loader 2... OK Serial Number: 00216D401B08293410HA0GW1 Read partitions info... OK Checking A/B state... OK [B] Read product info... OK Product Brand : realme Product Manufacturer : realme Product Model : RMX3261 Product Name : RMX3261 Product Device : RMX3261 Build ID : RP1A.201005.001 Build Date : Sun Apr 3 11:44:02 CST 2022 Display ID : RMX3261_11_A.81 Security Patch : 2022-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1648957531000 Load NVD... OK Read IMEI... OK Current IMEI: IMEI 1: 866691050787612 IMEI 2: 866691050787604 Repaired IMEI: IMEI 1: 354122xx IMEI 2: 354122xxx Check security state... OK [1] Unlock bootloader... OK Patch modem check... error(5.3) If your phone after repair keeps rebooting - use wipe data option. |
![]() | #48 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 205 | Please fix spd bug when using Network unlock function tool also automatically unlockes bootloader and phone ends up in boot loop or hang on logo. And only way out is by flashing yet some phones getting the firmware is not easy Other devices like Nokia G21 after unlock permanently locked |
The Following User Says Thank You to okello For This Useful Post: |
![]() | #49 (permalink) |
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 205 | please what is cause of this error trying to flash with cfg file Loading files... Exception: This operation can not be performed with a node of type ELEMENT Selected model: Nokia TA-1433 (Nokia C21 Plus) Operation: Read Flash Info Software version: 4.4 |
![]() | #50 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2021 Location: San Francisco De Macoris Age: 29
Member: 2979877 Status: Offline Thanks Meter: 18 | In the future do you improve Meta Mode to make unlock network with tracfone device models that are not yet supported in new security via Brom like a509DL,a508DL,B140DL,B130DL? |
![]() | #51 (permalink) | |
Junior Member ![]() Join Date: Sep 2021 Location: South Africa
Member: 2997515 Status: Offline Thanks Meter: 6 | Quote:
![]() | #52 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2407856 Status: Offline Thanks Meter: 0 | Licencing/Binding issue: I bought the digital license of Pandora box. Initially it worked fine. But after a week use, it shows the message "No more attempt to bind new PC untill....". As far I remember, I haven't used the license to any other pc. Could anyone please help me out? |
![]() | #56 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2011
Member: 1655288 Status: Offline Thanks Meter: 88 | Selected model: Realme RMX2189 (Realme C12) Operation: Repair Software version: 4.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Waiting for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1448.0] Device found at COM105 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xAB5F9827, 0x1B6E3DD1, 0x9605545D, 0x410D1497 Get Chip ID... [MT6765] Get SOC ID... [B9AD2DDB401F467023AE15F25DBD9B7CC7C49BF55DA4D0D879 87187BEEC8EBB5] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68423861503E03006A27F91811 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_CNAME: hB8aP> EMMC_ID : 0x90014A68423861503E03006A27F91811 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6765 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Tue Jul 5 12:27:48 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-07-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1609743540423 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 359749100354652 IMEI 2: 359749100352789 Write IMEI [NVDATA]... OK Checking patch type... [1] Patching partition... OK Save patched partiton... OK Read partitions info from phone... OK Read security partition from phone... OK Decrypting security data... OK Encrypt security data... OK Write security partition to phone... OK Checking additional lock... [ENABLED] Disable additional lock... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. after repair imei NULL in version 4.6 of pandora box but old version 3.2 was worked good now old version block by team |
![]() | #58 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Nov 2016
Member: 2647618 Status: Offline Thanks Meter: 16 | ![]() [QUOTE=blang;14725457]Pandora Tool 4.4 Update, Lot of new devices added to supported. HEllo i have onl one simply question.. CAN this tool UNLOCK any XIOMI bootloader even in lost or blocked state?? i have ton of customers (my country is big market for thise phones, thx to bojkot of huawei products) can it unlock by force?? iwhotu acess inside SW for UNLOCK READY button::? pls YES or NO (or ez xplanation thx) |
