03-28-2023, 18:53 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: In front of my pc
Member: 586318 Status: Offline Thanks Meter: 112 | Samsung A037u unlock done but still locked [Answered] Code: Selected model: Samsung SM-A037U (Galaxy A03s) Operation: Unlock network (Server) Software version: 4.8 Checking Login and Password... OK Balance: 11 crd. You have 11 credit(s) left. This operation takes 5 credits. Continue? Yes Searching Samsung modem... detected COM33 Reading phone info... OK Model: SM-A037U AP version: A037USQS3BVI2 CSC version: A037UOYN3BVI2 CP version: A037USQS3BVI2 OS version: 12 Product code: XAA Carrier ID: XAA Phone SN: R9WT90V13QJ Unique number: W154758300D3A106A189 IMEI: 354327823847677 IMEI Certi: PASS Powering off... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM35 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Waiting for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM36 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x6E2EEC1E, 0xA6C0CD25, 0x33AC0D96, 0xFF0D4A03 Get Chip ID... [MT6765] Get SOC ID... [D678A0984579111303B36467DA2725B7DCDCCDBCAA3821FE44809685AD731853] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x15010047583642414200D3A106A1896B Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_CNAME: GX6BAB EMMC_ID : 0x15010047583642414200D3A106A1896B EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK Read product info... OK Product Brand : samsung Product Manufacturer : samsung Product Model : SM-A037U Product Name : a03susq Product Device : a03su Product Board : a03su Board Platform : connac1x Build ID : SP1A.210812.016 Build Date : Fri Sep 30 20:32:34 KST 2022 Display ID : SP1A.210812.016.A037USQS3BVI2 Security Patch : 2022-10-01 Version SDK : 31 Version Release : 12 Version Codename : REL Firmware Version : A037USQS3BVI2 Read security partition from phone... OK Read security files... OK Read lock info... OK Searching server... OK Waiting for server answer... OK Unlocking ... [1] ... OK Write lock info... OK Write security partition to phone... OK Network Unlock done! |
03-28-2023, 19:27 | #3 (permalink) | |
Freak Poster Join Date: Feb 2021 Location: San Francisco De Macoris Age: 30
Member: 2979877 Status: Offline Thanks Meter: 82 | Quote:
The Following User Says Thank You to darkherman For This Useful Post: |
