05-16-2022, 13:57 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: algeria
Member: 242222 Status: Offline Thanks Meter: 54 | pleas help for redmi note9 imie [Solved] Selected model: Xiaomi M2003J15SS (Redmi Note 9) Operation: Read Flash Info Software version: 3.4 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM56 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM56 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xFE9C01AB, 0xD5AE7640, 0x3D79E82A, 0x0BEBE369 Get Chip ID... [MT6768] Get SOC ID... [B2FE45B7AE94FA24199C09C0DA6B5AD0415AEDABAD22BC4EA5 14EA5677D359A3] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E47314A3953391005DDF62657AF Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E47314A3953391005DDF62657AF EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x1D1F000000 (116,48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : M2003J15SC Product Name : merlin_global Product Device : merlin Product Board : merlin Board Platform : MT6768 Build ID : QP1A.190711.020 Build Date : Tue Feb 23 23:07:28 CST 2021 Display ID : AL2522-Merlin-V101-Q-0223 Security Patch : 2021-02-01 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : V12.0.7.0.QJOMIXM Read Flash Info done! |
05-18-2022, 14:22 | #3 (permalink) |
Member: 242222 Status: Offline Thanks Meter: 54 | it ok its ripar then patch cert Selected model: Xiaomi M2003J15SS (Redmi Note 9) Operation: Patch CERT Software version: 3.4 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM50 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM50 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xFE9C01AB, 0xD5AE7640, 0x3D79E82A, 0x0BEBE369 Get Chip ID... [MT6768] Get SOC ID... [B2FE45B7AE94FA24199C09C0DA6B5AD0415AEDABAD22BC4EA5 14EA5677D359A3] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E47314A3953391005DDF62657AF Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E47314A3953391005DDF62657AF EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x1D1F000000 (116,48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : M2003J15SC Product Name : merlin_global Product Device : merlin Product Board : merlin Board Platform : MT6768 Build ID : QP1A.190711.020 Build Date : Tue Feb 23 23:07:28 CST 2021 Display ID : AL2522-Merlin-V101-Q-0223 Security Patch : 2021-02-01 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : V12.0.7.0.QJOMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Load partiton for patching... OK Check modem patch possiblity... error, skip Patching CERT... OK Save patched partiton... OK Format "parameter" partition... OK Write partition "nvdata"... OK Write partition "nvram"... OK Patch cert done! If your phone after repair keeps rebooting - use wipe data option. |
05-18-2022, 14:24 | #4 (permalink) |
