Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 09-05-2021, 14:21   #61 (permalink)
Member: 1485943
Thanks Meter: 55
Selected model: Xiaomi M1908C3JGG (Redmi Note 8 (2021))
Operation: Erase FRP
Software version: 2.4
Host Power Off... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Send start cmd... OK
Get HW code from device... 0707
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6768]
Get sec config... OK [000000E7]
Active sec flags: [SBC SLA DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Connect Type-C to HUB... OK
Wait for device connecting... OK
Device found at COM17 [BROM]
Open port... OK
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0x367F06DB, 0xF4B504D6, 0x39CD4700, 0xC045FAC5
Get Chip ID... [MT6768]
Get SOC ID... [475130DF618294C732122817C9E8AC0AB1E0154A9E7D9836AF 5AB54C9917BB51]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [25]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x90014A68433861503E031049093CA7CB
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x90014A68433861503E031049093CA7CB
EMMC_BOOT1: 0x0000400000 (4,00Mb)
EMMC_BOOT2: 0x0000400000 (4,00Mb)
EMMC_RPMB : 0x0001000000 (16,00Mb)
EMMC_USER : 0x0E8F800000 (58,24Gb)
RAM INFO:
INT_SRAM: 0x0000070000 (448,00Kb)
EXT_RAM : 0x0100000000 (4,00Gb)
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Read partition "frp"... OK
Format "frp" partition... OK
Writting FRP data... OK
Erase FRP done!
Old 09-14-2021, 12:59   #62 (permalink)
Gsm Africa Team's Avatar
Member: 2986985
Thanks Meter: 163
VODACOM Kicka 5 Plus 4G FRP Removed
Selected model: Mediatek Mediatek
Software version: 2.5
Host Power On... OK
Get HW code from device... 0699
HW VER: CB00, SW VER: 0002, HW SUB CODE: 8A00
Detect chip [MT6739]
Get sec config... OK [00000000]
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0]
Device found at COM115 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0xA23F54CB, 0xF98B3A33, 0xAA8B0258, 0x5167B6E2
Get Chip ID... [MT6739]
Get SOC ID... [367C2B8596736E0E786DD3649923281BB8266376ADB53998A8 4C9CE20AD6C995]
Search DA... OK [0]
EMMC_ID: 0x70010054323237303801395741019735
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x70010054323237303801395741019735
EMMC_RPMB : 0x0000400000 (4,00Mb)
EMMC_USER : 0x01C8000000 (7,13Gb)
RAM INFO:
INT_SRAM: 0x0000020000 (128,00Kb)
EXT_RAM : 0x0040000000 (1,00Gb)
Erase FRP done!
Old 09-14-2021, 13:06   #63 (permalink)
Member: 2986985
Thanks Meter: 163
VODACOM Kicka 5 Plus 4G Network Unlock done!
Operation: Unlock network
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [0]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Read security partition from phone... OK
Read security files... OK
Read lock info... OK
Write lock info... OK
Write security partition to phone... OK
Old 09-15-2021, 11:44   #64 (permalink)
Member: 2986985
Thanks Meter: 163
NOKIA 2.4 TA-1270 Password Removed done
Operation: Wipe Data
There is a risk of data loss.
This procedure will erase all User Data
Make sure that you have a backup created. Continue? YES
Host Power On... OK
Get HW code from device... 0766
Detect chip [MT6765]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x9A73C5B4, 0xE54C027A, 0xEA613E8A, 0x61CACAE8
Get Chip ID... [MT6765]
Get SOC ID... [1A227D123E6B8F7161610F32C64FE8105E2720C8A98AE54A33 FEE2AE1F74C6A5]
Search DA... OK [23]
EMMC_ID: 0x880103534C44333247591AB7C8239721
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x880103534C44333247591AB7C8239721
EMMC_USER : 0x073A000000 (28,91Gb)
RAM INFO:
INT_SRAM: 0x000003A000 (232,00Kb)
EXT_RAM : 0x0080000000 (2,00Gb)
Read partition "preloader"... OK
Read partition "pgpt"... OK
Read partition "nvcfg"... OK
Read partition "nvdata"... OK
Read partition "protect1"... OK
Read partition "protect2"... OK
Read partition "persist"... OK
Read partition "proinfo"... OK
Read partition "efuse"... OK
Read partition "nvram"... OK
Read partition "oem"... OK
Read partition "elabel"... OK
Read partition "otp"... OK
Read partition "flashinfo"... OK
Format "userdata" partition... OK
Wipe data done!
Old 09-27-2021, 15:16   #65 (permalink)
Member: 66497
Thanks Meter: 80
Xiaomi MI Play Unlock bootloader
Operation: Unlock bootloader
Host Power On... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0]
Device found at COM8 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x9CF5B672, 0x35002C94, 0x1A42CFC0, 0xB1574387
Get SOC ID... [BAF755DE746D2F3CABB3B9CCF64363F359E7848292D927B30D 7092E9358DB961]
EMMC_ID: 0x90014A68433861503E03CA1574E916EB
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x90014A68433861503E03CA1574E916EB
RAM INFO:
Decrypt security data... OK
Encrypt security data... OK
Unlock bootloader done!
Old 10-05-2021, 11:10   #66 (permalink)
Member: 2239923
Thanks Meter: 48
Originally Posted by kzafquiel View Post
Selected model: ZTE UNKNOWN
Operation: Read Flash Info
Software version: 1.7
copiar imagen de pagina web
Switch virtual port to NONE... OK
Host Power On... OK
Open port... OK
Get HW code from device... 0788
Detect chip [MT6771]
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x3257773D, 0xBC2D560F, 0x5DE19E90, 0xBB581B26
Get Chip ID... [MT6771]
Get SOC ID... [B35CE499B8B04002C8D17B2A334E9EC8FCB6221C4CB572D81D ABB16F75B3CCE7]
Get sec config... OK [000000E1]
Wait for answer from bootloader... timeout
Host Power On... OK
Active sec flags: [SBC]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
EMMC_ID: 0x45010044413431323801ABD76440C677
Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [2]
Trying EMI [08EDF5FC, 6A5BF28C]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x45010044413431323801ABD76440C677
EMMC_BOOT1: 0x0000400000 (4.00Mb)
EMMC_BOOT2: 0x0000400000 (4.00Mb)
EMMC_RPMB : 0x0001000000 (16.00Mb)
EMMC_USER : 0x1D1EC00000 (116.48Gb)
RAM INFO:
INT_SRAM: 0x0000039000 (228.00Kb)
EXT_RAM : 0x0100000000 (4.00Gb)
Read Flash Info done!
Operation: Read PTT
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Read partition "boot_para"... OK
Read partition "recovery"... OK
Read partition "para"... OK
Read partition "expdb"... OK
Read partition "ztecfg"... OK
Read partition "metadata"... OK
Read partition "seccfg"... OK
Read partition "sec1"... OK
Read partition "md1img"... OK
Read partition "md1dsp"... OK
Read partition "spmfw"... OK
Read partition "scp1"... OK
Read partition "scp2"... OK
Read partition "sspm_1"... OK
Read partition "sspm_2"... OK
Read partition "cam_vpu1"... OK
Read partition "cam_vpu2"... OK
Read partition "cam_vpu3"... OK
Read partition "gz1"... OK
Read partition "gz2"... OK
Read partition "lk"... OK
Read partition "lk2"... OK
Read partition "boot"... OK
Read partition "logo"... OK
Read partition "dtbo"... OK
Read partition "tee1"... OK
Read partition "tee2"... OK
Read partition "vendor"... OK
Read partition "system"... OK
Read partition "cache"... OK
Read partition "sgpt"... OK
Dumping Partitions done!
Operation: Read Region
Select region for dump!
Operation: Read OTP
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Check OTP status... [STATUS_OTP_UNLOCKED]
Read OTP... OK
Reading OTP done!
Operation: Read Codes
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
N Code : 12345678
NS Code : 00000000
SP Code : 781234??
C Code : 00000000
SIM Code : 2222????
NS_SP Code: 00000000
SIM_C Code: 44??????
Read Codes done!
Operation: Read IMEI Info
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Read NVRAM files... OK
Read IMEI... OK
IMEI: XXXXXXXX2255953
Reading IMEI done!
Operation: Repair
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Read IMEI... OK
Read NVDATA files... OK
Read IMEI... OK
Set new IMEI to:
IMEI: XXXXXXXX9021697
Write IMEI... OK
Format EMMC_USER partition( 0x05708000..0x09707FFF )... OK
Repair Security done!
SPECIAL THANK TO Z3X TEAM FOR BIULD PANDORA
Congratulations to the z3x team for bringing something better to the industry. I am a veteran developer but i love what i see is very successful in the market am mr.Hussein from Tanzania or if you want to use it Professional Tecnology support work also give a great support to our developer is a very good thing thank you.
Old 10-09-2021, 02:00   #67 (permalink)
Member: 1790061
Thanks Meter: 63
Selected model: Samsung SM-A125M (Galaxy A12)
Software version: 2.6
Host Power On... OK
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0]
Device found at COM15 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x234D1D35, 0x7B47D3D9, 0x8BA492AE, 0xC205E3C5
Get SOC ID... [D20F14082BCEEDA4B218220158780BFD3C3F35932ACCECBF0E 5960889A769F74]
EMMC_ID: 0x150100445036444142003CCCDC3C580D
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x150100445036444142003CCCDC3C580D
RAM INFO:
Read product info... OK
Product Brand : samsung
Product Manufacturer : samsung
Product Model : SM-A125M
Product Name : a12ub
Product Device : a12
Board Platform : MT6765
Product Board : k65v1_64_bsp_titan_rat
Build ID : RP1A.200720.012
Build Date : Fri Jul 30 07:45:34 KST 2021
Display ID : RP1A.200720.012.A125MUBU1BUG6
Security Patch : 2021-07-01
Version SDK : 30
Version Release : 11
Version Codename : REL
Read partition "persistent"... OK
Backup saved to PND_LINK_0085 "file:///C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Samsung_SM-A125M%20(Galaxy%20A12)/FRP_BACKUP_(2021-10-8_18-54-45)/"directory
Format "persistent" partition... OK
Erase FRP done!
Old 10-09-2021, 02:01   #68 (permalink)
Member: 1790061
Thanks Meter: 63
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Version SDK : 30
Erase FRP done!
Old 10-13-2021, 09:06   #69 (permalink)
Member: 2993836
Thanks Meter: 12
Thumbs up Infinix X612B FRP Removed Successfully by Pandora Box
Infinix X612B Smart HD
Log:
elected model: Infinix X612B (Infinix Smart HD)
Host Power On... OK
Get HW code from device... 0717
HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00
Detect chip [MT6761]
Device found at COM0 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID =  0xFC30B5C0, 0x7C2CBD9A, 0xB18B9A91, 0x4C014D1E
Get Chip ID... [MT6761]
Get SOC ID... [6B42A5357D177BD7AB81268FCC85748AD587ADAFFA53716A7A5B69453FDA087C]
Search DA... OK [24]
EMMC_ID: 0x15010051583633414203FBD7F4A628C5
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
   EMMC_ID   : 0x15010051583633414203FBD7F4A628C5
   EMMC_RPMB : 0x0000400000 (4.00Mb)
   EMMC_USER : 0x0747C00000 (29.12Gb)
RAM INFO:
   EXT_RAM : 0x0080000000 (2.00Gb)
Erase FRP done!
GSM City
Old 11-01-2021, 08:23   #70 (permalink)
Member: 1485943
Thanks Meter: 55
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Force switch to BROM... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0xC81EB35A, 0xA75FB227, 0x9D6BE1FA, 0xEDC46EBD
Get SOC ID... [5DF135F8A6B7A8DA8A3990613EDD1CAF11E5A8D0D25E483FC7 E8B1C364005754]
EMMC_ID: 0x90014A68423861503E03001808ADC773
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x90014A68423861503E03001808ADC773
EMMC_USER : 0x0747C00000 (29,12Gb)
RAM INFO:
Product Brand : Redmi
Product Manufacturer : Xiaomi
Product Model : lancelot
Product Name : lancelot_global
Product Device : lancelot
Board Platform : MT6768
Product Board : lancelot
Build ID : QP1A.190711.020
Build Date : Fri Sep 4 22:31:03 CST 2020
Display ID : build-20200904222635
Security Patch : 2020-09-01
Version SDK : 29
Version Release : 10
Unlock bootloader... OK
Reset Mi Account... OK
Reset Mi Acc done!
Old 11-02-2021, 16:03   #71 (permalink)
Member: 2293383
Thanks Meter: 11
SM-A107F empty main board repair IMEI with this tools
Selected model: Samsung SM-A107F (Galaxy A10s)
Operation: Repair
Host Power On... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1632 (Android),usb2ser.sys,3.0.1504.0]
Device found at COM28 [PRELOADER]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Device found at COM29 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x06B018EC, 0x1E036125, 0x0BEA6F6E, 0x1629DD54
Get SOC ID... [F72209EF99887E429A60F767707976747D70CFC8732DE0192A C537EFB4147D2A]
EMMC_ID: 0x150100514436334D420375321482B6D9
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x150100514436334D420375321482B6D9
RAM INFO:
INT_SRAM: 0x000003A000 (232.00Kb)
Product Brand : alps
Product Manufacturer : alps
Product Model : S96116AA1
Product Name : S96116AA1
Product Device : S96116AA1
Product Board : S96116AA1
Build ID : PPR1.180610.011
Build Date : Sat Jun 29 19:18:05 KST 2019
Display ID : S96116AA1
Security Patch : 2019-06-05
Version SDK : 28
Version Release : 9
Read IMEI... OK
IMEI 1: 357452106001029
IMEI 2: 357453106001027
Repairing IMEI...
Write IMEI [NVDATA]... OK
Write IMEI [NVRAM]... OK
Write partition "nvdata"... OK
Write partition "nvram"... OK
Old 11-04-2021, 15:16   #72 (permalink)
Member: 2993836
Thanks Meter: 12
Thumbs up Tecno KC2 FRP Remove Done by Pandora Box
Tecno KC2
Log
Host Power On... OK
Device found at COM10 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID =  0xD80C7742, 0x6AEEC9DF, 0xA1EB6EF7, 0x08AC998F
Get SOC ID... [14C248926F0A0C36D1E9DF3612D5C9605B6CDAEA58ED579156404B7306CA45F5]
EMMC_ID: 0x90014A68423861503E02729CE5B15769
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
   EMMC_ID   : 0x90014A68423861503E02729CE5B15769
RAM INFO:
   EXT_RAM : 0x00C0000000 (3.00Gb)
Product Brand        : TECNO
Product Manufacturer : TECNO MOBILE LIMITED
Product Model        : TECNO KC2
Product Name         : H6113
Product Device       : TECNO-KC2
Board Platform       : MT6761
Product Board        : TECNO-KC2
Build Date           : Tue Sep 22 20:33:16 CST 2020
Display ID           : KC2-H6113AI-P-200922V280
Security Patch       : 2020-09-05
Version SDK          : 28
Version Release      : 9
Backup saved to PND_LINK_0072 "file:///C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Mediatek_MT6761/FRP_BACKUP_(2021-11-4_19-8-36)/"directory
Erase FRP done!
Br,
GSM City
Old 11-08-2021, 15:31   #73 (permalink)
Member: 66497
Thanks Meter: 80
Aligator S6000Duo
Selected model: Motorola UNKNOWN
Host Power On... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1633 (Android),usb2ser.sys,3.0.1504.0]
Device found at COM13 [PRELOADER]
Open port... OK
Get HW code from device... 6580
Detect chip [MT6580]
Library Version [1]
Init BROM... OK
Force Charge... OK
Get BROM version... OK
Search DA... OK [5]
Check bootloader answer... OK
Wait for hw detection... OK
Wait DA version... v4.2
Send BROM version... OK
Send storage config... OK
SyncBmtInfoWithDA... OK
Set params... OK
Sync with DA... OK
Wait for DA H/W detection... OK
EMMC INFO:
EMMC_ID : 0x700100544232383136200CE9F7846619
EMMC_USER : 0x03A8000000 (14,63Gb)
RAM INFO:
Product Brand : ALIGATOR
Product Manufacturer : magcomm
Product Model : ALIGATOR S6000
Product Name : ALIGATOR_S6000
Product Device : ALIGATOR_S6000
Board Platform : MTK6580_8.1
Product Board : k80hd_bsp_fwv_512m
Build ID : O11019
Build Date : 20190109_1507
Display ID : O11019 release-keys
Security Patch : 2018-12-05
Version SDK : 27
Version Release : 8.1.0
Read partition frp... OK
Backup saved to PND_LINK_0057 "file:///G:/Pandora/BackupMTK/Motorola_UNKNOWN/FRP_BACKUP_(2021-11-8_15-25-26)/"directory
Format EMMC_USER partition... OK
Erase FRP done!
Old 11-24-2021, 18:07   #74 (permalink)
Member: 66497
Thanks Meter: 80
Selected model: Huawei DRA-LX9 (Y5p (2020))
Software version: 2.7
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0xD3402425, 0x3917BEF2, 0x92E9004B, 0x5631B885
Get SOC ID... [475BF9074489A119BAE02FE58053D5C29CD72C0F04945D0F08 2930397815E776]
EMMC_ID: 0x150100515836334142034F2196C86761
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x150100515836334142034F2196C86761
RAM INFO:
Product Brand : Huawei
Product Manufacturer : unknown
Product Model : a53_a53_32
Product Name : a53_a53_32
Product Device : a53_a53_32
Build Date : Fri Sep 3 12:36:37 CST 2021
Display ID : System 10.1.0.68(2P0Q)
Security Patch : 2020-10-01
Version SDK : 29
Firmware Version : eng.root.20210903.123717
Backup saved to PND_LINK_0066 "file:///G:/Pandora/BackupMTK/Huawei_DRA-LX9%20(Y5p%20(2020))/FRP_BACKUP_(2021-11-24_18-6-39)/"directory
Erase FRP done!
The Following User Says Thank You to Svito For This Useful Post:
Old 12-01-2021, 18:15   #75 (permalink)
Member: 229048
Thanks Meter: 10
succesfull frp reset MOTOROLA e7 XT2095-2
Host Power On... OK
Device found at COM110 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x4F2D0BC9, 0x38E72B66, 0xE698A529, 0xD2098FAB
Get SOC ID... [6FA1600931B6982C9C9DDE268E369E5F449D5F6A261C4235D2 5BDE52D5EFF59C]
EMMC_ID: 0x1501003458364B4D4203DDBACA72A7EF
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x1501003458364B4D4203DDBACA72A7EF
RAM INFO:
Read product info... error(20)
Backup saved to PND_LINK_005B "file:///C:/gsm/Pandora/Backup/MTK/Motorola_UNKNOWN/FRP_BACKUP_(2021-12-1_19-9-44)/"directory
Erase FRP done!
The Following User Says Thank You to Statums For This Useful Post:
Page generated in 0.16606 seconds with 9 queries
