Post here successfully job with Pandora's Post here successfully job only. |
I am going to buy it, the z3x equipment, I succeed with everything, I will update soon |
go ahead we need to see all the miracles so we can buy too |
Redmi Note 9 Unlock bootloader done with Pandora Box Redmi Note 9 Unlock bootloader done with pandora Box https://i.ibb.co/34H5M19/redmi-note-9-read-info.png https://i.ibb.co/smyNx1W/redmi-note-9-bootunlock.png |
Redmi Note 9 Write Flash done with Pandora Box |
yeah let's see i will spent 200, If you do something that no one has ever done before |
Revvl 4 TMB 5007Z Revvl unlock done Selected model: TMB 5007Z (Revvl 4) Operation: Unlock network Software version: 1.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM37 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x50ACBA38, 0x87FF9E47, 0xB38CF83E, 0xB4EE72EC Get Chip ID... [MT6761] Get SOC ID... [D7CE7CE4806DFDB36EDD76BA489D02318A2B27136ED931C4E1 C4D8362D981AFD] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [30] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x1501003458364B4D42030703DC8CA781 Load EMI config from database [DB VER: 47 DB DATE: 04-02-2021] OK [1] Trying EMI [44724C4B, 7CB86554, 9C47C7D7, C26ECB0F, CCFE52E9, 2E865ED1, 4C76F2A3] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x1501003458364B4D42030703DC8CA781 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Read security files... OK Read lock info... OK Write lock info... OK Write security partition to phone... OK Network Unlock done! |
Huawei Amn-LXX (y5 2019) imei Repair With Pandora’s Box Huawei Amn-LXX (y5 2019) imei Repair With Pandora’s Box |
zte blade v smart READ CODES ,imei and read flash done Selected model: ZTE UNKNOWN Operation: Read Flash Info Software version: 1.7 https://i.ibb.co/T1g5vgf/zte.jpg copiar imagen de pagina web Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3257773D, 0xBC2D560F, 0x5DE19E90, 0xBB581B26 Get Chip ID... [MT6771] Get SOC ID... [B35CE499B8B04002C8D17B2A334E9EC8FCB6221C4CB572D81D ABB16F75B3CCE7] Get sec config... OK [000000E1] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... timeout Selected model: ZTE UNKNOWN Operation: Read Flash Info Software version: 1.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E1] Active sec flags: [SBC] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3257773D, 0xBC2D560F, 0x5DE19E90, 0xBB581B26 Get Chip ID... [MT6771] Get SOC ID... [B35CE499B8B04002C8D17B2A334E9EC8FCB6221C4CB572D81D ABB16F75B3CCE7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x45010044413431323801ABD76440C677 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [2] Trying EMI [08EDF5FC, 6A5BF28C] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x45010044413431323801ABD76440C677 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Read Flash Info done! Selected model: ZTE UNKNOWN Operation: Read PTT Software version: 1.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E1] Active sec flags: [SBC] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3257773D, 0xBC2D560F, 0x5DE19E90, 0xBB581B26 Get Chip ID... [MT6771] Get SOC ID... [B35CE499B8B04002C8D17B2A334E9EC8FCB6221C4CB572D81D ABB16F75B3CCE7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x45010044413431323801ABD76440C677 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [2] Trying EMI [08EDF5FC, 6A5BF28C] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x45010044413431323801ABD76440C677 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "preloader"... OK Read partition "pgpt"... OK Read partition "boot_para"... OK Read partition "recovery"... OK Read partition "para"... OK Read partition "expdb"... OK Read partition "ztecfg"... OK Read partition "frp"... OK Read partition "nvcfg"... OK Read partition "nvdata"... OK Read partition "metadata"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "seccfg"... OK Read partition "persist"... OK Read partition "sec1"... OK Read partition "proinfo"... OK Read partition "md1img"... OK Read partition "md1dsp"... OK Read partition "spmfw"... OK Read partition "scp1"... OK Read partition "scp2"... OK Read partition "sspm_1"... OK Read partition "sspm_2"... OK Read partition "cam_vpu1"... OK Read partition "cam_vpu2"... OK Read partition "cam_vpu3"... OK Read partition "gz1"... OK Read partition "gz2"... OK Read partition "nvram"... OK Read partition "lk"... OK Read partition "lk2"... OK Read partition "boot"... OK Read partition "logo"... OK Read partition "dtbo"... OK Read partition "tee1"... OK Read partition "tee2"... OK Read partition "vendor"... OK Read partition "system"... OK Read partition "cache"... OK Read partition "otp"... OK Read partition "flashinfo"... OK Read partition "sgpt"... OK Dumping Partitions done! Selected model: ZTE UNKNOWN Operation: Read Region Software version: 1.7 Select region for dump! Selected model: ZTE UNKNOWN Operation: Read OTP Software version: 1.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E1] Active sec flags: [SBC] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3257773D, 0xBC2D560F, 0x5DE19E90, 0xBB581B26 Get Chip ID... [MT6771] Get SOC ID... [B35CE499B8B04002C8D17B2A334E9EC8FCB6221C4CB572D81D ABB16F75B3CCE7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x45010044413431323801ABD76440C677 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [2] Trying EMI [08EDF5FC, 6A5BF28C] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x45010044413431323801ABD76440C677 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check OTP status... [STATUS_OTP_UNLOCKED] Read OTP... OK Reading OTP done! Selected model: ZTE UNKNOWN Operation: Read Codes Software version: 1.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E1] Active sec flags: [SBC] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3257773D, 0xBC2D560F, 0x5DE19E90, 0xBB581B26 Get Chip ID... [MT6771] Get SOC ID... [B35CE499B8B04002C8D17B2A334E9EC8FCB6221C4CB572D81D ABB16F75B3CCE7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x45010044413431323801ABD76440C677 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [2] Trying EMI [08EDF5FC, 6A5BF28C] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x45010044413431323801ABD76440C677 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Read security files... OK Read lock info... OK N Code : 12345678 NS Code : 00000000 SP Code : 781234?? C Code : 00000000 SIM Code : 2222???? NS_SP Code: 00000000 SIM_C Code: 44?????? Read Codes done! Selected model: ZTE UNKNOWN Operation: Read IMEI Info Software version: 1.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E1] Active sec flags: [SBC] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3257773D, 0xBC2D560F, 0x5DE19E90, 0xBB581B26 Get Chip ID... [MT6771] Get SOC ID... [B35CE499B8B04002C8D17B2A334E9EC8FCB6221C4CB572D81D ABB16F75B3CCE7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x45010044413431323801ABD76440C677 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [2] Trying EMI [08EDF5FC, 6A5BF28C] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x45010044413431323801ABD76440C677 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "nvram"... OK Read NVRAM files... OK Read IMEI... OK IMEI: XXXXXXXX2255953 Reading IMEI done! Selected model: ZTE UNKNOWN Operation: Repair Software version: 1.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E1] Active sec flags: [SBC] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3257773D, 0xBC2D560F, 0x5DE19E90, 0xBB581B26 Get Chip ID... [MT6771] Get SOC ID... [B35CE499B8B04002C8D17B2A334E9EC8FCB6221C4CB572D81D ABB16F75B3CCE7] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x45010044413431323801ABD76440C677 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [2] Trying EMI [08EDF5FC, 6A5BF28C] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x45010044413431323801ABD76440C677 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "nvdata"... OK Read partition "nvram"... OK Read NVRAM files... OK Read IMEI... OK Read NVDATA files... OK Read IMEI... OK IMEI: XXXXXXXX2255953 Set new IMEI to: IMEI: XXXXXXXX9021697 Write IMEI... OK Format EMMC_USER partition( 0x05708000..0x09707FFF )... OK Repair Security done! |
Alcatel 5080A (Shine Lite) read flash , imei done Selected model: Alcatel 5080A (Shine Lite) Operation: Read Flash Info Software version: 1.7 https://i.ibb.co/n8wNqxk/shine.jpg copiar imagen de pagina web Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0335 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Load DownloadAgent... OK ME_ID = 0xC209C2CD, 0xCD596B42, 0xC71B0813, 0x9E786C35 Get sec config... OK [00000007] Active sec flags: [ SBC SLA DAA] Get BROM version... OK AUTH file not found! Selected model: Alcatel 5080A (Shine Lite) Operation: Read Flash Info Software version: 1.7 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... timeout(S_BROM_CMD_STARTCMD_TIMEOUT) Selected model: Alcatel 5080A (Shine Lite) Operation: Read Flash Info Software version: 1.7 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0335 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Load DownloadAgent... OK ME_ID = 0xC209C2CD, 0xCD596B42, 0xC71B0813, 0x9E786C35 Get sec config... OK [00000007] Active sec flags: [ SBC SLA DAA] Get BROM version... OK AUTH file not found! Selected model: Alcatel 5080A (Shine Lite) Operation: Read Flash Info Software version: 1.7 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... error(4) Selected model: Alcatel 5080A (Shine Lite) Operation: Read Flash Info Software version: 1.7 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... error(4) Selected model: Alcatel 5080A (Shine Lite) Operation: Read Flash Info Software version: 1.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... FULL Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0335 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Get sec config... OK [00000007] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0335 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Load DownloadAgent... OK ME_ID = 0xC209C2CD, 0xCD596B42, 0xC71B0813, 0x9E786C35 Get sec config... OK [00000000] Get BROM version... OK Search DA... OK [11] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Check bootloader answer... OK Wait for answer from bootloader... OK Wait for hw detection... OK Wait DA version... v4.2 Send BROM version... OK Send storage config... OK SyncBmtInfoWithDA... OK Set params... OK Read flash info... OK EMMC_ID: 0x150100514531334D420D5902B282A0D3 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [9] Trying EMI [FCD13E57, 49CE1F40, 49120D13, 5DCFFA1A, DCF716DA, BBFE481A, ADB0E084, C3F7DB20, CC85EC35] Init DRAM... OK Enable DRAM... OK Sync with DA... OK Wait for DA H/W detection... OK EMMC INFO: EMMC_ID : 0x150100514531334D420D5902B28224D3 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x03A3E00000 (14.56Gb) RAM INFO: INT_SRAM: 0x0000020000 (128.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Read Flash Info done! Selected model: Alcatel 5080A (Shine Lite) Operation: Read Flash Info Software version: 1.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... FULL Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0335 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Get sec config... OK [00000007] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0335 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Load DownloadAgent... OK ME_ID = 0xC209C2CD, 0xCD596B42, 0xC71B0813, 0x9E786C35 Get sec config... OK [00000000] Get BROM version... OK Search DA... OK [11] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Check bootloader answer... OK Wait for answer from bootloader... OK Wait for hw detection... OK Wait DA version... v4.2 Send BROM version... OK Send storage config... OK SyncBmtInfoWithDA... OK Set params... OK Read flash info... OK EMMC_ID: 0x150100514531334D420D5902B282A0D3 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [9] Trying EMI [FCD13E57, 49CE1F40, 49120D13, 5DCFFA1A, DCF716DA, BBFE481A, ADB0E084, C3F7DB20, CC85EC35] Init DRAM... OK Enable DRAM... OK Sync with DA... OK Wait for DA H/W detection... OK EMMC INFO: EMMC_ID : 0x150100514531334D420D5902B28224D3 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x03A3E00000 (14.56Gb) RAM INFO: INT_SRAM: 0x0000020000 (128.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Read Flash Info done! Selected model: Alcatel 5080A (Shine Lite) Operation: Read PTT Software version: 1.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... FULL Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0335 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Get sec config... OK [00000007] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0335 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Load DownloadAgent... OK ME_ID = 0xC209C2CD, 0xCD596B42, 0xC71B0813, 0x9E786C35 Get sec config... OK [00000000] Get BROM version... OK Search DA... OK [11] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Check bootloader answer... OK Wait for answer from bootloader... OK Wait for hw detection... OK Wait DA version... v4.2 Send BROM version... OK Send storage config... OK SyncBmtInfoWithDA... OK Set params... OK Read flash info... OK EMMC_ID: 0x150100514531334D420D5902B282A0D3 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [9] Trying EMI [FCD13E57, 49CE1F40, 49120D13, 5DCFFA1A, DCF716DA, BBFE481A, ADB0E084, C3F7DB20, CC85EC35] Init DRAM... OK Enable DRAM... OK Sync with DA... OK Wait for DA H/W detection... OK EMMC INFO: EMMC_ID : 0x150100514531334D420D5902B28224D3 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x03A3E00000 (14.56Gb) RAM INFO: INT_SRAM: 0x0000020000 (128.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_FULL_SPEED Switching to USB high speed... OK Wait for device... OK High Speed USB detected at COM10 Open port... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition preloader... OK Read partition pgpt... OK Read partition proinfo... OK Read partition nvram... OK Read partition protect1... OK Read partition protect2... OK Read partition tctpersist... OK Read partition simlock... OK Read partition para... OK Read partition lk... OK Read partition boot... OK Read partition recovery... OK Read partition logo... OK Read partition expdb... OK Read partition seccfg... OK Read partition oemkeystore... OK Read partition secro... OK Read partition keystore... OK Read partition tee1... OK Read partition tee2... OK Read partition persist... OK Read partition efuse... OK Read partition frp... OK Read partition nvdata... OK Read partition metadata... OK Read partition system... OK Read partition cache... OK Read partition otp... OK Read partition flashinfo... OK Read partition sgpt... OK Dumping Partitions done! Selected model: Alcatel 5080A (Shine Lite) Operation: Repair Software version: 1.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... FULL Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0335 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Get sec config... OK [00000007] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0335 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Load DownloadAgent... OK ME_ID = 0xC209C2CD, 0xCD596B42, 0xC71B0813, 0x9E786C35 Get sec config... OK [00000000] Get BROM version... OK Search DA... OK [11] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Check bootloader answer... OK Wait for answer from bootloader... OK Wait for hw detection... OK Wait DA version... v4.2 Send BROM version... OK Send storage config... OK SyncBmtInfoWithDA... OK Set params... OK Read flash info... OK EMMC_ID: 0x150100514531334D420D5902B282A0D3 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [9] Trying EMI [FCD13E57, 49CE1F40, 49120D13, 5DCFFA1A, DCF716DA, BBFE481A, ADB0E084, C3F7DB20, CC85EC35] Init DRAM... OK Enable DRAM... OK Sync with DA... OK Wait for DA H/W detection... OK EMMC INFO: EMMC_ID : 0x150100514531334D420D5902B28224D3 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x03A3E00000 (14.56Gb) RAM INFO: INT_SRAM: 0x0000020000 (128.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_FULL_SPEED Switching to USB high speed... OK Wait for device... OK High Speed USB detected at COM10 Open port... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Get OTP size... OK [0x00800000] Read OTP... OK IMEI: xxxxxxxx1523764 Set new IMEI to: IMEI: xxxxxxxx7504164 Check OTP status... [S_DA_OTP_LOCKED] Write OTP... OK Repair Security done! |
VIVO Y17 Read info , Write Firmware , Erase FRP By Pandora Box https://www.img.in.th/images/d04d272...b50eeb1780.png Selected model: Vivo UNKNOWN Operation: Read Flash Info Software version: 1.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM43 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x2407BC92, 0xD470517C, 0x2E9BC903, 0x903C4AB6 Get Chip ID... [MT6765] Get SOC ID... [2571ED125253BFBAD2835CD78409DE5FA95146C172F5CF4E3D 2FAE6A6DB92544] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [29] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100444836444D420526E76A27B529 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [1] Trying EMI [F6969C3D] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100444836444D420526E76A27B529 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Read Flash Info done! https://www.img.in.th/images/e2cd868...c1fba46399.png Selected model: Vivo UNKNOWN Operation: Flash (Download only) Software version: 1.7 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM43 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x2407BC92, 0xD470517C, 0x2E9BC903, 0x903C4AB6 Get Chip ID... [MT6765] Get SOC ID... [2571ED125253BFBAD2835CD78409DE5FA95146C172F5CF4E3D 2FAE6A6DB92544] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [29] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100444836444D420526E76A27B529 Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100444836444D420526E76A27B529 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Check partition table layout changed... OK Read major partition table... OK Check major partition table layout changed... OK Download "preloader"... OK Download "recovery"... OK Download "survival"... OK Download "cust"... OK Download "efuse"... OK Download "md1img"... OK Download "spmfw"... OK Download "scp1"... OK Download "scp2"... OK Download "sspm_1"... OK Download "sspm_2"... OK Download "lk"... OK Download "lk2"... OK Download "boot"... OK Download "logo"... OK Download "dtbo"... OK Download "tee1"... OK Download "tee2"... OK Download "vendor"... OK Download "system"... OK Download "vbmeta"... OK Download "cache"... OK Download "userdata"... OK Flashing done! https://www.img.in.th/images/0ac344b...02cf2dc27a.png Selected model: Vivo UNKNOWN Operation: Erase FRP Software version: 1.7 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM43 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x2407BC92, 0xD470517C, 0x2E9BC903, 0x903C4AB6 Get Chip ID... [MT6765] Get SOC ID... [2571ED125253BFBAD2835CD78409DE5FA95146C172F5CF4E3D 2FAE6A6DB92544] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [29] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100444836444D420526E76A27B529 Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100444836444D420526E76A27B529 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "frp"... OK Format EMMC_USER partition( 0x05588000..0x05687FFF )... OK Erase FRP done! |
OPPO A31 CPH2015 Read info , Backup RPMB |
