Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 06-15-2021, 12:16   #31 (permalink)
-=MR_Gsm=-'s Avatar
Member: 762055
Sonork: -=664053=-
Thanks Meter: 763
Format Flash
Selected model: Mediatek Mediatek
Operation: Format Flash
Software version: 1.14
This procedure will erase all flash and can damage your device.
Make sure that you have a backup created. Continue? YES
Host Power Off... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Wait for device... OK
Read usbhost speed... FULL
Read Device Descriptor...
Get VID/PID...0E8D/0003
Send start cmd... OK
Get HW code from device... 6580
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6580]
Get sec config... OK [00000000]
Disconnect virtual port... OK
Connect Type-C to HUB... OK
Wait for device connecting... OK
Device found at COM3 [BROM]
Open port... OK
Library Version [1]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Load DownloadAgent... OK
ME_ID = 0xD465D7B5, 0x81F0549B, 0xAD170F3E, 0x0D8F767F
Get BROM version... OK
Search DA... OK [11]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Check bootloader answer... OK
Wait for answer from bootloader... OK
Wait for hw detection... OK
Wait DA version... v4.2
Send BROM version... OK
Send storage config... OK
SyncBmtInfoWithDA... OK
Set params... OK
Read flash info... OK
EMMC_ID: 0x504E01FE35394A319E05124C73323B00
Load EMI config from database [DB VER: 124 DB DATE: 06-13-2021] OK [2]
Trying EMI [9A66E559, 4A960ED9]
Init DRAM... OK
Enable DRAM... OK
Sync with DA... OK
Wait for DA H/W detection... OK
EMMC INFO:
EMMC_ID : 0xFE014E50314A39354C12059E003B3273
EMMC_BOOT1: 0x0000200000 (2,00Mb)
EMMC_BOOT2: 0x0000200000 (2,00Mb)
EMMC_RPMB : 0x0000200000 (2,00Mb)
EMMC_USER : 0x01D3000000 (7,30Gb)
RAM INFO:
INT_SRAM: 0x0000020000 (128,00Kb)
EXT_RAM : 0x0040000000 (1,00Gb)
Check USB status... USB_FULL_SPEED
Switching to USB high speed... OK
High Speed USB detected at COM24
Open port... OK
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Read partition preloader... OK
Read partition pgpt... OK
Read partition proinfo... OK
Read partition nvram... OK
Read partition protect1... OK
Read partition protect2... OK
Read partition nvdata... OK
Read partition oemkeystore... OK
Read partition flashinfo... OK
Create autoformat settings... OK
Format EMMC_BOOT_1 partition... OK
Format EMMC_BOOT_2 partition... OK
Format EMMC_USER partition... OK
Format done!
BR,
-=MR_Gsm=-
Old 06-17-2021, 11:20   #32 (permalink)
Member: 66497
Thanks Meter: 74
Motorola XT2016-1
Operation: Unlock bootloader
Parse scatter file... OK
Load Rom Images... OK
Host Power On... OK
Read usbhost speed... HIGH
Get HW code from device... 0788
Detect chip [MT6771]
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Advanced Bypass Security... OK
Device found at COM6 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0x26774D08, 0xF3EDD8DC, 0xDFC807D4, 0x13B027EA
Get Chip ID... [MT6771]
Get SOC ID... [27445B8177218F2A9DE8EBA06F84D2DE3A76E81A855D5F768F 09596ACEDC74A1]
Get sec config... OK [000000E0]
Search DA... OK [20]
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x13014E53304A394B381011CA6DEB76D9
Load EMI config from preloader... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x13014E53304A394B381011CA6DEB76D9
EMMC_BOOT1: 0x0000400000 (4,00Mb)
EMMC_BOOT2: 0x0000400000 (4,00Mb)
EMMC_RPMB : 0x0001000000 (16,00Mb)
EMMC_USER : 0x0E8F800000 (58,24Gb)
RAM INFO:
INT_SRAM: 0x0000039000 (228,00Kb)
EXT_RAM : 0x0100000000 (4,00Gb)
Get scatter info... OK
Read security partition from phone... OK
Decrypt security data... OK
Encrypt security data... OK
Write security partition to phone... OK
Unlock bootloader done!
Old 06-17-2021, 13:47   #33 (permalink)
Member: 66497
Thanks Meter: 74
Operation: Read PTT
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Read partition "preloader"... OK
Read partition "pgpt"... OK
Read partition "boot_para"... OK
Read partition "para"... OK
Read partition "expdb"... OK
Read partition "frp"... OK
Read partition "cid"... OK
Read partition "logs"... OK
Read partition "utags"... OK
Read partition "utagsBackup"... OK
Read partition "carrier"... OK
Read partition "pad1"... OK
Read partition "nvcfg"... OK
Read partition "nvdata"... OK
Read partition "metadata"... OK
Read partition "protect1"... OK
Read partition "protect2"... OK
Read partition "seccfg"... OK
Read partition "persist"... OK
Read partition "prodpersist"... OK
Read partition "sec1"... OK
Read partition "proinfo"... OK
Read partition "nvram"... OK
Read partition "efuse"... OK
Read partition "pad2"... OK
Read partition "hw"... OK
Read partition "sp"... OK
Read partition "kpan"... OK
Read partition "vbmeta_a"... OK
Read partition "md1img_a"... OK
Read partition "spmfw_a"... OK
Read partition "scp_a"... OK
Read partition "sspm_a"... OK
Read partition "cam_vpu1_a"... OK
Read partition "cam_vpu2_a"... OK
Read partition "cam_vpu3_a"... OK
Read partition "logo_a"... OK
Read partition "lk_a"... OK
Read partition "boot_a"... OK
Read partition "dtb_a"... OK
Read partition "dtbo_a"... OK
Read partition "tee_a"... OK
Read partition "oem_a"... OK
Read partition "vendor_a"... OK
Read partition "system_a"... OK
Read partition "vbmeta_b"... OK
Read partition "md1img_b"... OK
Read partition "spmfw_b"... OK
Read partition "scp_b"... OK
Read partition "sspm_b"... OK
Read partition "cam_vpu1_b"... OK
Read partition "cam_vpu2_b"... OK
Read partition "cam_vpu3_b"... OK
Read partition "logo_b"... OK
Read partition "lk_b"... OK
Read partition "boot_b"... OK
Read partition "dtb_b"... OK
Read partition "dtbo_b"... OK
Read partition "tee_b"... OK
Read partition "oem_b"... OK
Read partition "vendor_b"... OK
Read partition "system_b"... OK
Read partition "userdata"... OK
Read partition "otp"... OK
Read partition "flashinfo"... OK
Read partition "sgpt"... OK
Dumping Partitions done!
Old 06-22-2021, 18:10   #34 (permalink)
Member: 66497
Thanks Meter: 74
Huawei DRA-L21
The Following User Says Thank You to Svito For This Useful Post:
Old 06-24-2021, 05:54   #35 (permalink)
Member: 1461041
Thanks Meter: 56
Xiaomi Redmi 6A
Test Redmi 6A BY_Pandora Tool.
http://www.youtube.com/watch?v=whu-i9d0QY4
The Following User Says Thank You to lpservice For This Useful Post:
Old 06-28-2021, 10:51   #36 (permalink)
-=MR_Gsm=-'s Avatar
Member: 762055
Sonork: -=664053=-
Thanks Meter: 763
Repair Security done!
Operation: Repair
Software version: 1.15
Host Power On... OK
Get HW code from device... 0337
Detect chip [MT6735]
Device found at COM5 [BROM]
Open port... OK
Library Version [1]
Init BROM... OK
Force Charge... OK
ME_ID = 0xECEBCBC1, 0x88CB938F, 0x236C24B2, 0x372A0BDD
Search DA... OK [10]
StorageType matched!
Set params... OK
EMMC_ID: 0x90014A48414732650507491181264987
Init DRAM... OK
Enable DRAM... OK
Sync with DA... OK
EMMC INFO:
EMMC_ID : 0x90014A4841473265050749118126B287
EMMC_RPMB : 0x0000400000 (4,00Mb)
EMMC_USER : 0x03AB800000 (14,68Gb)
RAM INFO:
EXT_RAM : 0x00C0000000 (3,00Gb)
High Speed USB detected at COM23
Open port... OK
Read NVDATA files... OK
Read IMEI... OK
IMEI 1: 35504807275+++
IMEI 2: 3550480728++++
Set new IMEI to:
IMEI 1: 3550480727++++
IMEI 2: 3550480727++++
Write IMEI... OK
BR,
-=MR_Gsm=-
Old 07-02-2021, 17:04   #37 (permalink)
mediaextensions's Avatar
Member: 1123079
Sonork: 100.1586814
Thanks Meter: 436
Thumbs up TMB 5007Z (Revvl 4) Unlock Done
Selected model: TMB 5007Z (Revvl 4)
Operation: Unlock network
Software version: 2.0
Host Power On... OK
Get HW code from device... 0717
HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00
Detect chip [MT6761]
Get sec config... OK [000000E7]
Active sec flags: [SBC SLA DAA]
Device found at COM22 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0xA7EB6693, 0xC0B81651, 0x5A22A9AB, 0x8E91DEC0
Get Chip ID... [MT6761]
Get SOC ID... [51C8A336E83ED3F5C08967A9AEF40BDE8D92E4E1AD96C51FD7 164BCE49B074ED]
Search DA... OK [24]
EMMC_ID: 0x1501003458364B4D42031C0BCE60B7BB
Load EMI config from database [DB VER: 146 DB DATE: 06-30-2021] OK [1]
Trying EMI [44724C4B, 7CB86554, 9C47C7D7, C26ECB0F, CCFE52E9, 2E865ED1, 4C76F2A3]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x1501003458364B4D42031C0BCE60B7BB
EMMC_BOOT1: 0x0000400000 (4.00Mb)
EMMC_BOOT2: 0x0000400000 (4.00Mb)
EMMC_RPMB : 0x0000400000 (4.00Mb)
EMMC_USER : 0x0747C00000 (29.12Gb)
RAM INFO:
INT_SRAM: 0x0000039000 (228.00Kb)
EXT_RAM : 0x0080000000 (2.00Gb)
Read security files... OK
Read lock info... OK
Write lock info... OK
Network Unlock done!
Best Regards,
Mediaextensins.
Old 07-10-2021, 16:26   #38 (permalink)
-=MR_Gsm=-'s Avatar
Member: 762055
Sonork: -=664053=-
Thanks Meter: 763
Realme RMX2155 (Realme 7)
Operation: Flash (Upgrade)
Selected model: Realme RMX2155 (Realme 7)
Host Power On... OK
Get HW code from device... 0813
Detect chip [MT6785]
Device found at COM9 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x307775EF, 0xBD987249, 0x06A79ED4, 0x9FB23CBF
Get Chip ID... [MT6785]
Get SOC ID... [16486B8D5EB4DCF19D68E6F696ACBDEE397B9438B74125DBDA 527F9896E0CA99]
Search DA... OK [29]
UFS CID (FW VER): H9HQ53AECMMDAR (0004)
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_CID : H9HQ53AECMMDAR
UFS_FWVER : 0004
BLOCK_SIZE: 0x0000001000 (4,00Kb)
UFS_LU0 : 0x0000400000 (4,00Mb)
UFS_LU1 : 0x0000400000 (4,00Mb)
UFS_LU2 : 0x0EE5800000 (59,59Gb)
RAM INFO:
INT_SRAM: 0x0000080000 (512,00Kb)
EXT_RAM : 0x0180000000 (6,00Gb)
Prepare list for upgrade... OK
Check upgrade list... OK
Prepare format list... OK
Prepare final partition list... OK
Read partition "opporeserve1"... OK
Read partition "opporeserve2"... OK
Read partition "opporeserve3"... OK
Read partition "oppo_custom"... OK
Verify checksum... OK
Format UFS_LU2 partition( 0x00008000..0x02107FFF )... OK
Format UFS_LU2 partition( 0x0AA08000..0x0D707FFF )... OK
Format UFS_LU2 partition( 0x0F708000..0x16DA1FFF )... OK
Format UFS_LU2 partition( 0x1B000000..0xEE17F7FFF )... OK
Verify scatter file... OK
Do NAND BMT remark... OK
Setup download info... OK
Get partition table catagory... OK [GPT]
Read mirror partition table... OK
Check partition table layout changed... OK
Generate mirror partition table... OK
Download mirror partition table... OK
Read major partition table... OK
Check major partition table layout changed... OK
Generate major partition table... OK
Download major partition table... OK
Download "preloader"... OK
Download "opporeserve2"... OK
Download "vbmeta"... OK
Download "vbmeta_system"... OK
Download "vbmeta_vendor"... OK
Download "md1img"... OK
Download "special_preload"... OK
Download "my_custom"... OK
Download "spmfw"... OK
Download "audio_dsp"... OK
Download "scp1"... OK
Download "scp2"... OK
Download "sspm_1"... OK
Download "sspm_2"... OK
Download "cam_vpu1"... OK
Download "cam_vpu2"... OK
Download "cam_vpu3"... OK
Download "cdt_engineering"... OK
Download "lk"... OK
Download "lk2"... OK
Download "boot"... OK
Download "logo"... OK
Download "dtbo"... OK
Download "recovery"... OK
Download "tee1"... OK
Download "tee2"... OK
Download "super"... OK
Download "cache"... OK
Download "userdata"... OK
Write file "opporeserve1.bin"... OK
Write file "opporeserve2.bin"... OK
Write file "opporeserve3.bin"... OK
Write file "oppo_custom.bin"... OK
Write file "nvcfg.bin"... OK
Write file "persist.bin"... OK
Write file "protect1.bin"... OK
Write file "protect2.bin"... OK
Write file "proinfo.bin"... OK
Write file "nvram.bin"... OK
Flashing done!
BR,
-=MR_Gsm=-
The Following User Says Thank You to -=MR_Gsm=- For This Useful Post:
Old 07-12-2021, 11:51   #39 (permalink)
-=MR_Gsm=-'s Avatar
Member: 762055
Sonork: -=664053=-
Thanks Meter: 763
Software version: 2.1
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_FWVER : 0004
RAM INFO:
Operation: Relock bootloader
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_FWVER : 0004
RAM INFO:
Relock bootloader done!
BR,
-=MR_Gsm=-
Old 07-17-2021, 13:07   #40 (permalink)
validity's Avatar
Member: 1708749
Thanks Meter: 14
Hello please want to know if pandora can remove mdm in samsung M013F
MESSAGE ON THE SCREEN
Old 07-17-2021, 13:08   #41 (permalink)
validity's Avatar
Member: 1708749
Thanks Meter: 14
Is it an offline box or online consuming credits
Old 07-18-2021, 16:18   #42 (permalink)
Member: 66497
Thanks Meter: 74
Selected model: Nokia TA-1206 (Nokia 2.3)
Operation: Erase FRP
Software version: 2.2
Host Power On... OK
Wait for device... timeout
Host Power On... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x3208C205, 0x4E172AB0, 0x30659EDD, 0xDEBC2120
Get SOC ID... [5C9F377A7FD1191D2D1148208523FB120AEE5606348C4AB458 E2E07D85EBCDFF]
EMMC_ID: 0x7001005441323833322011A0C334C6CD
Load EMI config from database [DB VER: 164 DB DATE: 07-17-2021] OK [1]
Trying EMI [17FE6D1D]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x7001005441323833322011A0C334C6CD
EMMC_USER : 0x074A000000 (29,16Gb)
RAM INFO:
EXT_RAM : 0x0080000000 (2,00Gb)
Format "frp" partition... OK
Writting FRP data... OK
Erase FRP done!
Old 07-18-2021, 16:18   #43 (permalink)
Member: 66497
Thanks Meter: 74
Operation: Wipe Data
There is a risk of data loss.
This procedure will erase all User Data
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Read partition "oem"... OK
Read partition "elabel"... OK
Format "userdata" partition... OK
Wipe data done!
Old 07-18-2021, 18:59   #44 (permalink)
Member: 1418749
Thanks Meter: 43
Offline box
No credits
No activation
No annual fees
No subscription
Powered by z3x
Old 07-19-2021, 06:47   #45 (permalink)
Member: 2905715
Sonork: 100.1682585
Thanks Meter: 9
Oppo a3s and oppo a5 1901 possable remove user lock?
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.28253 seconds with 7 queries
