Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 01-05-2023, 00:31   #196 (permalink)
Member: 2578528
Thanks Meter: 143
Selected model: Spreadtrum Spreadtrum
Operation: Wipe Partitions
Software version: 4.2
Erasing of partitions can damage your device.
Make sure that you have a backup created. Continue? YES
Work ID: 57821
Waiting for device... OK
Device found at COM13
Port: USB\VID_1782&PID_4D00\5&ABBE63A&0&4
Connecting to device... OK
Selected processor: SC9863A
Load files... OK
Connect preloader 1... OK
Connect preloader 2... OK
Connect loader 1... OK
Connect loader 2... OK
Serial Number: R9QT4067LMZ
Read partitions info... OK
Checking A/B state... OK
Read product info... OK
Product Brand : samsung
Product Manufacturer : samsung
Product Model : SM-A032M
Product Name : a3coreub
Product Device : a3core
Build ID : RP1A.201005.001
Build Date : Tue Aug 30 23:49:48 KST 2022
Display ID : RP1A.201005.001.A032MUBU2AVH4
Security Patch : 2022-07-01
Version SDK : 30
Version Release : 11
Version Codename : REL
Firmware Version : A032MUBU2AVH4
Format partition "persistent"... OK
Done!
https://uploaddeimagens.com.br/imagens/TTGEY-A
Old 01-05-2023, 00:32   #197 (permalink)
Member: 2578528
Thanks Meter: 143
Frp a03 core a032m done
Work ID: 57821
Load files... OK
Version SDK : 30
Done!
Old 01-05-2023, 01:03   #198 (permalink)
Member: 2578528
Thanks Meter: 143
FRP A035M DONE
https://uploaddeimagens.com.br/imagens/DWWYqU4
Old 01-15-2023, 12:03   #199 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
REIPAIR IMEI INFINIX HOT 10 X657B done
Selected model: Infinix X657B (Infinix Hot 10 Lite)
Operation: Read Flash Info
Software version: 3.10
Host Power Off... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Connect phone to BOX in BROM mode
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Send start cmd... OK
Get HW code from device... 0717
Get HW & SW version from device... OK
HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00
Detect chip [MT6761]
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Advanced Bypass Security... OK
Switch virtual port to NONE... OK
Connect Type-C to HUB... OK
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0]
Device found at COM61 [BROM]
Open port... OK
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0x21EBF25C, 0x8A9D8C21, 0x8F6EA275, 0x52320741
Get Chip ID... [MT6761]
Get SOC ID... [C097B074E64FC618DB92F814655CA76C8E7E68908952EDC408 06CB51B2FB9A23]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [5]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0xD60103353841343431109051C42248D5
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0xD60103353841343431109051C42248D5
EMMC_BOOT1: 0x0000400000 (4,00Mb)
EMMC_BOOT2: 0x0000400000 (4,00Mb)
EMMC_RPMB : 0x0000400000 (4,00Mb)
EMMC_USER : 0x0E67800000 (57,62Gb)
RAM INFO:
INT_SRAM: 0x000003A500 (233,25Kb)
EXT_RAM : 0x00C0000000 (3,00Gb)
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Check A/B state... OK
Product Brand : Infinix
Product Manufacturer : INFINIX MOBILITY LIMITED
Product Model : Infinix X657B
Product Name : X657B-OP
Product Device : Infinix-X657B
Product Board : Infinix-X657B
Board Platform : MT6761
Build ID : QP1A.190711.020
Build Date : Wed Aug 25 16:34:49 CST 2021
Display ID : X657B-H6117DFJ-QGo-OP-210825V388
Security Patch : 2021-08-05
Version SDK : 29
Version Release : 10
Firmware Version : DFJ-OP-210825V388
Read Flash Info done!
Operation: Repair
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [5]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Version SDK : 29
Read partition "nvdata"... OK
Read partition "nvram"... OK
Read NVDATA files... OK
Read NVRAM files... OK
Read IMEI... OK
IMEI 1: 354622294450088
IMEI 2: 354622294450096
Repairing IMEI...
IMEI 1: 354245056341939
IMEI 2: 354793056281373
Write IMEI [NVDATA]... OK
Write IMEI [NVRAM]... OK
Write partition "nvdata"... OK
Write partition "nvram"... OK
Repair Security done!
Old 01-25-2023, 11:11   #200 (permalink)
Member: 2927217
Thanks Meter: 13
realme C35 RMX3511 imei repair done
Selected model: Realme RMX3511 (C35)
Operation: Repair
Software version: 4.4
Host Power On... OK
Device found at COM253
Port: USB\VID_1782&PID_4D00\6&D0542F3&0&2
Selected processor: Tiger_T616_64
Load files... OK
Serial Number: 0H52815I37100100
Flash Type: UFS
Checking A/B state... OK [A]
Product Brand        : realme
Product Manufacturer : realme
Product Model        : RMX3511
Product Name         : ums9230_nico_Natv
Product Device       : RE87BAL1
Build Date           : Tue Jul 26 18:24:38 CST 2022
Display ID           : RMX3511PU_11_A.43
Security Patch       : 2022-07-05
Version SDK          : 30
Firmware Version     : 1151
Load NVD... OK
Read IMEI... OK
Current IMEI:
   IMEI 1: 86221xxxxxxxxxx
   IMEI 2: 86221xxxxxxxxxx
Repaired IMEI:
   IMEI 1: 3559xxxxxxxxxxx
   IMEI 2: 3559xxxxxxxxxxx
Check security state... OK [2]
Check patch state... OK
Read patch data... OK
Correct patch... OK
Patch cert... OK
Write IMEI... OK
Save NVD... OK
Done!
Guljee
Old 01-25-2023, 11:52   #201 (permalink)
Remco's Avatar
Member: 334
Thanks Meter: 124
Lenovo TB-J616F FRP done see log,
Selected model: Lenovo Mediatek
Operation: Erase FRP
Host Power On... OK
Connect phone to BOX in BROM/PRELOADER Mode
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1511.0]
Device found at COM9 [BROM]
Open port... OK
Get HW code from device... 0813
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6785]
Library Version [2]
Init BROM... OK
Force Charge... OK
Force switch to BROM... OK
Host Power On... OK
Open port... OK
Active sec flags: []
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0xCA4847EF, 0x298A4D3C, 0x8090AF86, 0xA1E28364
Get Chip ID... [MT6785]
Get SOC ID... [3009D97FC7D87CA3D5B642AB47F16B3D2329BA00838BA08888 9E4EE02185FF5C]
Search DA... OK [12]
Checking preloader answer... OK
UFS CID (FW VER): H9HQ15ACPMBDAR (A002)
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_CID : H9HQ15ACPMBDAR
UFS_FWVER : A002
BLOCK_SIZE: 0x0000001000 (4,00Kb)
UFS_LU0 : 0x0000400000 (4,00Mb)
UFS_LU1 : 0x0000400000 (4,00Mb)
UFS_LU2 : 0x1DCB000000 (119,17Gb)
RAM INFO:
INT_SRAM: 0x0000080000 (512,00Kb)
EXT_RAM : 0x0100000000 (4,00Gb)
Checking USB status... USB_HIGH_SPEED
Product Brand : Lenovo
Product Manufacturer : LENOVO
Product Model : Lenovo TB-J616F
Product Name : TB-J616F
Product Device : TB-J616F
Product Board : p11
Board Platform : mtk
Build ID : RP1A.200720.011
Build Date : Tue Jan 18 07:41:08 CST 2022
Display ID : TB-J616F_S000044_220118_ROW
Security Patch : 2021-12-05
Version SDK : 30
Firmware Version : TB-J616F_S000044_220118_ROW
Read partition "frp"... OK
Backup saved to HYPERLINK C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Lenovo_MT6785/FRP_BACKUP_(2023-1-25_10-59-40)/"directory
Writting FRP data... OK
Erase FRP done!
Old 01-26-2023, 10:15   #202 (permalink)
Member: 2147534
Thanks Meter: 15
REDMI 9A NETWORK UNLOCK MTN LOCK DONE
Selected model: Xiaomi Redmi 9A (Dandelion)
Operation: Unlock network
Work ID: 242678
Connect phone in BROM Mode
Device found at COM142 [BROM]
Open port... OK
Get HW code from device... 0766
Get sec config... OK [000000E7]
Active sec flags: [SBC SLA DAA]
LibUSB installed
Detect chip [MT6765]
Library Version [2]
Init BROM... OK
Force Charge... OK
Open port... OK
LibUSB installed
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x189CDFDD, 0x25BF5F4B, 0x6E87D5A4, 0x7ADA2FFB
Get Chip ID... [MT6765]
Get SOC ID... [395EC70AECFE19E3CD1BDF6064CDF7C6ACE46DAE847C911573 6E2632CF460315]
Search DA... OK [7]
EMMC_ID: 0x450100444134303332012EA1CE45C89F
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: DA4032
EMMC_ID : 0x450100444134303332012EA1CE45C89F
EMMC_BOOT1: 0x0000400000 (4.00Mb)
EMMC_BOOT2: 0x0000400000 (4.00Mb)
EMMC_RPMB : 0x0001000000 (16.00Mb)
EMMC_USER : 0x0747C00000 (29.12Gb)
RAM INFO:
INT_SRAM: 0x000003A000 (232.00Kb)
EXT_RAM : 0x0080000000 (2.00Gb)
Product Brand : Redmi
Product Manufacturer : Xiaomi
Product Model : M2006C3LG
Product Name : dandelion_global
Product Device : dandelion
Product Board : dandelion
Board Platform : MT6765
Build Date : Tue Aug 3 22:42:33 CST 2021
Display ID : QP1A.190711.020
Security Patch : 2021-08-01
Version SDK : 29
Firmware Version : V12.0.1.0.QCDZAMT
Read security partition from phone... OK
Read security files... OK
Read lock info... OK
Unlock... OK [DF1, GB2, UN]
Write lock info... OK
Write security partition to phone... OK
Network Unlock done!
The Following User Says Thank You to Tinadenzy For This Useful Post:
Old 01-28-2023, 08:42   #203 (permalink)
Member: 2945769
Sonork: http://forum.gsmhosting.c
Thanks Meter: 32
Movitel M9110 erase frp and wipe done
Operation: Erase FRP And Wipe
Work ID: 266957
Device found at COM10
Port: USB\VID_1782&PID_4D00\6&1EFC522A&0&2
Selected processor: SC9832E
Load files... OK
Serial Number: M911021082609814
Product Brand : Movitel
Product Manufacturer : Movitel
Product Model : M9110
Product Name : M9110
Product Device : M9110
Build Date : Mon Aug 30 15:58:58 CST 2021
Display ID : Movitel_M9110_V01_20210812
Security Patch : 2021-07-05
Version SDK : 30
Firmware Version : 1628476487 OK
Formatting "userdata" partition... OK
Formatting "cache" partition... OK
Formatting "metadata" partition... OK
Done!
Old 01-30-2023, 07:33   #204 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,382
Selected model: Mediatek Mediatek
Work ID: 285607
Connect phone in BROM/PRELOADER Mode
Device found at COM41 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Open port... OK
LibUSB installed
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0xEDFFCB58, 0x140F355D, 0x26AF2AF2, 0x83B263EA
Get SOC ID... [44AE63248F41BAAA07BCA501ADE8C2457A75BFF95EA8F8A3CA 7D70149430011E]
Search DA... OK [5]
EMMC_ID: 0x15010044503644424202EF30C05EC8E5
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: DP6DBB
EMMC_ID : 0x15010044503644424202EF30C05EC8E5
EMMC_USER : 0x0E8F800000 (58.24Gb)
RAM INFO:
INT_SRAM: 0x000003A500 (233.25Kb)
EXT_RAM : 0x0100000000 (4.00Gb)
Product Model : Infinix X665B
Product Name : TSSI
Product Device : FULL-64
Product Board : Infinix-X665B
Build Date : Mon Nov 14 16:54:12 CST 2022
Display ID : INFINIX-R-64-221114V367
Security Patch : 2022-11-05
Version SDK : 30
Firmware Version : 221114V631
Backup saved to HYPERLINK C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Mediatek_MT6761/FRP_BACKUP_(2023-1-30_12-14-23)/"directory
Erase FRP done!
Old 01-30-2023, 12:29   #205 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,382
Selected model: Tecno KG5k (Tecno Spark 8C)
Operation: Flash
Work ID: 287724
Loading packet file... OK
Init partition data... OK
Init files... OK
Device found at COM63
Port: USB\VID_1782&PID_4D00\6&3B22905B&0&4
Load files... OK
Selected processor: Tiger_T606_64
Load files... OK
Serial Number: 0781631281050410
Flash Type: EMMC
Read product info... error(2)
Executing _BKF_PhaseCheck...
ReadFlashByID... OK
Executing _BKF_ProdNV...
ReadFlashByID... OK
Executing _BKF_NV_LTE...
ReadFlashByID... OK
Executing _REPARTITION_...
ForceRepartitionByID... OK
Executing PhaseCheck...
DownloadByID... OK
Flashing NV_LTE...
ReadFlashByID... OK
DownloadByID... OK
Flashing ProdNV...
DownloadByID... OK
Executing EraseUBOOTLOG...
EraseFlashByID... OK
Flashing VBMETA...
DownloadByID... OK
Flashing VBMETA_SYSTEM...
DownloadByID... OK
Flashing VBMETA_SYSTEM_EXT...
DownloadByID... OK
Flashing VBMETA_VENDOR...
DownloadByID... OK
Flashing VBMETA_PRODUCT...
DownloadByID... OK
Flashing Modem_LTE...
DownloadByID... OK
Flashing Modem_LTE_DELTANV...
DownloadByID... OK
Flashing DSP_LTE_LTE...
DownloadByID... OK
Flashing DSP_LTE_GGE...
DownloadByID... OK
Flashing DSP_LTE_AG...
DownloadByID... OK
Flashing DFS...
DownloadByID... OK
Flashing Modem_GNSS...
DownloadByID... OK
Flashing Modem_WCN...
DownloadByID... OK
Flashing BOOT...
DownloadByID... OK
Flashing DTBO...
DownloadByID... OK
Flashing Super...
DownloadByID... OK
Flashing Cache...
DownloadByID... OK
Executing Tranfs...
Flashing UserData...
DownloadByID... OK
Flashing BootLogo...
DownloadByID... OK
Flashing Fastboot_Logo...
DownloadByID... OK
Flashing Socko...
DownloadByID... OK
Flashing Odmko...
DownloadByID... OK
Executing FLASH_LTE...
Executing EraseMisc...
Executing EraseSysdumpdb...
Flashing Trustos...
DownloadByID... OK
Flashing Teecfg...
DownloadByID... OK
Flashing SML...
DownloadByID... OK
Flashing UBOOTLoader...
DownloadByID... OK
Flashing Persist...
DownloadByID... OK
Flashing Cover...
DownloadByID... OK
Executing EraseMetadata...
Flashing SPLLoaderEMMC...
DownloadByID... OK
Flashing SPLLoaderUFS...
DownloadByID... OK
Flashing done!
Old 01-30-2023, 12:29   #206 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,382
Tecno KG5k (Tecno Spark 8C) dead recover Done
Operation: Flash
Work ID: 287724
Init files... OK
Load files... OK
Load files... OK
Flash Type: EMMC
ReadFlashByID... OK
ReadFlashByID... OK
ReadFlashByID... OK
DownloadByID... OK
Flashing NV_LTE...
ReadFlashByID... OK
DownloadByID... OK
Flashing ProdNV...
DownloadByID... OK
Flashing VBMETA...
DownloadByID... OK
DownloadByID... OK
DownloadByID... OK
DownloadByID... OK
DownloadByID... OK
DownloadByID... OK
DownloadByID... OK
DownloadByID... OK
DownloadByID... OK
DownloadByID... OK
Flashing DFS...
DownloadByID... OK
DownloadByID... OK
DownloadByID... OK
Flashing BOOT...
DownloadByID... OK
Flashing DTBO...
DownloadByID... OK
Flashing Super...
DownloadByID... OK
Flashing Cache...
DownloadByID... OK
Executing Tranfs...
DownloadByID... OK
DownloadByID... OK
DownloadByID... OK
Flashing Socko...
DownloadByID... OK
Flashing Odmko...
DownloadByID... OK
Flashing Trustos...
DownloadByID... OK
Flashing Teecfg...
DownloadByID... OK
Flashing SML...
DownloadByID... OK
DownloadByID... OK
Flashing Persist...
DownloadByID... OK
Flashing Cover...
DownloadByID... OK
DownloadByID... OK
DownloadByID... OK
Flashing done!
Old 01-31-2023, 00:21   #207 (permalink)
Member: 2930267
tablet cant unlock t227u
hi admin need recovery 5 credits for not unlock tablet t227u with server pandora. pls have you email for send proofs.
Old 02-01-2023, 09:05   #208 (permalink)
Member: 2534995
Thanks Meter: 96
Nokia C21 Plus Formatting
Host Power On... OK
Device found at COM448
Port: USB\VID_1782&PID_4D00\6&161B231C&0&2
Load files... OK
Serial Number: P250928751002593
Checking A/B state... OK [B]
Product Brand : Nokia
Product Manufacturer : HMD Global
Product Model : Nokia C21 Plus
Product Device : HPE
Build Date : Sun Apr 10 01:57:51 UTC 2022
Display ID : 00WW_1_070
Security Patch : 2022-04-05
Version SDK : 30
Firmware Version : 00WW_1_070 OK
Old 02-04-2023, 13:48   #209 (permalink)
Member: 2945769
Thanks Meter: 32
itel P551W FRP and Wipe DONE
Selected model: Itel P551W (Itel P17)
Software version: 4.6
Work ID: 355546
Selected processor: SC7731E
Load files... OK
Serial Number: 077544524B042513
Product Brand : Itel
Product Manufacturer : ITEL MOBILE LIMITED
Product Model : itel P551W
Product Name : SA360
Product Device : itel-P551W
Build Date : Mon Jan 24 18:40:04 CST 2022
Display ID : P551W-SA360-11.0-OP-V006-2022012
Version SDK : 30
Firmware Version : OP-V006-20220124 OK
Done!
Old 02-11-2023, 16:30   #210 (permalink)
Member: 839673
Sonork: pastorshaggy
Thanks Meter: 66
camon 16 frp done by pandora by selecting CHn9 CAMON 18 PREMIER
Selected model: Tecno CH9n (Tecno Camon 18 Premier)
Host Power On... OK
Get HW code from device... 0707
Detect chip [MT6768]
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0]
Device found at COM43 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0xEF2A0AA6, 0x4A125BD3, 0x078CB5AE, 0x7C4B3760
Get Chip ID... [MT6768]
Get SOC ID... [BA6D9E62F1A12ACEE215FC15AEB6B5663F20E3DEE9C591698E F61701E0010C65]
Search DA... OK [8]
EMMC_ID: 0x15010044563644424202A41BDC57C80F
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: DV6DBB
EMMC_ID : 0x15010044563644424202A41BDC57C80F
EMMC_USER : 0x1D1EC00000 (116.48Gb)
RAM INFO:
INT_SRAM: 0x0000070000 (448.00Kb)
Product Brand : TECNO
Product Manufacturer : TECNO
Product Model : TECNO CI6
Product Name : TSSI
Product Board : TECNO-CI6
Board Platform : connac1x
Build ID : SP1A.210812.016
Build Date : Fri Jul 8 20:20:41 CST 2022
Display ID : TECNO-S-64-220708V377
Security Patch : 2022-05-05
Version SDK : 31
Version Release : 12
Firmware Version : 220708V655
Backup saved to HYPERLINK C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Tecno_CH9n%20(Tecno%20Camon%2018%20Premier)/FRP_BACKUP_(2023-2-11_18-24-31)/"directory
Erase FRP done!
Page generated in 0.31030 seconds with 9 queries
