![]() | #31 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 781 ![]() | Quote:
-=MR_Gsm=- | |
![]() | #32 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2004 Location: Slovakia Age: 46
Member: 66497 Status: Offline Thanks Meter: 81 | Motorola XT2016-1 Selected model: Mediatek Mediatek Operation: Unlock bootloader Software version: 1.14 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x26774D08, 0xF3EDD8DC, 0xDFC807D4, 0x13B027EA Get Chip ID... [MT6771] Get SOC ID... [27445B8177218F2A9DE8EBA06F84D2DE3A76E81A855D5F768F 09596ACEDC74A1] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [20] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E53304A394B381011CA6DEB76D9 Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E53304A394B381011CA6DEB76D9 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0E8F800000 (58,24Gb) RAM INFO: INT_SRAM: 0x0000039000 (228,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Decrypt security data... OK Encrypt security data... OK Write security partition to phone... OK Unlock bootloader done! |
![]() | #33 (permalink) |
Member: 66497 Status: Offline Thanks Meter: 81 | Selected model: Mediatek Mediatek Operation: Read PTT Software version: 1.14 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x26774D08, 0xF3EDD8DC, 0xDFC807D4, 0x13B027EA Get Chip ID... [MT6771] Get SOC ID... [27445B8177218F2A9DE8EBA06F84D2DE3A76E81A855D5F768F 09596ACEDC74A1] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [20] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E53304A394B381011CA6DEB76D9 Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E53304A394B381011CA6DEB76D9 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0E8F800000 (58,24Gb) RAM INFO: INT_SRAM: 0x0000039000 (228,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "preloader"... OK Read partition "pgpt"... OK Read partition "boot_para"... OK Read partition "para"... OK Read partition "expdb"... OK Read partition "frp"... OK Read partition "cid"... OK Read partition "logs"... OK Read partition "utags"... OK Read partition "utagsBackup"... OK Read partition "carrier"... OK Read partition "pad1"... OK Read partition "nvcfg"... OK Read partition "nvdata"... OK Read partition "metadata"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "seccfg"... OK Read partition "persist"... OK Read partition "prodpersist"... OK Read partition "sec1"... OK Read partition "proinfo"... OK Read partition "nvram"... OK Read partition "efuse"... OK Read partition "pad2"... OK Read partition "hw"... OK Read partition "sp"... OK Read partition "kpan"... OK Read partition "vbmeta_a"... OK Read partition "md1img_a"... OK Read partition "spmfw_a"... OK Read partition "scp_a"... OK Read partition "sspm_a"... OK Read partition "cam_vpu1_a"... OK Read partition "cam_vpu2_a"... OK Read partition "cam_vpu3_a"... OK Read partition "logo_a"... OK Read partition "lk_a"... OK Read partition "boot_a"... OK Read partition "dtb_a"... OK Read partition "dtbo_a"... OK Read partition "tee_a"... OK Read partition "oem_a"... OK Read partition "vendor_a"... OK Read partition "system_a"... OK Read partition "vbmeta_b"... OK Read partition "md1img_b"... OK Read partition "spmfw_b"... OK Read partition "scp_b"... OK Read partition "sspm_b"... OK Read partition "cam_vpu1_b"... OK Read partition "cam_vpu2_b"... OK Read partition "cam_vpu3_b"... OK Read partition "logo_b"... OK Read partition "lk_b"... OK Read partition "boot_b"... OK Read partition "dtb_b"... OK Read partition "dtbo_b"... OK Read partition "tee_b"... OK Read partition "oem_b"... OK Read partition "vendor_b"... OK Read partition "system_b"... OK Read partition "userdata"... OK Read partition "otp"... OK Read partition "flashinfo"... OK Read partition "sgpt"... OK Dumping Partitions done! |
![]() | #36 (permalink) | |
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 781 ![]() | Repair Security done! Quote:
BR, -=MR_Gsm=- | |
![]() | #37 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2009 Location: K'dua , 3rd Fl Main K'si St GH
Member: 1123079 Status: Offline Sonork: 100.1586814 Thanks Meter: 439 | ![]() Quote:
Best Regards, Mediaextensi ![]() | |
![]() | #38 (permalink) | |
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 781 ![]() | Realme RMX2155 (Realme 7) Operation: Flash (Upgrade) Quote:
BR, -=MR_Gsm=- | |
The Following User Says Thank You to -=MR_Gsm=- For This Useful Post: |
![]() | #39 (permalink) | ||
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 781 ![]() | Realme RMX2155 (Realme 7) Operation: Unlock bootloader Quote:
Realme RMX2155 (Realme 7) Operation: Relock bootloader Quote:
BR, -=MR_Gsm=- | ||
![]() | #42 (permalink) |
Member: 66497 Status: Offline Thanks Meter: 81 | Selected model: Nokia TA-1206 (Nokia 2.3) Operation: Erase FRP Software version: 2.2 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... timeout Selected model: Nokia TA-1206 (Nokia 2.3) Operation: Erase FRP Software version: 2.2 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... timeout Selected model: Nokia TA-1206 (Nokia 2.3) Operation: Erase FRP Software version: 2.2 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3208C205, 0x4E172AB0, 0x30659EDD, 0xDEBC2120 Get Chip ID... [MT6761] Get SOC ID... [5C9F377A7FD1191D2D1148208523FB120AEE5606348C4AB458 E2E07D85EBCDFF] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x7001005441323833322011A0C334C6CD Load EMI config from database [DB VER: 164 DB DATE: 07-17-2021] OK [1] Trying EMI [17FE6D1D] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x7001005441323833322011A0C334C6CD EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000400000 (4,00Mb) EMMC_USER : 0x074A000000 (29,16Gb) RAM INFO: INT_SRAM: 0x0000039000 (228,00Kb) EXT_RAM : 0x0080000000 (2,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "frp"... OK Format "frp" partition... OK Writting FRP data... OK Erase FRP done! |
![]() | #43 (permalink) |
Member: 66497 Status: Offline Thanks Meter: 81 | Selected model: Nokia TA-1206 (Nokia 2.3) Operation: Wipe Data Software version: 2.2 There is a risk of data loss. This procedure will erase all User Data Make sure that you have a backup created. Continue? YES Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3208C205, 0x4E172AB0, 0x30659EDD, 0xDEBC2120 Get Chip ID... [MT6761] Get SOC ID... [5C9F377A7FD1191D2D1148208523FB120AEE5606348C4AB458 E2E07D85EBCDFF] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x7001005441323833322011A0C334C6CD Load EMI config from database [DB VER: 164 DB DATE: 07-17-2021] OK [1] Trying EMI [17FE6D1D] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x7001005441323833322011A0C334C6CD EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000400000 (4,00Mb) EMMC_USER : 0x074A000000 (29,16Gb) RAM INFO: INT_SRAM: 0x0000039000 (228,00Kb) EXT_RAM : 0x0080000000 (2,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "preloader"... OK Read partition "pgpt"... OK Read partition "nvcfg"... OK Read partition "nvdata"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "persist"... OK Read partition "proinfo"... OK Read partition "efuse"... OK Read partition "nvram"... OK Read partition "oem"... OK Read partition "elabel"... OK Read partition "otp"... OK Read partition "flashinfo"... OK Format "userdata" partition... OK Wipe data done! |
