![]() | #61 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Jan 2011
Member: 1485943 Status: Offline Thanks Meter: 55 | Operation: Erase FRP Software version: 2.4 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM17 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x367F06DB, 0xF4B504D6, 0x39CD4700, 0xC045FAC5 Get Chip ID... [MT6768] Get SOC ID... [475130DF618294C732122817C9E8AC0AB1E0154A9E7D9836AF 5AB54C9917BB51] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E031049093CA7CB Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E031049093CA7CB EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0E8F800000 (58,24Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "frp"... OK Format "frp" partition... OK Writting FRP data... OK Erase FRP done! |
![]() | #62 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2021 Location: GSM AFRICA TEAM (SA)
Member: 2986985 Status: Offline Thanks Meter: 190 | VODACOM Kicka 5 Plus 4G FRP Removed Selected model: Mediatek Mediatek Operation: Erase FRP Software version: 2.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0002, HW SUB CODE: 8A00 Detect chip [MT6739] Get sec config... OK [00000000] Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM115 [BROM] Open port... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0002, HW SUB CODE: 8A00 Detect chip [MT6739] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xA23F54CB, 0xF98B3A33, 0xAA8B0258, 0x5167B6E2 Get Chip ID... [MT6739] Get SOC ID... [367C2B8596736E0E786DD3649923281BB8266376ADB53998A8 4C9CE20AD6C995] Get sec config... OK [00000000] Load DownloadAgent... OK Search DA... OK [0] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x70010054323237303801395741019735 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x70010054323237303801395741019735 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000400000 (4,00Mb) EMMC_USER : 0x01C8000000 (7,13Gb) RAM INFO: INT_SRAM: 0x0000020000 (128,00Kb) EXT_RAM : 0x0040000000 (1,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "frp"... OK Format "frp" partition... OK Writting FRP data... OK Erase FRP done! |
![]() | #63 (permalink) |
Member: 2986985 Status: Offline Thanks Meter: 190 | VODACOM Kicka 5 Plus 4G Network Unlock done! Selected model: Mediatek Mediatek Operation: Unlock network Software version: 2.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0002, HW SUB CODE: 8A00 Detect chip [MT6739] Get sec config... OK [00000000] Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM115 [BROM] Open port... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0002, HW SUB CODE: 8A00 Detect chip [MT6739] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xA23F54CB, 0xF98B3A33, 0xAA8B0258, 0x5167B6E2 Get Chip ID... [MT6739] Get SOC ID... [367C2B8596736E0E786DD3649923281BB8266376ADB53998A8 4C9CE20AD6C995] Get sec config... OK [00000000] Load DownloadAgent... OK Search DA... OK [0] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x70010054323237303801395741019735 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x70010054323237303801395741019735 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000400000 (4,00Mb) EMMC_USER : 0x01C8000000 (7,13Gb) RAM INFO: INT_SRAM: 0x0000020000 (128,00Kb) EXT_RAM : 0x0040000000 (1,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Write lock info... OK Write security partition to phone... OK Network Unlock done! |
![]() | #64 (permalink) |
Member: 2986985 Status: Offline Thanks Meter: 190 | NOKIA 2.4 TA-1270 Password Removed done Selected model: Mediatek Mediatek Operation: Wipe Data Software version: 2.5 There is a risk of data loss. This procedure will erase all User Data Make sure that you have a backup created. Continue? YES Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM115 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x9A73C5B4, 0xE54C027A, 0xEA613E8A, 0x61CACAE8 Get Chip ID... [MT6765] Get SOC ID... [1A227D123E6B8F7161610F32C64FE8105E2720C8A98AE54A33 FEE2AE1F74C6A5] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x880103534C44333247591AB7C8239721 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x880103534C44333247591AB7C8239721 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000400000 (4,00Mb) EMMC_USER : 0x073A000000 (28,91Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x0080000000 (2,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "preloader"... OK Read partition "pgpt"... OK Read partition "nvcfg"... OK Read partition "nvdata"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "persist"... OK Read partition "proinfo"... OK Read partition "efuse"... OK Read partition "nvram"... OK Read partition "oem"... OK Read partition "elabel"... OK Read partition "otp"... OK Read partition "flashinfo"... OK Format "userdata" partition... OK Wipe data done! |
![]() | #65 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2004 Location: Slovakia Age: 46
Member: 66497 Status: Offline Thanks Meter: 81 | Xiaomi MI Play Unlock bootloader Operation: Unlock bootloader Software version: 2.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x9CF5B672, 0x35002C94, 0x1A42CFC0, 0xB1574387 Get Chip ID... [MT6765] Get SOC ID... [BAF755DE746D2F3CABB3B9CCF64363F359E7848292D927B30D 7092E9358DB961] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E03CA1574E916EB Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E03CA1574E916EB EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0E8F800000 (58,24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Decrypt security data... OK Encrypt security data... OK Write security partition to phone... OK Unlock bootloader done! |
![]() | #66 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2014 Location: Tanzania
Member: 2239923 Status: Offline Thanks Meter: 51 ![]() | Quote:
Congratulations to the z3x team for bringing something better to the industry. I am a veteran developer but i love what i see is very successful in the market am mr.Hussein from Tanzania or if you want to use it Professional Tecnology support work also give a great support to our developer is a very good thing thank you. | |
![]() | #67 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2012 Location: Costa Rica
Member: 1790061 Status: Offline Thanks Meter: 63 | Selected model: Samsung SM-A125M (Galaxy A12) Operation: Erase FRP Software version: 2.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x234D1D35, 0x7B47D3D9, 0x8BA492AE, 0xC205E3C5 Get Chip ID... [MT6765] Get SOC ID... [D20F14082BCEEDA4B218220158780BFD3C3F35932ACCECBF0E 5960889A769F74] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445036444142003CCCDC3C580D Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100445036444142003CCCDC3C580D EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0E8F800000 (58,24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : samsung Product Manufacturer : samsung Product Model : SM-A125M Product Name : a12ub Product Device : a12 Board Platform : MT6765 Product Board : k65v1_64_bsp_titan_rat Build ID : RP1A.200720.012 Build Date : Fri Jul 30 07:45:34 KST 2021 Display ID : RP1A.200720.012.A125MUBU1BUG6 Security Patch : 2021-07-01 Version SDK : 30 Version Release : 11 Version Codename : REL Read partition "frp"... OK Read partition "persistent"... OK Backup saved to PND_LINK_0085 "file:///C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Samsung_SM-A125M%20(Galaxy%20A12)/FRP_BACKUP_(2021-10-8_18-54-45)/"directory Format "frp" partition... OK Format "persistent" partition... OK Writting FRP data... OK Erase FRP done! |
![]() | #68 (permalink) |
![]() | #69 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2021 Location: Pakistan
Member: 2993836 Status: Offline Thanks Meter: 12 | ![]() Infinix X612B Smart HD Log: Code: elected model: Infinix X612B (Infinix Smart HD) Operation: Erase FRP Software version: 2.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [00000000] Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM0 [BROM] Open port... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xFC30B5C0, 0x7C2CBD9A, 0xB18B9A91, 0x4C014D1E Get Chip ID... [MT6761] Get SOC ID... [6B42A5357D177BD7AB81268FCC85748AD587ADAFFA53716A7A5B69453FDA087C] Get sec config... OK [00000000] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x15010051583633414203FBD7F4A628C5 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x15010051583633414203FBD7F4A628C5 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "frp"... OK Format "frp" partition... OK Writting FRP data... OK Erase FRP done! GSM City |
![]() | #70 (permalink) |
Member: 1485943 Status: Offline Thanks Meter: 55 | Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM17 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM17 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xC81EB35A, 0xA75FB227, 0x9D6BE1FA, 0xEDC46EBD Get Chip ID... [MT6768] Get SOC ID... [5DF135F8A6B7A8DA8A3990613EDD1CAF11E5A8D0D25E483FC7 E8B1C364005754] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68423861503E03001808ADC773 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68423861503E03001808ADC773 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0747C00000 (29,12Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : lancelot Product Name : lancelot_global Product Device : lancelot Board Platform : MT6768 Product Board : lancelot Build ID : QP1A.190711.020 Build Date : Fri Sep 4 22:31:03 CST 2020 Display ID : build-20200904222635 Security Patch : 2020-09-01 Version SDK : 29 Version Release : 10 Version Codename : REL Read security partition from phone... OK Unlock bootloader... OK Reset Mi Account... OK Write security partition to phone... OK Reset Mi Acc done! |
![]() | #71 (permalink) |
Junior Member ![]() ![]() Join Date: Nov 2014
Member: 2293383 Status: Offline Thanks Meter: 11 | SM-A107F empty main board repair IMEI with this tools Selected model: Samsung SM-A107F (Galaxy A10s) Operation: Repair Software version: 2.6 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1632 (Android),usb2ser.sys,3.0.1504.0] Device found at COM28 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x06B018EC, 0x1E036125, 0x0BEA6F6E, 0x1629DD54 Get Chip ID... [MT6765] Get SOC ID... [F72209EF99887E429A60F767707976747D70CFC8732DE0192A C537EFB4147D2A] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514436334D420375321482B6D9 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100514436334D420375321482B6D9 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : S96116AA1 Product Name : S96116AA1 Product Device : S96116AA1 Board Platform : MT6765 Product Board : S96116AA1 Build ID : PPR1.180610.011 Build Date : Sat Jun 29 19:18:05 KST 2019 Display ID : S96116AA1 Security Patch : 2019-06-05 Version SDK : 28 Version Release : 9 Version Codename : REL Read partitions info from phone... OK Read partition "nvram"... OK Read partition "nvdata"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: 357452106001029 IMEI 2: 357453106001027 Repairing IMEI... IMEI 1: 357452106001029 IMEI 2: 357453106001027 Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! |
![]() | #72 (permalink) |
Member: 2993836 Status: Offline Thanks Meter: 12 | ![]() Tecno KC2 Log Code: Selected model: Mediatek Mediatek Operation: Erase FRP Software version: 2.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM10 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xD80C7742, 0x6AEEC9DF, 0xA1EB6EF7, 0x08AC998F Get Chip ID... [MT6761] Get SOC ID... [14C248926F0A0C36D1E9DF3612D5C9605B6CDAEA58ED579156404B7306CA45F5] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68423861503E02729CE5B15769 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68423861503E02729CE5B15769 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : TECNO Product Manufacturer : TECNO MOBILE LIMITED Product Model : TECNO KC2 Product Name : H6113 Product Device : TECNO-KC2 Board Platform : MT6761 Product Board : TECNO-KC2 Build ID : PPR1.180610.011 Build Date : Tue Sep 22 20:33:16 CST 2020 Display ID : KC2-H6113AI-P-200922V280 Security Patch : 2020-09-05 Version SDK : 28 Version Release : 9 Version Codename : REL Read partition "frp"... OK Backup saved to PND_LINK_0072 "file:///C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Mediatek_MT6761/FRP_BACKUP_(2021-11-4_19-8-36)/"directory Format "frp" partition... OK Writting FRP data... OK Erase FRP done! GSM City |
![]() | #73 (permalink) |
Member: 66497 Status: Offline Thanks Meter: 81 | Aligator S6000Duo Selected model: Motorola UNKNOWN Operation: Erase FRP Software version: 2.6 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1633 (Android),usb2ser.sys,3.0.1504.0] Device found at COM13 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 6580 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6580] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Load DownloadAgent... OK Get sec config... OK [00000000] Get BROM version... OK Search DA... OK [5] Send bootloader... OK Start bootloader... OK Check bootloader answer... OK Wait for answer from bootloader... OK Wait for hw detection... OK Wait DA version... v4.2 Send BROM version... OK Send storage config... OK SyncBmtInfoWithDA... OK Set params... OK Sync with DA... OK Wait for DA H/W detection... OK EMMC INFO: EMMC_ID : 0x700100544232383136200CE9F7846619 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000400000 (4,00Mb) EMMC_USER : 0x03A8000000 (14,63Gb) RAM INFO: INT_SRAM: 0x0000020000 (128,00Kb) EXT_RAM : 0x0040000000 (1,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : ALIGATOR Product Manufacturer : magcomm Product Model : ALIGATOR S6000 Product Name : ALIGATOR_S6000 Product Device : ALIGATOR_S6000 Board Platform : MTK6580_8.1 Product Board : k80hd_bsp_fwv_512m Build ID : O11019 Build Date : 20190109_1507 Display ID : O11019 release-keys Security Patch : 2018-12-05 Version SDK : 27 Version Release : 8.1.0 Version Codename : REL Read partition frp... OK Backup saved to PND_LINK_0057 "file:///G:/Pandora/BackupMTK/Motorola_UNKNOWN/FRP_BACKUP_(2021-11-8_15-25-26)/"directory Format EMMC_USER partition... OK Writting FRP data... OK Erase FRP done! |
![]() | #74 (permalink) |
Member: 66497 Status: Offline Thanks Meter: 81 | Selected model: Huawei DRA-LX9 (Y5p (2020)) Operation: Erase FRP Software version: 2.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xD3402425, 0x3917BEF2, 0x92E9004B, 0x5631B885 Get Chip ID... [MT6765] Get SOC ID... [475BF9074489A119BAE02FE58053D5C29CD72C0F04945D0F08 2930397815E776] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100515836334142034F2196C86761 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100515836334142034F2196C86761 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000400000 (4,00Mb) EMMC_USER : 0x0747C00000 (29,12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x0080000000 (2,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : Huawei Product Manufacturer : unknown Product Model : a53_a53_32 Product Name : a53_a53_32 Product Device : a53_a53_32 Build ID : QP1A.190711.020 Build Date : Fri Sep 3 12:36:37 CST 2021 Display ID : System 10.1.0.68(2P0Q) Security Patch : 2020-10-01 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : eng.root.20210903.123717 Read partition "frp"... OK Backup saved to PND_LINK_0066 "file:///G:/Pandora/BackupMTK/Huawei_DRA-LX9%20(Y5p%20(2020))/FRP_BACKUP_(2021-11-24_18-6-39)/"directory Format "frp" partition... OK Writting FRP data... OK Erase FRP done! |
The Following User Says Thank You to Svito For This Useful Post: |
![]() | #75 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: Latvija
Member: 229048 Status: Offline Thanks Meter: 10 | succesfull frp reset MOTOROLA e7 XT2095-2 Quote:
The Following User Says Thank You to Statums For This Useful Post: |
