Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 02-05-2025, 17:41   #751 (permalink)
mr.6630's Avatar
Member: 148424
Sonork: 100.93619
Thanks Meter: 114
oppo a1k imei repair done
Selected model: OPPO CPH1923 (OPPO A1K)
Operation: Repair
Software version: 7.14
Work ID: 60270910
Connect phone in BROM Mode
Waiting for device... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1512.0]
You are using driver version 3.0.1512.0, we recommend using version 3.0.1504.0 for proper operation. You can install the correct driver from the program directory.
Device found at COM22 [BROM]
Open port... OK
Send start cmd... OK
Get HW code from device... 0766
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6765]
LibUSB installed
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Release testpoint, waiting 2 seconds
Advanced Bypass Security... OK
Open port... OK
Get sec config... OK [000000E0]
Active sec flags: []
Library Version [2]
Init BROM... OK
Force Charge... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0x28CFB9B2, 0x100D6BE4, 0xD24CB212, 0x310D22B6
Get Chip ID... [MT6765]
Get SOC ID... [B3E4780358F337FD5DF35BBD8E57C3B4DF5D2ECD2E7B3691A3 EA6CE6896F2D30]
Load DownloadAgent... OK
Search DA... OK [7]
Send preloader... OK
Start preloader... OK
Checking preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x150100514436334D42031383AA40160F
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: QD63MB
EMMC_ID : 0x150100514436334D42031383AA40160F
EMMC_BOOT1: 0x0000400000 (4.00Mb)
EMMC_BOOT2: 0x0000400000 (4.00Mb)
EMMC_RPMB : 0x0001000000 (16.00Mb)
EMMC_USER : 0x0747C00000 (29.12Gb)
RAM INFO:
INT_SRAM: 0x000003A000 (232.00Kb)
EXT_RAM : 0x0080000000 (2.00Gb)
HEALTH:
Pre EOL Info: normal
DeviceLifeTimeEstA: 60% - 70% device life time used
DeviceLifeTimeEstB: 60% - 70% device life time used
Checking USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Checking A/B state... OK
Read product info... [EXT4] ... OK
Product Brand : OPPO
Product Manufacturer : OPPO
Product Model : CPH1923
Product Name : CPH1923
Product Device : OP486C
Product Board : oppo6762_18540
Board Platform : mt6765
Build ID : PPR1.180610.011
Build Date : Fri Mar 29 16:47:13 CST 2024
Display ID : CPH1923EX_11_A.42
Security Patch : 2021-05-05
Version SDK : 28
Version Release : 9
Version Codename : REL
Firmware Version : 1711702281
Userdata FS Type : EXT4
Read security partition from phone...
Decrypting security data... OK
Encrypt security data... OK
Read partition "nvdata"... OK
Read partition "protect1"... OK
Read partition "nvram"... OK
Read NVDATA files... OK
Read NVRAM files... OK
Read security files... OK
Calculating... OK
Repairing IMEI...
IMEI 1: 867867867869855
IMEI 2: 867867867869863
Write IMEI and patch CERT [NVDATA]... OK
Checking patch type... [1]
Patching CERT... OK
Save patched partiton... OK
Updating NVRAM... OK
Read security partition from phone... OK
Write security partition to phone... OK
Checking additional lock... [DISABLED]
Unlock bootloader done!
Selected "Disable VBMETA verification"
Write IMEI and patch CERT [NVRAM]... OK
Write partition "nvdata"... OK
Write partition "nvram"... OK
Repair Security and Patch cert done!
If your phone after repair keeps rebooting - use wipe data option.
Old 02-06-2025, 12:29   #752 (permalink)
Member: 1589971
Thanks Meter: 151
Infinix Smart HD 2021 (X612b) Frp done
Selected model: Infinix Mediatek
Operation: Erase FRP
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1511.0]
You are using driver version 3.0.1511.0, we recommend using version 3.0.1504.0 for proper operation. You can install the correct driver from the program directory.
Device found at COM116 [BROM]
Open port... OK
Get HW code from device... 0717
Get sec config... OK [00000000]
HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00
Detect chip [MT6761]
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0xC897CA8C, 0xABE4294B, 0x1DD459F0, 0xC5757814
Get Chip ID... [MT6761]
Get SOC ID... [C7FD735827E8E493EA854DF65666F638634CB77FAB7DC94F18 B60375B4C63836]
Search DA... OK [5]
EMMC_ID: 0x15010051583633414203CC8E076718B5
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: QX63AB
EMMC_ID : 0x15010051583633414203CC8E076718B5
EMMC_RPMB : 0x0000400000 (4.00Mb)
RAM INFO:
INT_SRAM: 0x000003A500 (233.25Kb)
HEALTH:
DeviceLifeTimeEstA: 10% - 20% device life time used
DeviceLifeTimeEstB: 10% - 20% device life time used
Product Brand : Infinix
Product Manufacturer : INFINIX MOBILITY LIMITED
Product Model : Infinix X612B
Product Name : X612B-GL
Product Device : Infinix-X612B
Product Board : infinix_x612b
Board Platform : mt6761
Build ID : QP1A.190711.020
Build Date : Thu Nov 11 19:41:55 CST 2021
Display ID : X612B-X612BBC-QGo-GL-211111V037
Security Patch : 2021-11-05
Version SDK : 29
Version Release : 10
Firmware Version : BC-GL-211111V037
Userdata FS Type : F2FS
Read partition "frp"... OK
Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Infinix_MT6761/FRP_BACKUP_(2025-2-6_15-54-1)/
Format FRP... [P1] OK
Writting FRP data... OK
Fix TOOL DL Image error... OK
Erase FRP done!
Old 02-08-2025, 13:56   #753 (permalink)
Member: 1589971
Thanks Meter: 151
Xiaomi Redmi A3x Frp done
Selected model: Itel P683L (Itel P40 Plus)
Connect phone in BROM mode. Use volume key buttons or testpoint.
Device found at COM45
Port: USB\VID_1782&PID_4D00\6&298C69D9&0&3
Driver: [UNISOC Communications Inc.,sprdvcom,SPRD U2S Diag,sprdvcom.sys,4.19.38.134]
Port type: BROM
Connecting to device... OK
Selected processor: SC9863A_64
Load files... (universal) OK
Connect preloader 1... OK
Connect preloader 2... OK
Connect loader 1... OK
Connect loader 2... OK
Serial Number: ET417L002538
Read partitions info... OK
Checking A/B state... OK [A]
Read product info... [EROFS] ... OK
Product Brand : Redmi
Product Manufacturer : Xiaomi
Product Model : klein
Product Name : miodm_klein_global
Product Device : klein
Product Board : klein
Board Platform : sp9863a
Build ID : TP1A.220624.014
Build Date : Thu Apr 25 08:14:24 CST 2024
Display ID : TP1A.220624.014
Security Patch : 2024-03-01
Version SDK : 34
Version Release : 14
Firmware Version : V816.0.2.0.UGSMIXM
Backup partitions... OK
Formatting "persist" partition... OK
Done!
Old 02-10-2025, 15:00   #754 (permalink)
Member: 1589971
Thanks Meter: 151
Tecno KE5 (Tecno Spark 6 Go) Frp done
Selected model: Tecno KE5 (Tecno Spark 6 Go)
Connect phone in BROM/PRELOADER Mode
Open port... OK
LibUSB installed
Library Version [2]
Init BROM... OK
Force Charge... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0xA84C2686, 0x528B510A, 0x2F5EEBE2, 0x546CC10D
Get SOC ID... [5978C25AEA5F1726127DAA084A2FF6AC4BCC288BE37E1621B7 093B324F54A8F1]
Search DA... OK [5]
EMMC_ID: 0x90014A68423861503E03105CFD78A717
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: hB8aP>
EMMC_ID : 0x90014A68423861503E03105CFD78A717
RAM INFO:
HEALTH:
DeviceLifeTimeEstA: info not available
DeviceLifeTimeEstB: 30% - 40% device life time used
Product Brand : TECNO
Product Manufacturer : TECNO MOBILE LIMITED
Product Model : TECNO KE5
Product Name : KE5-GL
Product Device : TECNO-KE5
Product Board : TECNO-KE5
Build Date : Mon Aug 22 20:44:38 CST 2022
Display ID : KE5-H6123ABC-QGo-GL-220822V553
Security Patch : 2022-08-01
Version SDK : 29
Firmware Version : ABC-GL-220822V553
Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Tecno_KE5%20(Tecno%20Spark%206%20Go)/FRP_BACKUP_(2025-2-10_18-57-19)/
Erase FRP done!
Old 02-12-2025, 17:25   #755 (permalink)
chipscell25's Avatar
Member: 1537078
Sonork: celular center
Thanks Meter: 602
UNLOCK TCL T610E USING 6125F SUCCESS
Selected model: TCL 6125F (TCL 20E)
Operation: Unlock network
Host Power Off... OK
Switch virtual port to NONE... OK
Connect Type-C to HUB... OK
Host Power On... OK
Connect phone to [BOX] in BROM/PRELOADER Mode
Device found at COM72 [BROM]
Open port... OK
Get sec config... OK [000000E7]
Active sec flags: [SBC SLA DAA]
Library Version [2]
Init BROM... OK
Force Charge... OK
Force switch to BROM... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Release testpoint
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x2B3159CD, 0xBB381A3E, 0x8C9B4332, 0xC89BC8BB
Get SOC ID... [956E65A4B7183569317B9A2A358E39DCD0DE39724372E7AADC ECB70CFBEC1E0E]
Get hw mode... OK
Search DA... OK [7]
EMMC_ID: 0xF4012241525632315813236992C86A03
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: ARV21X
EMMC_ID : 0xF4012241525632315813236992C86A03
EMMC_USER : 0x1CD0000000 (115.25Gb)
RAM INFO:
EXT_RAM : 0x0100000000 (4.00Gb)
HEALTH:
DeviceLifeTimeEstA: 0% - 10% device life time used
DeviceLifeTimeEstB: 0% - 10% device life time used
Checking A/B state... OK [B]
Product Brand : TCL
Product Manufacturer : TCL
Product Model : mssi_64_ww
Product Board : model_3
Build ID : SP1A.210812.016
Build Date : Sun Oct 8 11:27:13 CST 2023
Security Patch : 2023-08-01
Version SDK : 33
Version Release : 13
Firmware Version : 7GH8
Calculating... OK
Read lock info... OK
Read OTP... OK
Unlock... OK [DF1, DF2]
Write lock info... OK
Network Unlock done!
Old 02-13-2025, 21:36   #756 (permalink)
Member: 2979877
Thanks Meter: 115
Selected model: Vortex HD65 Ultra
Connect Type-C to NONE... OK
Connect phone to [PC] in PRELOADER Mode
Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0]
Device found at COM9 [PRELOADER]
Open port... OK
Get HW code from device... 0699
Detect chip [MT6739]
Library Version [2]
Init BROM... OK
Force Charge... OK
Preloader exist. Skip connection verification.
Get ME ID... OK
ME_ID = 0x7116B407, 0x621B216A, 0xD18DA07F, 0x9EE44559
Search DA... OK [0]
Get device connection agent... [PRELOADER]
Preloader alive. Skip initializing external RAM
Search DA... OK [1]
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: HBG4a2
EMMC_ID : 0x90014A484247346132A42200101092E1
RAM INFO:
INT_SRAM: 0x0000020000 (128.00Kb)
EXT_RAM : 0x00C0000000 (3.00Gb)
HEALTH:
[EFUSE INFO]: BROM not disabled
Product Brand : Vortex
Product Manufacturer : Vortex
Product Model : HD65_Ultra
Product Name : HD65_Ultra
Product Device : HD65_Ultra
Product Board : k39tv1_64_bsp_k419
Board Platform : mt6739
Build Date : Sat Dec 9 13:50:00 CST 2023
Display ID : Vortex_HD65_Ultra_V01_12092023
Security Patch : 2023-11-05
Version SDK : 33
Firmware Version : 20231209
Calculating... OK
Read IMEI... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x2D1BAE37, 0x763F939E, 0x7E7BC0EC, 0x4596196E
Search DA... OK [0]
Search DA... OK [1]
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: GD6BMB
EMMC_ID : 0x150100474436424D4201513B061495A3
RAM INFO:
HEALTH:
Build Date : Tue Feb 27 10:55:32 CST 2024
Display ID : Vortex_HD65_Ultra_V01_02272024
Security Patch : 2024-01-05
Version SDK : 33
Firmware Version : 20240227
Calculating... OK
Read IMEI... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0xA638E7AF, 0xEC08AAD1, 0x7DAB4E91, 0x85B68731
Search DA... OK [0]
Search DA... OK [1]
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: HBG4a2
EMMC_ID : 0x90014A484247346132A515003676B585
RAM INFO:
HEALTH:
Build Date : Mon Apr 22 20:06:02 CST 2024
Display ID : Vortex_HD65_Ultra_V01_04222024
Security Patch : 2024-04-05
Version SDK : 33
Firmware Version : 20240422
Calculating... OK
Read IMEI... OK
Old 02-16-2025, 20:12   #757 (permalink)
Member: 2951556
Thanks Meter: 906
Selected model: Nokia TA-1412 (Nokia G21)
Operation: Erase FRP And Wipe
Host Power On... OK
Connect phone to [BOX or PC]
Device found at COM64
Port: USB\VID_1782&PID_4D00\6&37F8BD03&0&2
Port type: BROM
Selected processor: Tiger_T616_64
Serial Number: P232227121005048
Flash Type: EMMC
Product Brand : Nokia
Product Manufacturer : HMD Global
Product Model : Nokia G21
Product Name : ShadowcatPlus_00WW
Product Device : SCP_sprout
Product Board : ShadowcatPlus
Board Platform : ums9230
Build Date : Tue Jan 7 10:07:04 UTC 2025
Display ID : 00WW_3_530_SP15
Security Patch : 2025-01-05
Version SDK : 33
Firmware Version : 00WW_3_53V
Formatting "userdata" partition... OK
Formatting "cache" partition... OK
Formatting "metadata" partition... OK
Creating default filesystems... [CACHE: EXT4] ... [USERDATA: F2FS] ... OK
Done!
Old 02-22-2025, 19:31   #758 (permalink)
Member: 2979877
Thanks Meter: 115
Selected model: Samsung SM-G996U (Galaxy S21 Plus 5G)
BITD or less is supported by EDL loader
Device found at COM42
Port: Qualcomm HS-USB QDLoader 9008
Open port... OK
Reading device info... OK
Serial Number: 1991517641
Sahara ver: 2
OEM PK HASH: D6BD96B0682EE88A1607A4C5602833F52929A2541C3C2B5D51 A4628DB3F4618BD475287DF12553F62D7900A84BF1A07B
CPU: SM8350 (Snapdragon 888 5G)
Vendor: Samsung
MSM HW ID: 001350E100200000
SBL SW Ver: 00000000
Prepare loader file... downloading... OK
Loader hash: 658AEF85984ECD05BF59E842E109F1F9EB0CE663
Loader PK hash: D6BD96B0682EE88A1607A4C5602833F52929A2541C3C2B5D51 A4628DB3F4618BD475287DF12553F62D7900A84BF1A07B
Loader version: 6.5
Sending loader... OK
FireHose initialization... OK
Detecting memory type... OK [UFS]
Get storage info... OK
Storage info:
Type: UFS
Page size: 1000
Block size: 1000
Partition count: 6
LU0 size: 0x1DA8C00000
LU1 size: 0x0000800000
LU2 size: 0x0000800000
LU3 size: 0x0000400000
LU4 size: 0x0020000000
LU5 size: 0x0000800000
Read product info... OK
Serial Number : RFCR10ZGKQN
Product Brand : samsung
Product Manufacturer : samsung
Product Model : SM-G996U
Product Name : t2qsqw
Product Device : t2q
Product Board : lahaina
Board Platform : lahaina
Build ID : RP1A.200720.012
Build Date : Wed Jun 15 10:41:36 KST 2022
Display ID : SP1A.210812.016.G996USQU5CVF3
Security Patch : 2022-06-01
Version SDK : 31
Version Release : 12
Firmware Version : G996USQU5CVF3
Erase FRP... OK
Done!
Old 02-25-2025, 16:32   #759 (permalink)
yuslamunique's Avatar
Member: 2993572
Thanks Meter: 204
Samsung a03 [a035f] u7 frp reset done
Selected model: Samsung SM-A035F (Samsung Galaxy A03 )
Device found at COM19
Port: USB\VID_1782&PID_4D00\5&28062471&0&3
Port type: BROM
Selected processor: Tiger_T606_64
Serial Number: 82828B6T0753E
Flash Type: EMMC
Product Model        : SM-A035F
Product Name         : a03nnxx
Product Device       : a03
Product Board        : ums9230_25c10
Build Date           : Wed Jun 26 10:39:36 KST 2024
Firmware Version     : A035FXXS7CXF3
Formatting "persistent" partition... OK
Done!
Old 03-03-2025, 09:12   #760 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Lenovo TB-X605LC Erase FRP
Selected model: Qualcomm Qualcomm
Software version: 8.0
Device found at COM10
Open port... OK
Serial Number: 3892580796
Sahara ver: 2
OEM PK HASH: C07FF9FE7A808082A863025F7DBFB850C0A34F645542B84201 5A5A8FD8C3E53C
CPU: SDM450 (Snapdragon 450)
Vendor: Qualcomm
MSM HW ID: 0009A0E100000000
Loader hash: 0687C308B21F6B0F3CD8AD59C302B520D8D0DD90
Loader PK hash: C07FF9FE7A808082A863025F7DBFB850C0A34F645542B84201 5A5A8FD8C3E53C
Loader version: 3.21
Detecting memory type... OK [EMMC]
Storage info:
Type: EMMC
Page size: 200
Block size: 200
Partition count: 3
PART0 size: 0x0747C00000 (29.12Gb)
PART1 size: 0x0000400000 (4.00Mb)
PART2 size: 0x0000400000 (4.00Mb)
Product Brand : Lenovo
Product Manufacturer : LENOVO
Product Model : Lenovo TB-X605LC
Product Name : LenovoTB-X605LCV
Product Device : TB-X605LC
Product Board : LenovoTB-X605LCV
Board Platform : msm8953
Build ID : PKQ1.181203.001
Build Date : Wed Oct 21 17:47:11 CST 2020
Display ID : TB-X605LC_S000092_201021_IN
Security Patch : 2020-10-05
Version SDK : 28
Version Release : 9
Firmware Version : TB-X605LC_S000092_201021_IN
Erase FRP... OK
Done!
Old 03-03-2025, 22:32   #761 (permalink)
..::alexis::..'s Avatar
Member: 289200
Thanks Meter: 219
Moto G04s XT2421-8
Moto G04s XT2421-8
Selecting Tiger_T612_64
Unlike other apps that kill this phone, Pandora do a great job)
Device found at COM30
Port: USB\VID_1782&PID_4D00\5&307991E7&0&9
Port type: BROM
Selected processor: Tiger_T612_64
Serial Number: ZY22KSM3G2
Flash Type: UFS
Product Brand        : motorola
Product Manufacturer : motorola
Product Model        : lion
Product Name         : lion_g
Product Device       : lion
Product Board        : lion
Build ID             : ULA34.89-178
Build Date           : Sat Dec 21 14:25:54 CST 2024
Display ID           : ULA34.89-178 release-keys
Version SDK          : 34
Firmware Version     : bb98381f
Done!
Old 03-04-2025, 01:10   #762 (permalink)
Member: 2875052
Thanks Meter: 226
Alcatel 9032Z Unlock Done
Selected model: Alcatel 9032Z (Alcatel Joy Tab 2)
Work ID: 63673432
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0]
Device found at COM31 [BROM]
Open port... OK
LibUSB installed
Library Version [2]
Init BROM... OK
Force Charge... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x92BFC462, 0x1CE80D84, 0x6C0ACBDA, 0x90AD64EE
Get SOC ID... [6BF02E85F1BB55303F8913B98FF6118D6E1D699939A01BC15B 26B7D1867784D9]
Search DA... OK [5]
EMMC_ID: 0x150100445836384D4209181ECA8EC831
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: DX68MB
EMMC_ID : 0x150100445836384D4209181ECA8EC831
RAM INFO:
HEALTH:
Product Brand : Alcatel
Product Model : 9032Z
Product Name : 9032Z
Product Device : Apollo_8_4G_TMO
Product Board : apollo84gtmo
Build Date : Tue Jul 11 19:52:56 CST 2023
Display ID : QP1A.190711.020 release-keys
Security Patch : 2023-02-05
Version SDK : 29
Firmware Version : v1C7O-0
Calculating... OK
Read OTP... OK
Unlock... OK [DF1, DF2, SM]
Old 03-06-2025, 13:20   #763 (permalink)
Member: 1589971
Thanks Meter: 151
Vivo V2026 (Vivo Y12S) Frp done
Selected model: Vivo V2026 (Vivo Y12S)
Parse scatter file... OK
Load Rom Images... OK
Connect phone in PRELOADER Mode
Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1511.0]
Device found at COM64 [PRELOADER]
Open port... OK
Get sec config... OK [00000005]
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x780B94FA, 0x561C99A7, 0xC40FF590, 0x2BA564A3
Search DA... OK [2]
Search DA... OK [7]
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: hB8aP>
EMMC_ID : 0x90014A68423861503E03004010A9A72B
RAM INFO:
HEALTH:
DeviceLifeTimeEstB: 40% - 50% device life time used
Get scatter info... OK
Product Brand : vivo
Product Manufacturer : vivo
Product Model : V2026
Product Name : 2026
Product Device : 2026
Product Board : k65v1_64_bsp
Build Date : Mon Oct 21 18:12:11 CST 2024
Display ID : RP1A.200720.012 release-keys
Security Patch : 2023-05-01
Version SDK : 30
Version Release : 11
Firmware Version : eng.compil.20241021.181531
Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Vivo_V2026%20(Vivo%20Y12S)/FRP_BACKUP_(2025-3-6_16-56-49)/
Erase FRP done!
Old 03-06-2025, 13:30   #764 (permalink)
Member: 1589971
Thanks Meter: 151
ecno BC2 (Tecno Pop 4) wipe & Frp done
Selected model: Tecno BC2 (Tecno Pop 4)
Erasing of partitions can damage your device.
Make sure that you have a backup created. Continue? YES
Device found at COM62 [BROM]
Open port... OK
Get HW code from device... 6580
Detect chip [MT6580]
LibUSB installed
Library Version [1]
Init BROM... OK
Force Charge... OK
Open port... OK
Library Version [1]
Init BROM... OK
Force Charge... OK
ME_ID = 0xEADA8E2C, 0x4DE7D71B, 0x51419CD9, 0xD789586D
Get BROM version... OK
Search DA... OK [26]
Checking bootloader answer... OK
Wait for hw detection... OK
Wait DA version... v4.2
Send BROM version... OK
Send storage config... OK
SyncBmtInfoWithDA... OK
Set params... OK
Read flash info... OK
EMMC_ID: 0x510001154D3336448A9F0142B5A7A3E4
Init DRAM... OK
Enable DRAM... OK
Sync with DA... OK
Wait for DA H/W detection... OK
EMMC INFO:
EMMC_CNAME: QD63MB
EMMC_ID : 0x150100514436334D42019F8AE4A3A7B5
RAM INFO:
HEALTH:
Checking USB status... USB_FULL_SPEED
Switching to USB high speed... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek DA USB VCOM (Android),usb2ser.sys,3.0.1511.0]
High Speed USB detected at COM11
Open port... OK
Product Model : TECNO BC2
Product Name : BC2-OP
Product Device : TECNO-BC2
Product Board : k80hd_bsp_fwv_512m
Board Platform : mt6580
Build Date : Tue May 3 13:45:59 CST 2022
Display ID : BC2-VP592AB-QGo-OP-220503V019
Security Patch : 2022-04-05
Version SDK : 29
Firmware Version : AB-OP-220503V019
Read partition frp... OK
Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Tecno_BC2%20(Tecno%20Pop%204)/FRP_BACKUP_(2025-3-6_16-44-14)/
Formatting "md_udc" partition... OK
Wipe data done!
Old 03-06-2025, 13:40   #765 (permalink)
Member: 1589971
Thanks Meter: 151
Xiaomi Redmi 9AT (Dandelion) Frp done
Selected model: Xiaomi Redmi 9AT (Dandelion)
Open port... OK
LibUSB installed
Library Version [2]
Init BROM... OK
Force Charge... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x7D920EAE, 0xD844D292, 0x5E0BCFC7, 0xE5CA4DE4
Get SOC ID... [054FB88117C626C787B73D625B4447526C0098A2F7952AAB8C 984E75B1452F85]
Search DA... OK [7]
EMMC_ID: 0x9B010059325030333200C1FB2F9E29D7
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: Y2P032
EMMC_ID : 0x9B010059325030333200C1FB2F9E29D7
RAM INFO:
HEALTH:
Product Model : M2006C3LG
Product Name : dandelion_eea
Product Device : dandelion
Product Board : dandelion
Build Date : Fri Jul 2 23:37:35 CST 2021
Security Patch : 2021-06-01
Version SDK : 29
Firmware Version : V12.0.14.0.QCDEUXM
MiAcc Find Device : Enabled
Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Xiaomi_Redmi%209AT%20(Dandelion)/FRP_BACKUP_(2025-3-4_12-12-2)/
Erase FRP done!
Page generated in 0.18078 seconds with 9 queries
