Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 12-04-2021, 12:39   #76 (permalink)
Crazy Poster
Member: 2995638
Thanks Meter: 30
Nony s351 imei repair
NONY S351 IMEI REPAIR
Selected model: Sony UNKNOWN
Operation: Repair
Software version: 2.6
Host Power Off... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Wait for device... OK
Read usbhost speed... FULL
Read Device Descriptor...
Get VID/PID...0E8D/0003
Send start cmd... OK
Get HW code from device... 6580
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6580]
Get sec config... OK [00000000]
Disconnect virtual port... OK
Connect Type-C to HUB... OK
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0]
Device found at COM43 [BROM]
Open port... OK
Library Version [1]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Load DownloadAgent... OK
ME_ID = 0x76BA7C40, 0x0EB57F50, 0xDB0808FB, 0x4619D151
Get BROM version... OK
Search DA... OK [11]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Check bootloader answer... OK
Wait for answer from bootloader... OK
Wait for hw detection... OK
Wait DA version... v4.2
Send BROM version... OK
Send storage config... OK
SyncBmtInfoWithDA... OK
Set params... OK
Read flash info... OK
EMMC_ID: 0x524E011336394A314188104E1933E4A6
Load EMI from phone... OK
Init DRAM... OK
Enable DRAM... OK
Sync with DA... OK
Wait for DA H/W detection... OK
EMMC INFO:
EMMC_ID : 0x13014E52314A39364E108841A6E43319
EMMC_BOOT1: 0x0000400000 (4.00Mb)
EMMC_BOOT2: 0x0000400000 (4.00Mb)
EMMC_RPMB : 0x0000400000 (4.00Mb)
EMMC_USER : 0x03AB400000 (14.68Gb)
RAM INFO:
INT_SRAM: 0x0000020000 (128.00Kb)
EXT_RAM : 0x0080000000 (2.00Gb)
Check USB status... USB_FULL_SPEED
Read partitions info from phone... OK
Read product info... OK
Product Brand : NONY
Product Manufacturer : NONY
Product Model : U2
Product Name : S351
Product Device : S351
Board Platform : MT6580
Product Board : MTK
Build ID : LMY47I
Build Date : Mon Sep 16 15:31:49 CST 2019
Display ID : S351_B606MB_Q5P 20190916-153149
Version SDK : 22
Version Release : 5.1
Version Codename : REL
Read partition nvram... OK
Read partition nvdata... OK
Read NVDATA files... OK
Read NVRAM files... OK
Read IMEI... OK
IMEI 1: 111111111111111
IMEI 2: 111111111111111
Repairing IMEI...
IMEI 1: 000000000000000
IMEI 2: 000000000000000
Write IMEI [NVDATA]... OK
Write IMEI [NVRAM]... OK
Check parametres... OK
Write partition "nvdata"... OK
Write partition "nvram"... OK
Repair Security done!
Old 12-07-2021, 13:10   #77 (permalink)
Member: 1485943
Thanks Meter: 55
Selected model: Samsung SM-A107F (Galaxy A10s)
Operation: Patch CERT
Software version: 2.8
Switch virtual port to NONE... OK
Host Power On... OK
Connect phone to BOX in BROM/PRELOADER Mode
Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0]
Device found at COM64 [PRELOADER]
Open port... OK
Get HW code from device... 0766
Detect chip [MT6765]
Library Version [2]
Init BROM... OK
Force Charge... OK
Force switch to BROM... OK
Host Power On... OK
Read usbhost speed... HIGH
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Advanced Bypass Security... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0]
Device found at COM17 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0x162AB416, 0x413821B5, 0xC0E22865, 0x4B4C552E
Get Chip ID... [MT6765]
Get SOC ID... [CBC1A6B53A462187CEE6A7DF2434745623EA542DEADCD44382 56EC6D65E0594A]
Get sec config... OK [000000E0]
Search DA... OK [23]
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x150100514436334D42034EF8900C3757
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x150100514436334D42034EF8900C3757
EMMC_BOOT1: 0x0000400000 (4,00Mb)
EMMC_BOOT2: 0x0000400000 (4,00Mb)
EMMC_RPMB : 0x0001000000 (16,00Mb)
EMMC_USER : 0x0747C00000 (29,12Gb)
RAM INFO:
INT_SRAM: 0x000003A000 (232,00Kb)
EXT_RAM : 0x0080000000 (2,00Gb)
Check USB status... USB_HIGH_SPEED
Product Brand : samsung
Product Manufacturer : samsung
Product Model : SM-A107F
Product Name : a10sxx
Product Device : a10s
Product Board : S96116CA1
Board Platform : MT6765
Build ID : QP1A.190711.020
Build Date : Thu Mar 25 09:27:15 KST 2021
Display ID : QP1A.190711.020.A107FXXU8BUC2
Security Patch : 2021-04-01
Version SDK : 29
Version Release : 10
Firmware Version : A107FXXU8BUC2
Read partition "nvram"... OK
Read partition "nvdata"... OK
Patch CERT [NVDATA]... OK
Patch CERT [NVRAM]... OK
Patch cert done!
Old 12-07-2021, 13:10   #78 (permalink)
Member: 1485943
Thanks Meter: 55
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Version SDK : 29
Patch cert done!
Old 12-17-2021, 12:24   #79 (permalink)
Member: 2185549
Thanks Meter: 536
oppo a59s format userdtaa done
Selected model: OPPO A59s (Oppo A59s)
Operation: Wipe Data
There is a risk of data loss.
This procedure will erase all User Data
Make sure that you have a backup created. Continue? YES
Host Power On... OK
Driver: [Sony Mobile Communications,usbser,MTK USB Port,usbser.sys,10.0.19041.1202]
Device found at COM188 [BROM]
Open port... OK
Get HW code from device... 0326
HW VER: CB00, SW VER: 0001, HW SUB CODE: 8A00
Detect chip [MT6755]
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Get sec config... OK [00000001]
Active sec flags: [SBC]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x30F10278, 0xE8D9DB88, 0xC274CBBE, 0x1425953B
Get Chip ID... [MT6750]
Modem count: 6
Search DA... OK [13]
EMMC_ID: 0x90014A484247346132A52280D4F214D5
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x90014A484247346132A52280D4F214D5
EMMC_USER : 0x0747C00000 (29.12Gb)
RAM INFO:
INT_SRAM: 0x0000038000 (224.00Kb)
EXT_RAM : 0x0100000000 (4.00Gb)
Switching to USB high speed... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek DA USB VCOM (Android),usb2ser.sys,3.0.1504.0]
High Speed USB detected at COM87
Open port... OK
Product Brand : OPPO
Product Manufacturer : OPPO
Product Model : OPPO A59s
Product Name : A59
Product Device : A59
Product Board : full_oppo6750_15131
Board Platform : MT6755
Build ID : LMY47I
Build Date : Tue Dec 27 22:07:48 CST 2016
Display ID : A59s_11_A.16_161227
Security Patch : 2016-09-05
Version SDK : 22
Firmware Version : 1482847378
Read partition "preloader"... OK
Read partition "pgpt"... OK
Read partition "oppo_custom"... OK
Read partition "protect1"... OK
Read partition "protect2"... OK
Read partition "oemkeystore"... OK
Read partition "proinfo"... OK
Read partition "flashinfo"... OK
Backup saved to PND_LINK_007F "file:///C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/OPPO_A59s%20(Oppo%20A59s)/WIPE_BACKUP_(2021-12-17_14-22-42)/"directory
Format "userdata" partition... OK
Format "cache" partition... OK
Create default filesystems... OK
Wipe data done!
Old 12-18-2021, 11:05   #80 (permalink)
Gsm Africa Team's Avatar
Member: 2986985
Thanks Meter: 190
Alcatel 5033G Network Unlock DONE
Selected model: Alcatel 5033G (Alcatel 1)
Operation: Unlock network
Host Power On... OK
Device found at COM135 [BROM]
Open port... OK
Get HW code from device... 0699
Detect chip [MT6739]
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Get sec config... OK [000000E7]
Active sec flags: [SBC SLA DAA]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x915DF1C6, 0x1B3F340A, 0xFA4796FF, 0xBEFAD81D
Get Chip ID... [MT6739]
Get SOC ID... [DF84DE61DF62040A3A8FBCC96615792C2B0FBD3911E9CAB865 D85C35EDD9B88E]
Search DA... OK [0]
EMMC_ID: 0x150100464536324D4203A63A97B4A6C9
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x150100464536324D4203A63A97B4A6C9
EMMC_RPMB : 0x0000400000 (4,00Mb)
EMMC_USER : 0x03A3E00000 (14,56Gb)
RAM INFO:
INT_SRAM: 0x0000020000 (128,00Kb)
EXT_RAM : 0x0040000000 (1,00Gb)
Product Brand : TCL
Product Manufacturer : TCL
Product Model : 5033G
Product Name : 5033G
Product Device : U3A_PLUS_4G
Product Board : MT6739
Board Platform : MT6739
Build ID : O11019
Build Date : Thu Apr 30 18:10:09 CST 2020
Display ID : Nougat
Security Patch : 2020-05-05
Version SDK : 27
Version Release : 8.1.0
Firmware Version : v7L78-0
Read security partition from phone... OK
Read security files... OK
Read lock info... OK
Write lock info... OK
Write security partition to phone... OK
Network Unlock done!
Old 12-29-2021, 19:22   #81 (permalink)
Member: 2902804
Sonork: 100.1660513
Thanks Meter: 929
Old 01-16-2022, 15:28   #82 (permalink)
Member: 2534995
Thanks Meter: 96
Huawei DRA-LX5 (Y5 (2018) FRP DONE
Selected model: Huawei DRA-LX5 (Y5 (2018))
Operation: Erase FRP
Software version: 2.10
Host Power On... OK
Connect phone to BOX in BROM mode
HW VER: CB00, SW VER: 0002, HW SUB CODE: 8A00
Get sec config... OK [000000E3]
Active sec flags: [SBC SLA]
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0]
Device found at COM0 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x3B810830, 0x8F714AEB, 0xEC7425DC, 0xF1D8BCE0
Get SOC ID... [80359EB859F65A5E5EC73664AE7AC15A3CAEE58BF2BDC45EE4 207BF7B8812EAB]
Search DA... OK [0]
EMMC_ID: 0x150100464536324D4206317690DF5777
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x150100464536324D4206317690DF5777
EMMC_USER : 0x03A3E00000 (14.56Gb)
RAM INFO:
EXT_RAM : 0x0040000000 (1.00Gb)
Check A/B state... OK
Product Brand : HUAWEI
Product Manufacturer : HUAWEI
Product Model : DRA-LX5
Product Name : DRA-LX5
Product Device : HWDRA-MG
Product Board : DRA-LX5
Build ID : HUAWEIDRA-LX5
Build Date : Tue Apr 6 10:14:27 CST 2021
Display ID : DRA-LX5 1.0.0.130(C316)
Security Patch : 2020-10-01
Version SDK : 27
Firmware Version : 1.0.0.130(C316)
Read partition "frp"... OK
Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Huawei_DRA-LX5%20(Y5%20(2018))/FRP_BACKUP_(2022-1-16_14-25-56)/"directory
Format "frp" partition... OK
Writting FRP data... OK
Erase FRP done!
Old 01-19-2022, 11:33   #83 (permalink)
Member: 2534995
Thanks Meter: 96
Vodafone Smart_C9 VFD320 FRP done!
Selected model: Mediatek Mediatek
Host Power On... OK
Device found at COM40 [BROM]
Open port... OK
Library Version [1]
Init BROM... OK
Force Charge... OK
ME_ID = 0xB3ECC356, 0x678BBB42, 0xB9C8D67B, 0x3DE595A7
Set params... OK
EMMC_ID: 0x4500017044453445DD20013443B5D23A
Init DRAM... OK
Enable DRAM... OK
Sync with DA... OK
EMMC INFO:
EMMC_ID : 0x7001004545344544340120DD3AD2B543
EMMC_BOOT1: 0x0000200000 (2.00Mb)
EMMC_BOOT2: 0x0000200000 (2.00Mb)
EMMC_RPMB : 0x0000080000 (512.00Kb)
EMMC_USER : 0x00E2000000 (3.53Gb)
RAM INFO:
EXT_RAM : 0x0020000000 (512.00Mb)
High Speed USB detected at COM63
Open port... OK
Product Brand : Vodafone
Product Manufacturer : Vodafone
Product Model : VFD320
Product Name : Smart_C9
Product Device : VFD320
Product Board : MT6580M
Board Platform : MTK6580_8.1
Build ID : O11019
Build Date : 2018年 12月 27日 星期四 18
Display ID : O11019 release-keys
Security Patch : 2018-11-05
Version SDK : 27
Firmware Version : 1545905526
Read partition frp... OK
Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Mediatek_MT6580/FRP_BACKUP_(2022-1-19_12-28-37)/"directory
Erase FRP done!
Old 01-20-2022, 08:09   #84 (permalink)
Member: 2534995
Thanks Meter: 96
STYLO S53 STARK FRP done!
Host Power On... OK
Open port... OK
Library Version [1]
Init BROM... OK
Force Charge... OK
ME_ID = 0xE17B67A2, 0xFFF4F077, 0xA1DB9A89, 0x60913AE3
Set params... OK
EMMC_ID: 0x38000115344654472F400352AD95394F
Init DRAM... OK
Enable DRAM... OK
Sync with DA... OK
EMMC INFO:
EMMC_ID : 0x15010038475446345203402F4F3995AD
EMMC_USER : 0x01D2000000 (7.28Gb)
RAM INFO:
Open port... OK
Product Brand : STYLO
Product Manufacturer : STYLO
Product Model : S53_STARK
Product Name : S53_STARK
Product Device : S53_STARK
Product Board : STARK
Build ID : O11019
Build Date : Tue Oct 9 20:48:13 CST 2018
Display ID : w48_jingwei_W534_Telma_user_V4.0
Security Patch : 2018-10-05
Version SDK : 27
Firmware Version : 1539089293
Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Mediatek_MT6580/FRP_BACKUP_(2022-1-20_8-38-39)/"directory
Erase FRP done!
Old 01-24-2022, 13:22   #85 (permalink)
Member: 1038150
Thanks Meter: 45
OPPO CPH1909 (Oppo A5s)
Selected model: OPPO CPH1909 (Oppo A5s)
Operation: Repair
Host Power On... OK
Device found at COM28 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x14193733, 0x6ED70C15, 0x564476DF, 0xD25F7EEE
Get SOC ID... [ADDBF83879A9421C472E33D88496A48B2390B40094993D8F81 8BF45C30143B93]
EMMC_ID: 0x150100474436424D42017E72D383B621
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x150100474436424D42017E72D383B621
RAM INFO:
INT_SRAM: 0x000003A000 (232.00Kb)
EXT_RAM : 0x00C0000000 (3.00Gb)
Build ID : O11019
Build Date : Fri Mar 19 19:45:31 CST 2021
Security Patch : 2021-04-05
Version SDK : 27
Read IMEI... OK
IMEI 1: 8685*******1730
IMEI 2: 868505******1730
Repairing IMEI...
IMEI 1: 86385******83697
IMEI 2: 863859******3705
Load partiton for patching... OK OK
Save patched partiton... OK
Unlock bootloader... OK
Old 01-24-2022, 13:28   #86 (permalink)
Member: 1038150
Thanks Meter: 45
2 out of 2 hassle free thank you pandora team
Operation: Repair
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x565ECD00, 0x0A1B9399, 0x91D6C0CD, 0xDDEC1CF5
Get SOC ID... [8ED1AE5A096FE9EF9BAAD7FB427A7E5125EC59D0E132868F3A CA1F01D5492E0F]
EMMC_ID: 0x90014A68423861503E0362C2E4D09649
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x90014A68423861503E0362C2E4D09649
EMMC_RPMB : 0x0001000000 (16.00Mb)
RAM INFO:
Build ID : O11019
Version SDK : 27
Read IMEI... OK
IMEI: 86850*******01350
Repairing IMEI...
IMEI: 863859******3705
Old 01-24-2022, 14:29   #87 (permalink)
Member: 1038150
Thanks Meter: 45
OPPO CPH2083 (Oppo A12) REPAİR DONE
Selected model: OPPO CPH2083 (Oppo A12)
Operation: Repair
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x1225F449, 0x2FFF843A, 0xF41B6B98, 0x40490A6C
Get SOC ID... [04640A9D355111DC9FA9BF6ACB761B1E255FD67D48B4A5D68E 767E2B807EE194]
EMMC_ID: 0x90014A68423861503E03508748AB27A9
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x90014A68423861503E03508748AB27A9
RAM INFO:
Product Board : oppo6765_19451
Build ID : PPR1.180610.011
Build Date : Tue Nov 9 20:25:52 CST 2021
Security Patch : 2021-11-05
Version SDK : 28
Version Release : 9
Read IMEI... OK
IMEI: 8687*******80891
Repairing IMEI...
IMEI: 86385*******3713
Old 01-25-2022, 08:03   #88 (permalink)
Member: 2518014
Thanks Meter: 43
hello pandora team
im repair security oppo reno 2f after repair security phone stack on logo
plz fix this problem
Host Power On... OK
Get HW code from device... 0788
Detect chip [MT6771]
Device found at COM71 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x40A98621, 0x4CAF8893, 0xBA6E8B62, 0xBADE8D29
Get Chip ID... [MT6771]
Get SOC ID... [30AE5D79C1C2D98972A4029E4D476B1C1E9AB0EC9D4A60D5F4 5C03D0CB76BE85]
Search DA... OK [20]
UFS CID (FW VER): KM8V7001JM-B810 (0900)
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_CID : KM8V7001JM-B810
UFS_FWVER : 0900
BLOCK_SIZE: 0x0000001000 (4.00Kb)
UFS_LU0 : 0x0000400000 (4.00Mb)
UFS_LU1 : 0x0000400000 (4.00Mb)
UFS_LU2 : 0x1DCB000000 (119.17Gb)
RAM INFO:
INT_SRAM: 0x0000039000 (228.00Kb)
EXT_RAM : 0x0200000000 (8.00Gb)
Product Brand : alps
Product Manufacturer : alps
Product Model : oplus_mssi_64_cn
Product Name : sys_oplus_mssi_64_cn
Product Device : oplus_mssi_64_cn
Product Board : oppo6771
Board Platform : MT6771
Build ID : RP1A.200720.011
Build Date : Sat Oct 16 04:27:24 CST 2021
Display ID : RP1A.200720.011 release-keys
Security Patch : 2021-10-05
Version SDK : 30
Version Release : 11
Firmware Version : 1634328910487
Read IMEI... OK
IMEI 1: 86xxxxxxxxxxxxxx
IMEI 2: 86xxxxxxxxxxxxxx
Repairing IMEI...
IMEI 2: 863xxxxxxxxxxxx
Old 01-26-2022, 12:04   #89 (permalink)
Member: 2534995
Thanks Meter: 96
itel-S32 FRP Done Pandora Box
High Speed USB detected at COM0
Open port... OK
Product Brand : Itel
Product Manufacturer : itel
Product Model : itel S32
Product Name : I805
Product Device : itel-S32
Build ID : NRD90M
Build Date : Tue May 29 11:05:39 CST 2018
Display ID : S32-I805-7.0-OP-V035-20180529
Security Patch : 2018-05-05
Version SDK : 24
Version Release : 7.0
Firmware Version : 1527563149
Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Mediatek_MT6580/FRP_BACKUP_(2022-1-26_9-40-59)/"directory
Erase FRP done!
Old 01-26-2022, 12:14   #90 (permalink)
siang8788's Avatar
Member: 205283
Thanks Meter: 81
rmx3195 imei repair done!
Selected model: Realme RMX3195 (Realme C25s)
Operation: Repair
Software version: 2.11
Host Power On... OK
Get HW code from device... 0707
Detect chip [MT6768]
Device found at COM21 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x9A9FDFA3, 0xC7D84720, 0x4851238A, 0xAF84FF38
Get Chip ID... [MT6768]
Get SOC ID... [431AE84A4309F9B0A9DE40CD04F42E02E2EDDCB657573337CB 97F230C78AFBDC]
Search DA... OK [25]
EMMC_ID: 0x150100445636444142027DF0CA204895
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x150100445636444142027DF0CA204895
EMMC_USER : 0x1D1EC00000 (116.48Gb)
RAM INFO:
INT_SRAM: 0x0000070000 (448.00Kb)
Product Board : oppo6769
Board Platform : MT6768
Build Date : Tue May 11 13:24:05 CST 2021
Version SDK : 30
Firmware Version : mp1tc16sppr4V1
Repairing IMEI...
IMEI 1: 86402xxxxxxxxxx
IMEI 2: 86402xxxxxxxxxx
If your phone after repair keeps rebooting - use wipe data option.
Page generated in 0.37935 seconds with 9 queries
