03-14-2023, 22:46 | #1 (permalink) |
Junior Member Join Date: Jan 2023 Location: dhaka bangladesh Age: 31
Member: 3028916 Status: Offline Sonork: 100.650600 Thanks Meter: 1 | Realme 8 5g network repair Pandora's [Answered] |
03-25-2023, 00:43 | #3 (permalink) |
Member: 3028916 Status: Offline Sonork: 100.650600 Thanks Meter: 1 | Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6833 Board Platform : MT6833 Build ID : RP1A.200720.011 Build Date : Tue Apr 20 17:03:49 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1618908511562 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 866547868775761 IMEI 2: 866547868775795 Write IMEI [NVDATA]... OK Checking patch type... [2] Load partiton for patching... OK Patching CERT... OK Save patched partiton... OK Read partitions info from phone... OK Checking A/B state... OK Read security partition from phone... OK Decrypting security data... OK Encrypt security data... OK Write security partition to phone... OK Checking additional lock... [DISABLED] Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Selected model: Realme RMX3241 (Realme 8 5G) Operation: Repair Software version: 4.8 Work ID: 1134709 |
03-29-2023, 09:43 | #5 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2583168 Status: Offline Thanks Meter: 0 | After restoring my IMEI, it freezes on the screensaver. The device was originally brought with a black display. DUMP was stitched from the support area. The device began to turn on. The firmware of the earliest version that I could find (A 12) was flooded. Program version 4.8. Help solve my problem! |
03-29-2023, 10:07 | #6 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,065 | Quote:
03-29-2023, 11:43 | #7 (permalink) |
Member: 2583168 Status: Offline Thanks Meter: 0 | I tried the firmware versions A12, A18, A21, A24. After the firmware, the IMEI hangs on the yellow Realme label. Moreover, even when you restore nv data and nvram files from Backup, nothing changes. It starts only after the firmware via the Update function |
03-29-2023, 12:16 | #8 (permalink) |
Member: 2583168 Status: Offline Thanks Meter: 0 | On the A 24 firmware, the phone rebooted after a long freeze, wrote that the data was damaged and needed to be reset. After resetting the IMEI appeared, but the phone does not catch the network. How can I fix it? |
02-02-2024, 13:17 | #12 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | Quote:
Restored original backup and same problem. Can't return the phone to it original status. Seems to be something related to RSA verification of NVRAM. Code: Selected model: Realme RMX3241 (Realme 8 5G) Operation: Repair Software version: 6.3 Connect Type-C to NONE... OK Host Power Off... OK Connect phone to [PC] in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM10 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Release testpoint, waiting 2 seconds Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM10 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xA732416C, 0x26E5041A, 0x32748E71, 0x96D38A58 Get Chip ID... [MT6833] Get SOC ID... [5E05F89577A82B89DE413D08B944ADBA70F9D1F203AF985BA42993D72BFC5486] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [14] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15ACPMBDAR (A002) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15ACPMBDAR UFS_FWVER : A002 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK Read product info... [EXT4] ... OK Product Brand : alps Product Manufacturer : alps Product Model : RMX3241 Product Name : vnd_oppo6833 Product Device : oppo6833 Product Board : oppo6833 Board Platform : mt6833 Build ID : RP1A.200720.011 Build Date : Tue Apr 20 17:03:49 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1618908511562 Userdata FS Type : F2FS Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 35...... IMEI 2: 35...... Write IMEI and patch CERT [NVDATA]... OK Checking patch type... [2] Load partiton for patching... OK Patching CERT... already patched, skip Read security partition from phone... OK Decrypting security data... OK Encrypt security data... OK Write security partition to phone... OK Checking additional lock... [DISABLED] Write IMEI and patch CERT [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security and Patch cert done! If your phone after repair keeps rebooting - use wipe data option. | |
