Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 03-02-2022, 11:00   #1 (permalink)
Member: 2758069
Thanks Meter: 40
realme pad can add repair imei? [Answered]
Host Power Off... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Connect phone to BOX in BROM mode
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Send start cmd... OK
Get HW code from device... 0707
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6768]
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Connect Type-C to HUB... OK
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0]
Device found at COM3 [BROM]
Open port... OK
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0x104599CC, 0xCF968191, 0x4A411680, 0xE6A3919E
Get Chip ID... [MT6768]
Get SOC ID... [3432722FCBE259234989D600CCA3010BF4ECF7468442FAEEED 879D4699670A5D]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [8]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x6B01014D4D43333247510119F91A48AF
Load EMI from phone... Skip
Load EMI config from database [DB VER: 203 DB DATE: 02-22-2022] OK [1]
Trying EMI [703B5CDE, F83EEC01, B772E8DA, 4C76F2A3, 40457DA8, D8F5BD39, AD4E4796, 7805E65B, 44724C4B, 89B4F298, 148572B4, 85DF9841, 10D75741, 4ECF8C5A, F1ADA01B, 667E0B28, 1A304479, 154C2947, C8B7B877]
Init EXT RAM... error(2)
Old 03-02-2022, 11:04   #2 (permalink)
Member: 2758069
Thanks Meter: 40
Selected model: Realme RMX3195 (Realme C25s)
Operation: Repair
Software version: 2.12
Switch virtual port to NONE... OK
Host Power On... OK
Connect phone to BOX in BROM/PRELOADER Mode
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Force switch to BROM... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [8]
Init EXT RAM... error(6)
Old 03-02-2022, 11:45   #3 (permalink)
Z3X
Member: 706257
Thanks Meter: 4,987
Hello. Download firmware, choose it, untick read emi from phone and repeat operation. Post result.
Also tape device RMX here.
Old 03-02-2022, 15:07   #4 (permalink)
Member: 2758069
Thanks Meter: 40
RMP2102 can flash can't repair imei
Old 03-02-2022, 15:09   #5 (permalink)
Member: 2758069
Thanks Meter: 40
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [8]
Load EMI config from preloader... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x6B01014D4D43333247510119F91A48AF
EMMC_BOOT1: 0x0000400000 (4.00Mb)
EMMC_BOOT2: 0x0000400000 (4.00Mb)
EMMC_RPMB : 0x0000400000 (4.00Mb)
EMMC_USER : 0x0747C00000 (29.12Gb)
RAM INFO:
INT_SRAM: 0x0000070000 (448.00Kb)
EXT_RAM : 0x0100000000 (4.00Gb)
Get scatter info... OK
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Check A/B state... OK
Read product info... OK
Product Brand : realme
Product Manufacturer : realme
Product Model : RMP2102
Product Name : RMP2102
Product Device : RE54C1L1
Product Board : oppo8786
Board Platform : MT6768
Build ID : RP1A.200720.011
Build Date : Wed Jan 26 17:12:58 CST 2022
Display ID : RMP2102_11_A.05
Security Patch : 2022-01-05
Version SDK : 30
Version Release : 11
Version Codename : REL
Firmware Version : 1638845703331
Read partition "nvdata"... OK
Read partition "nvram"... OK
Read NVDATA files... OK
Read NVRAM files... OK
Read IMEI... error
Repairing IMEI...
IMEI 1: 865645343543548
IMEI 2: 864565456435137
Write IMEI [NVDATA]... OK
Write IMEI [NVRAM]... OK
Write partition "nvdata"... OK
Repair Security done!
Old 03-02-2022, 15:10   #6 (permalink)
Member: 2758069
Thanks Meter: 40
Selected model: Mediatek Mediatek
Operation: Read IMEI Info
Parse scatter file... OK
Load Rom Images... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [8]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Version SDK : 30
Read IMEI... error
NVDATA corrupted!
Old 03-02-2022, 15:12   #7 (permalink)
Z3X
Member: 706257
Thanks Meter: 4,987
Please read partitions backup (except userdata and cache) and attach them. We will recheck possibility.
Old 03-02-2022, 16:52   #8 (permalink)
Member: 2758069
Thanks Meter: 40
Look forward to your good news
https://drive.google.com/file/d/17fO...Imp5lBj7d/view
The Following User Says Thank You to chenyongming For This Useful Post:
Old 04-01-2022, 08:53   #9 (permalink)
Z3X
Member: 706257
Thanks Meter: 4,987
Hello. Try with 3.3 and post result.
Old 04-04-2022, 07:30   #10 (permalink)
Member: 2861102
why the board firware update to stock firmwre after baseband version is unknow and it can"t write imei
Old 04-04-2022, 07:47   #11 (permalink)
Z3X
Member: 706257
Thanks Meter: 4,987
Hello. Restore original backup.
Old 04-07-2022, 09:47   #12 (permalink)
Member: 2861102
It doesn't work
When it was board firmware, I successfully wrote IMEI, but after I updated it to the normal firmware, the baseband disappeared and the recovery backup did not work, and the IMEI disappeared
Old 04-07-2022, 09:48   #13 (permalink)
Z3X
Member: 706257
Thanks Meter: 4,987
Try flash another firmware.
Old 04-08-2022, 07:12   #14 (permalink)
Member: 2861102
Post reamle 2012 can"t reapir IMEI
Selected model: Realme RMP2102 (Realme Pad)
Operation: Repair META
Software version: 3.3
CURRENT IMEI:
IMEI1 = EMPTY
IMEI2 = EMPTY
Set IMEI 1 to 867153323323203... error 7 Operation timeout
Old 04-08-2022, 16:07   #15 (permalink)
Member: 2861102
CURRENT IMEI:
IMEI1 = EMPTY
IMEI2 = EMPTY
Page generated in 0.22011 seconds with 8 queries
