Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2017 Location: china
Member: 2758069 Status: Offline Thanks Meter: 40 | realme pad can add repair imei? [Answered] Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x104599CC, 0xCF968191, 0x4A411680, 0xE6A3919E Get Chip ID... [MT6768] Get SOC ID... [3432722FCBE259234989D600CCA3010BF4ECF7468442FAEEED 879D4699670A5D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x6B01014D4D43333247510119F91A48AF Load EMI from phone... Skip Load EMI config from database [DB VER: 203 DB DATE: 02-22-2022] OK [1] Trying EMI [703B5CDE, F83EEC01, B772E8DA, 4C76F2A3, 40457DA8, D8F5BD39, AD4E4796, 7805E65B, 44724C4B, 89B4F298, 148572B4, 85DF9841, 10D75741, 4ECF8C5A, F1ADA01B, 667E0B28, 1A304479, 154C2947, C8B7B877] Init EXT RAM... error(2) |
![]() | #2 (permalink) |
Member: 2758069 Status: Offline Thanks Meter: 40 | Selected model: Realme RMX3195 (Realme C25s) Operation: Repair Software version: 2.12 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x104599CC, 0xCF968191, 0x4A411680, 0xE6A3919E Get Chip ID... [MT6768] Get SOC ID... [3432722FCBE259234989D600CCA3010BF4ECF7468442FAEEED 879D4699670A5D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x6B01014D4D43333247510119F91A48AF Load EMI config from database [DB VER: 203 DB DATE: 02-22-2022] OK [1] Trying EMI [703B5CDE, F83EEC01, B772E8DA, 4C76F2A3, 40457DA8, D8F5BD39, AD4E4796, 7805E65B, 44724C4B, 89B4F298, 148572B4, 85DF9841, 10D75741, 4ECF8C5A, F1ADA01B, 667E0B28, 1A304479, 154C2947, C8B7B877] Init EXT RAM... error(6) |
![]() | #5 (permalink) |
Member: 2758069 Status: Offline Thanks Meter: 40 | Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x104599CC, 0xCF968191, 0x4A411680, 0xE6A3919E Get Chip ID... [MT6768] Get SOC ID... [3432722FCBE259234989D600CCA3010BF4ECF7468442FAEEED 879D4699670A5D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x6B01014D4D43333247510119F91A48AF Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x6B01014D4D43333247510119F91A48AF EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : realme Product Manufacturer : realme Product Model : RMP2102 Product Name : RMP2102 Product Device : RE54C1L1 Product Board : oppo8786 Board Platform : MT6768 Build ID : RP1A.200720.011 Build Date : Wed Jan 26 17:12:58 CST 2022 Display ID : RMP2102_11_A.05 Security Patch : 2022-01-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1638845703331 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... error Repairing IMEI... IMEI 1: 865645343543548 IMEI 2: 864565456435137 Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Repair Security done! |
![]() | #6 (permalink) |
Member: 2758069 Status: Offline Thanks Meter: 40 | Selected model: Mediatek Mediatek Operation: Read IMEI Info Software version: 2.12 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x104599CC, 0xCF968191, 0x4A411680, 0xE6A3919E Get Chip ID... [MT6768] Get SOC ID... [3432722FCBE259234989D600CCA3010BF4ECF7468442FAEEED 879D4699670A5D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x6B01014D4D43333247510119F91A48AF Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x6B01014D4D43333247510119F91A48AF EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : realme Product Manufacturer : realme Product Model : RMP2102 Product Name : RMP2102 Product Device : RE54C1L1 Product Board : oppo8786 Board Platform : MT6768 Build ID : RP1A.200720.011 Build Date : Wed Jan 26 17:12:58 CST 2022 Display ID : RMP2102_11_A.05 Security Patch : 2022-01-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1638845703331 Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... error NVDATA corrupted! |
![]() | #8 (permalink) | |
Member: 2758069 Status: Offline Thanks Meter: 40 | Quote:
https://drive.google.com/file/d/17fO...Imp5lBj7d/view | |
The Following User Says Thank You to chenyongming For This Useful Post: |
![]() | #15 (permalink) |
Junior Member ![]() Join Date: Aug 2018
Member: 2861102 Status: Offline Thanks Meter: 1 | Selected model: Realme RMP2102 (Realme Pad) Operation: Repair META Software version: 3.3 CURRENT IMEI: IMEI1 = EMPTY IMEI2 = EMPTY Set IMEI 1 to 867153323323203... error 7 Operation timeout |
