06-06-2022, 06:09 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Realme RMX3430 after Repair boot image corrupted [Answered] Operation: Repair Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM7 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x69BEFF14, 0x1409BC53, 0x9007D431, 0x9C1E1188 Get Chip ID... [MT6768] Get SOC ID... [CFF54518D02E8A9939599285D2710CFA4AD1EBAC1A9E7952D2 29D53FF6956E21] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x15010044563644414202689DFAACA837 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x15010044563644414202689DFAACA837 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6769 Board Platform : MT6768 Build ID : RP1A.200720.011 Build Date : Sun May 8 18:15:37 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-05-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 0mp3k6833v164P6 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 35512aaaaaaaaaaaaaa IMEI 2: 355125aaaaaaaaaaaaaa Write IMEI [NVDATA]... OK Load partiton for patching... OK Patching CERT... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option |
06-06-2022, 07:58 | #4 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | RMX3430_11_A.11_ RMX3430_EX_11_A.06 RMX3430_EX_11_A.09 try with this file but not Repair same problem corropted image (boot/recovery) |
06-06-2022, 11:48 | #10 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Operation: Write OFP Software version: 3.5 Extract scatter file... OK Read super info... OK Parse scatter file... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x69BEFF14, 0x1409BC53, 0x9007D431, 0x9C1E1188 Get Chip ID... [MT6768] Get SOC ID... [CFF54518D02E8A9939599285D2710CFA4AD1EBAC1A9E7952D2 29D53FF6956E21] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x15010044563644414202689DFAACA837 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x15010044563644414202689DFAACA837 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6769 Board Platform : MT6768 Build ID : RP1A.200720.011 Build Date : Wed Feb 23 19:06:59 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-02-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 0mp3k6833v164P6 Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Check partition table layout changed... OK Read major partition table... OK Check major partition table layout changed... OK Download "preloader"... OK Download "recovery"... OK Download "opporeserve2"... OK Download "vbmeta"... OK Download "vbmeta_system"... OK Download "vbmeta_vendor"... OK Download "cdt_engineering"... OK Download "logo"... OK Download "md1img"... OK Download "spmfw"... OK Download "scp1"... OK Download "scp2"... OK Download "sspm_1"... OK Download "sspm_2"... OK Download "gz1"... OK Download "gz2"... OK Download "lk"... OK Download "lk2"... OK Download "boot"... OK Download "dtbo"... OK Download "tee1"... OK Download "tee2"... OK Download "super" part 1... OK Download "super" part 2... OK Download "super" part 3... OK Download "cache"... OK Download "userdata"... OK Flashing done Mobile phone fully on but imei blank when Repair imei same problem only show corropted image (boot/recovery) Selected model: Realme RMX3430 (Realme Narzo 50A) Operation: Flash (Download only) Software version: 3.5 File(s) not selected Selected model: Realme RMX3430 (Realme Narzo 50A) Operation: Repair Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... error(2) Selected model: Realme RMX3430 (Realme Narzo 50A) Operation: Repair Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x69BEFF14, 0x1409BC53, 0x9007D431, 0x9C1E1188 Get Chip ID... [MT6768] Get SOC ID... [CFF54518D02E8A9939599285D2710CFA4AD1EBAC1A9E7952D2 29D53FF6956E21] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [8] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x15010044563644414202689DFAACA837 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x15010044563644414202689DFAACA837 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6769 Board Platform : MT6768 Build ID : RP1A.200720.011 Build Date : Thu Oct 28 11:24:04 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-10-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 0mp3k6833v164P6 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI...zzzzzzzzzzzz IMEI 1: 35512511zzzzzzzzzz Write IMEI [NVDATA]... OK Load partiton for patching... OK Patching CERT... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. |
06-06-2022, 11:51 | #11 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | https://easy-firmware.com/index.php?...file&id=389237 please unlock this link |
06-07-2022, 08:30 | #14 (permalink) | |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Quote:
