Member: 383211
Thanks Meter: 131 | redmi 10 prime 21061119BI after repair imei ,mobile rebooting [Answered] redmi 10 prime 21061119BI after repair imei ,mobile rebooting.i also wipe data but first show nv data corrupt.after patch and wipe data.but mobile rebooting. then write firmware .then mobile go to normal and working but imei not repaired
repair Quote:
Selected model: Xiaomi 21061119BI (Redmi 10 Prime)
Operation: Repair
Software version: 3.7
Host Power Off... OK
Switch virtual port to NONE... OK
Connect Type-C to HUB... OK
Host Power On... OK
Connect phone to BOX in BROM/PRELOADER Mode
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0]
Device found at COM34 [BROM]
Open port... OK
Send start cmd... OK
Get HW code from device... 0707
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6768]
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Force switch to BROM... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Get sec config... OK [000000E7]
Active sec flags: [SBC SLA DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0xE69BF93F, 0x72EB614E, 0x9BE2D7E7, 0x81D5A0B5
Get Chip ID... [MT6768]
Get SOC ID... [ACC74CE025AAA87035E0B8132840808A17AB830AB45E06CA48 6AC6CA32B4A309]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [8]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x90014A68444561503303103D118F683B
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x90014A68444561503303103D118F683B
EMMC_BOOT1: 0x0000400000 (4.00Mb)
EMMC_BOOT2: 0x0000400000 (4.00Mb)
EMMC_RPMB : 0x0001000000 (16.00Mb)
EMMC_USER : 0x1D1F000000 (116.48Gb)
RAM INFO:
INT_SRAM: 0x0000070000 (448.00Kb)
EXT_RAM : 0x0100000000 (4.00Gb)
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Check A/B state... OK [B]
Read product info... OK
Product Brand : Redmi
Product Manufacturer : Xiaomi
Product Model : 21061119AG
Product Name : selene
Product Device : selene
Product Board : selene
Board Platform : MT6768
Build ID : RP1A.200720.011
Build Date : Fri Mar 4 18:04:20 CST 2022
Display ID : AL5186-selene-build-202203041802
Security Patch : 2022-02-01
Version SDK : 30
Version Release : 11
Version Codename : REL
Firmware Version : V12.5.8.0.RKUINXM
Read partition "nvdata"... OK
Read partition "nvram"... OK
Read NVDATA files... OK
Read NVRAM files... OK
Read IMEI... OK
IMEI 1: 865
IMEI 2: 86
Repairing IMEI...
IMEI 1: 86
IMEI 2: 86
Write IMEI [NVDATA]... OK
Write IMEI [NVRAM]... OK
Write partition "nvdata"... OK
Write partition "nvram"... OK
Repair Security done!
If your phone after repair keeps rebooting - use wipe data option.
Now use "Patch Cert" option to comlete repair.
Operation: Repair
Host Power On... OK
Wait for device connecting... timeout
Operation: Repair
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [8]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Version SDK : 30
Read IMEI... OK
IMEI 1: 86****
IMEI 2: 86****
Repairing IMEI...
IMEI 1: 86***
IMEI 2: 864*********
Operation: Repair
Host Power On... OK
Device found at COM17 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [8]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Check A/B state... OK [A]
Build Date : Tue Aug 10 00:54:59 CST 2021
Display ID : AL5186-selene-build-202108100052
Security Patch : 2021-07-01
Version SDK : 30
Firmware Version : V12.5.1.0.RKUINXM
Read IMEI... OK
IMEI 1: 86
IMEI 2: 86
Repairing IMEI...
IMEI 1: 3593
IMEI 2: 351
Now use "Patch Cert" option to complete repair. | Patch Quote:
Operation: Patch CERT
Host Power On... OK
Wait for device connecting... canceled
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [8]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Version SDK : 30
Load partiton for patching... OK
Check modem patch possiblity... POSSIBLE WITH BOOT UNLOCK
Patching CERT... OK
Save patched partiton... OK
Format "parameter" partition... OK
Patch cert done!
Host Power On... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [8]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Version SDK : 30
Patching CERT... OK
Patch cert done!
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [8]
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Version SDK : 30
Patching CERT... OK
Patch cert done!
If your phone after repair keeps rebooting - use wipe data option. | firmware writing Quote:
Operation: Flash (Download only)
Parse scatter file... OK
Load Rom Images... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Search DA... OK [8]
Load EMI config from preloader... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
RAM INFO:
Get scatter info... OK
Version SDK : 30
Verify scatter file... OK
Do NAND BMT remark... OK
Setup download info... OK
Get partition table catagory... OK [GPT]
Read mirror partition table... OK
Check partition table layout changed... OK
Read major partition table... OK
Check major partition table layout changed... OK
Download "preloader"... OK
Download "vbmeta_a"... OK
Download "vbmeta_system_a"... OK
Download "vbmeta_vendor_a"... OK
Download "md1img_a"... OK
Download "spmfw_a"... OK
Download "scp_a"... OK
Download "sspm_a"... OK
Download "lk_a"... OK
Download "boot_a"... OK
Download "dtbo_a"... OK
Download "tee_a"... OK
Download "logo_a"... OK
Download "cust"... OK
Download "rescue"... OK
Download "super"... OK
Download "userdata"... OK
Flashing done! |
Reason: hide imei number
