06-04-2021, 19:28 | #5 (permalink) |
Insane Poster Join Date: Nov 2014 Location: indonesia
Member: 2302504 Status: Offline Thanks Meter: 12 | yes, problem solved. usb cable damage. unlock bootloader. DONE Selected model: Xiaomi M2004J19G (Redmi 9) Operation: Unlock bootloader Software version: 1.12 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM50 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x42C13417, 0x42106612, 0x8BC13F26, 0xCA4681FE Get Chip ID... [MT6768] Get SOC ID... [1391B2799D89FD614A381ABDD9AD30E03BDFC7711BA60CF141 1CB02D09FDF6E4] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68423861503E03001B306BB7E7 Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68423861503E03001B306BB7E7 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0747C00000 (29,12Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Decrypt security data... OK Encrypt security data... OK Write security partition to phone... OK Unlock bootloader done! |
12-07-2021, 11:30 | #11 (permalink) |
Freak Poster Join Date: Nov 2007 Location: ukraine lviv
Member: 624189 Status: Offline Thanks Meter: 4 | i already do that phone. when problem will repeat i will make video and photo. in my opinion, problem is in bad connect between box type-c connector and cable. |
12-08-2021, 22:59 | #12 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | Yes Pandora box has a general connection problem but always changing the USB connection between the phone and box solves the issue. Yet if you connect phone direct to pc it will be detected well |
