08-10-2021, 02:38 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: CUBA Age: 32
Member: 2108610 Status: Offline Thanks Meter: 379 | Redmi 9A Init EXT RAM... error(6) when try flash Operation: Flash (Download only) Software version: 2.2 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM8 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xF36C7DE2, 0xFF5C12A4, 0x002A2192, 0xD2AC9D83 Get Chip ID... [MT6765] Get SOC ID... [A15505E34FC55647E0CA0A1B9DCAF5DD95419CB41E59F55104 E84652A341F16C] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100424A544434520999138E7D8789 Load EMI config from preloader... OK Init EXT RAM... error(6) I try flash firmware stock 12.0.3 12.0.11 & EngRom rev1 rev2, ever same error |
The Following User Says Thank You to yosbel182us For This Useful Post: |
08-10-2021, 02:48 | #2 (permalink) | |
Member: 2108610 Status: Offline Thanks Meter: 379 | Success Flash after relock bootloader Quote:
06-29-2022, 19:21 | #5 (permalink) |
Junior Member Join Date: May 2013
Member: 1935111 Status: Offline Thanks Meter: 0 | With any attempt to read data or sections from the phone, this error. What am I doing wrong? Selected model: Xiaomi M2006C3LG (Redmi 9A) Operation: Read Flash Info Software version: 3.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xD4EA32CE, 0xF42A498D, 0x452A8580, 0x147C611B Get Chip ID... [MT6765] Get SOC ID... [7CD62A7F5BA88B3C35C4CA6B6D3F3447E4DC3570787FD85CDC 00C55B1D7AAD66] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100424A544434520910F346B59781 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... error(6) |
06-29-2022, 19:31 | #6 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Online Thanks Meter: 5,056 | Hello. Seems like preloader incompatible. Unchoose scatter, read preloader from phone, replace in firmware folder and try flash again. |
The Following User Says Thank You to Z3X For This Useful Post: |
06-29-2022, 20:00 | #11 (permalink) |
Member: 1935111 Status: Offline Thanks Meter: 0 | Selected model: Xiaomi M2006C3LG (Redmi 9A) Operation: Read PTT Software version: 3.7 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xD4EA32CE, 0xF42A498D, 0x452A8580, 0x147C611B Get Chip ID... [MT6765] Get SOC ID... [7CD62A7F5BA88B3C35C4CA6B6D3F3447E4DC3570787FD85CDC 00C55B1D7AAD66] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100424A544434520910F346B59781 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... error(6) |
06-30-2022, 09:49 | #13 (permalink) |
Member: 1935111 Status: Offline Thanks Meter: 0 | Selected model: Xiaomi M2006C3LG (Redmi 9A) Operation: Read PTT Software version: 3.7 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x9E7A8E75, 0xCCACE8BA, 0xD41E255C, 0x64594C27 Get Chip ID... [MT6765] Get SOC ID... [D6ADEBD6EEB50A8635E3CB0ABC76255695166F47C24AE96297 1A799001E50368] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x4501004441343033320178A51C156725 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... error(6) With any phone and firmware. Three different phones. One with an account. Others just flash. There is a mistake everywhere. At the same time, unlock tool and cm2 did everything from 1 time. Somehow it’s not right for such an expensive box. |
06-30-2022, 18:16 | #15 (permalink) |
Member: 1935111 Status: Offline Thanks Meter: 0 | https://t.me/Drug65 telegram contact.if you meant it |
