03-13-2023, 16:45 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | redmi note 10 5G unknown imei repair failed [Answered] Operation: Repair Software version: 4.7 Work ID: 919920 Connect phone in BROM Mode Waiting for device... OK Driver: [Sony Mobile Communications,usbser,MTK USB Port,usbser.sys,10.0.19041.2130] Device found at COM19 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 LibUSB installed Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Advanced Bypass Security... OK Waiting for device... OK Driver: [Sony Mobile Communications,usbser,MTK USB Port,usbser.sys,10.0.19041.2130] Device found at COM19 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 LibUSB installed Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xE096C619, 0x2F49A0E6, 0x8C7BC62F, 0xA05824C9 Get Chip ID... [MT6833] Get SOC ID... [C62A8106718CD7BECCBF7C1C7E6EC34D113390BD2E0954A779 B9037D90A51811] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [14] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): MT128GASAO4U21 (0605) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT128GASAO4U21 UFS_FWVER : 0605 BLOCK_SIZE: 0x0000001000 (4,00Kb) UFS_LU0 : 0x0000400000 (4,00Mb) UFS_LU1 : 0x0000400000 (4,00Mb) UFS_LU2 : 0x1DCB000000 (119,17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK [A] Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : M2103K19C Product Name : camellia Product Device : camellia Product Board : camellia Board Platform : connac1x Build ID : SP1A.210812.016 Build Date : Wed Dec 28 13:25:49 CST 2022 Display ID : AN3516-camellia-build-2022122813 Security Patch : 2022-12-01 Version SDK : 31 Version Release : 12 Version Codename : REL Firmware Version : V13.0.5.0.SKSMIXM Read partition "nvdata"... error(8), skip Read partition "nvram"... error(2), skip Read NVDATA files... OK Read NVRAM files... OK Read IMEI... error Repairing IMEI... IMEI 1: 86xxxxxxxxxxxxxx IMEI 2: 86xxxxxxxxxxxxxx Write IMEI [NVDATA]... error(1) |
03-14-2023, 11:13 | #3 (permalink) |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | now repair done patch cert unknown xiaomi model! and still imei unknown Selected model: Xiaomi Redmi Note 10 5G (China) (Camellia) Operation: Repair Software version: 4.7 Work ID: 933445 Connect phone in BROM Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM13 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 LibUSB installed Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM13 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 LibUSB installed Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xE096C619, 0x2F49A0E6, 0x8C7BC62F, 0xA05824C9 Get Chip ID... [MT6833] Get SOC ID... [C62A8106718CD7BECCBF7C1C7E6EC34D113390BD2E0954A779 B9037D90A51811] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [14] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): MT128GASAO4U21 (0605) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT128GASAO4U21 UFS_FWVER : 0605 BLOCK_SIZE: 0x0000001000 (4,00Kb) UFS_LU0 : 0x0000400000 (4,00Mb) UFS_LU1 : 0x0000400000 (4,00Mb) UFS_LU2 : 0x1DCB000000 (119,17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK [A] Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : M2103K19C Product Name : camellia Product Device : camellia Product Board : camellia Board Platform : connac1x Build ID : SP1A.210812.016 Build Date : Wed Dec 28 13:25:49 CST 2022 Display ID : AN3516-camellia-build-2022122813 Security Patch : 2022-12-01 Version SDK : 31 Version Release : 12 Version Codename : REL Firmware Version : V13.0.5.0.SKSMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... error Repairing IMEI... IMEI 1: 86xxxxxxxxxxxxxx IMEI 2: 86xxxxxxxxxxxxxx Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Now use "Patch Cert" option to comlete repair. |
03-14-2023, 12:03 | #5 (permalink) |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | Selected model: Xiaomi Redmi Note 10 5G (China) (Camellia) Operation: Patch CERT Software version: 4.7 Work ID: 934141 Connect phone in BROM Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM13 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 LibUSB installed Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM13 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 LibUSB installed Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xE096C619, 0x2F49A0E6, 0x8C7BC62F, 0xA05824C9 Get Chip ID... [MT6833] Get SOC ID... [C62A8106718CD7BECCBF7C1C7E6EC34D113390BD2E0954A779 B9037D90A51811] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [14] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): MT128GASAO4U21 (0605) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT128GASAO4U21 UFS_FWVER : 0605 BLOCK_SIZE: 0x0000001000 (4,00Kb) UFS_LU0 : 0x0000400000 (4,00Mb) UFS_LU1 : 0x0000400000 (4,00Mb) UFS_LU2 : 0x1DCB000000 (119,17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK [A] Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : M2103K19C Product Name : camellia Product Device : camellia Product Board : camellia Board Platform : connac1x Build ID : SP1A.210812.016 Build Date : Wed Dec 28 13:25:49 CST 2022 Display ID : AN3516-camellia-build-2022122813 Security Patch : 2022-12-01 Version SDK : 31 Version Release : 12 Version Codename : REL Firmware Version : V13.0.5.0.SKSMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Unknown Xiaomi model! |
