Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 04-30-2024, 12:14   #1 (permalink)
Member: 1215266
Thanks Meter: 129
reevl v5g
hi how to enter the code ????? t mobile
elected model: Mediatek Mediatek
Operation: Read Codes
Software version: 6.8
Connect Type-C to NONE... OK
Host Power Off... OK
Connect phone to [PC] in BROM Mode
Waiting for device... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1511.0]
You are using driver version 3.0.1511.0, we recommend using version 3.0.1504.0 for proper operation. You can install the correct driver from the program directory.
Device found at COM22 [BROM]
Open port... OK
Send start cmd... OK
Get HW code from device... 0989
Get sec config... OK [000000E7]
Active sec flags: [SBC SLA DAA]
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6833]
LibUSB installed
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Release testpoint, waiting 2 seconds
Advanced Bypass Security... OK
Open port... OK
Get sec config... OK [000000E0]
Active sec flags: []
Library Version [2]
Init BROM... OK
Force Charge... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0xD69B791C, 0xD683F9ED, 0xC7B5AE11, 0xD82470E5
Get Chip ID... [MT6833]
Get SOC ID... [290FB03D0328921492B933E0B61E6628F95943AE95101DC4E8 D1FBF166BACF74]
Load DownloadAgent... OK
Search DA... OK [14]
Send preloader... OK
Start preloader... OK
Checking preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x150100445036444142023300CE056849
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: DP6DAB
EMMC_ID : 0x150100445036444142023300CE056849
EMMC_BOOT1: 0x0000400000 (4.00Mb)
EMMC_BOOT2: 0x0000400000 (4.00Mb)
EMMC_RPMB : 0x0001000000 (16.00Mb)
EMMC_USER : 0x0E8F800000 (58.24Gb)
RAM INFO:
INT_SRAM: 0x0000070000 (448.00Kb)
EXT_RAM : 0x0100000000 (4.00Gb)
Checking USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Checking A/B state... OK [A]
Read product info... [EXT4] ... OK
Product Brand : T-Mobile
Product Manufacturer : Wingtech
Product Model : REVVL V+ 5G
Product Name : Sprout
Product Device : Sprout
Product Board : S98115AA1S
Board Platform : mt6833
Build ID : SP1A.210812.016
Build Date : Fri Dec 1 15:26:03 CST 2023
Display ID : WTRVL5G_0.24.58
Security Patch : 2023-11-05
Version SDK : 31
Version Release : 12
Version Codename : REL
Firmware Version : SW_S98115AA1_S_V118
Read security partition from phone... OK
Read security files... OK
Calculating... OK
Read lock info... OK
N Code : 12345678
NS Code : 56781234
SP Code : 11112222
C Code : 33334444
SIM Code : 55556666
NS_SP Code: 77778888
SIM_C Code: 99990000
Read Codes done!
Old 04-30-2024, 12:27   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,104
Hello. Try to direct unlock option.
The Following User Says Thank You to Z3X For This Useful Post:
Old 04-30-2024, 13:51   #3 (permalink)
Member: 1215266
Thanks Meter: 129
The direct unlock process goes successfully but the sim is still locked. I tried read codes it works just fine but it does not ask for any codes because the device is T-Mobile
Old 04-30-2024, 14:11   #4 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,104
Try to choose TMB REVVL V+ 5G and repeat direct unlock. Post result.
Old 04-30-2024, 14:24   #5 (permalink)
Member: 1215266
Thanks Meter: 129
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: DP6DAB
RAM INFO:
Version SDK : 31
Read NVDATA files... OK
Calculating... OK
Read partition "nvdata"... OK
Read partition "protect1"... OK
Read IMEI... OK
Unlock... OK [DF1, DF2, GB1, GB2]
Write lock info... OK
Write security partition to phone... OK
Network Unlock done!
Selected model: TMB WTRVL5G (TMB REVVL V+ 5G)
Operation: Unlock network
Old 04-30-2024, 14:52   #6 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,104
So? Result - working?
Page generated in 0.17856 seconds with 9 queries
