06-24-2022, 14:00 | #1 (permalink) |
Insane Poster Join Date: Mar 2019 Location: Pakistan
Member: 2902364 Status: Offline Sonork: HMGSM Thanks Meter: 4 | reno 3 pro cph 2034 flash error [Answered] Operation: Flash (Upgrade) Software version: 3.6 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [ZTE Corporation,wdm_usb2sersv3,USB Single Port,usb2sersv3.sys,3.0.1352.0] Device found at COM11 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [ZTE Corporation,wdm_usb2sersv3,USB Single Port,usb2sersv3.sys,3.0.1352.0] Device found at COM11 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xAE3CA48E, 0x38BDAB2F, 0xD610E880, 0xE7BBCAC6 Get Chip ID... [MT6779] Get SOC ID... [10353D8ECEF05ECFFC4E3A11E707CB9D52BFA5F8B560E763F8 7C8FEAA5EE6288] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM8V7001JM-B810 (1200) Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V7001JM-B810 UFS_FWVER : 1200 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... error(20) Prepare list for upgrade... OK Check upgrade list... OK Prepare format list... OK Prepare final partition list... OK Read partition "preloader"... OK Read partition "opporeserve1"... OK Read partition "opporeserve2"... OK Read partition "opporeserve3"... OK Read partition "oppo_custom"... OK Read partition "nvcfg"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "persist"... OK Read partition "proinfo"... OK Read partition "nvram"... OK Read partition "ocdt"... OK Read partition "main_cdt"... OK Verify checksum... OK Format UFS_LU2 partition( 0x00008000..0x04107FFF )... OK Format UFS_LU2 partition( 0x0CA08000..0x0DF07FFF )... OK Format UFS_LU2 partition( 0x10708000..0x16707FFF )... OK Format UFS_LU2 partition( 0x17800000..0x1787FFFF )... OK Format UFS_LU2 partition( 0x1B000000..0x1B1FFFFF )... OK Format UFS_LU2 partition( 0x20500000..0x768FFFFF )... OK Format UFS_LU2 partition( 0x78000000..0x3B924F7FFF )... error(STATUS_EXCEED_AVALIABLE_RANGE) |
03-07-2023, 21:22 | #3 (permalink) |
Junior Member Join Date: Mar 2022 Location: Mumbai India
Member: 3009597 Status: Offline Thanks Meter: 0 | oppo cph 2035 flash error Get scatter info... OK Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Sat Mar 5 00:23:03 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1646410489222 Partition "userdata" changed...skip Partition "otp" changed: addr<0x3B924F8000>-->addr<0x1DC74F8000>, len<0x2B00000>-->len<0x2B00000> Partition table changed! The firmware must be downloaded with "Upgrade" option Prepare list for upgrade... OK Checking upgrade list... OK Prepare format list... OK Prepare final partition list... OK Read partition "preloader"... OK Read partition "opporeserve1"... OK Read partition "opporeserve2"... OK Read partition "opporeserve3"... OK Read partition "oppo_custom"... OK Read partition "nvcfg"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "persist"... OK Read partition "proinfo"... OK Read partition "nvram"... OK Read partition "ocdt"... OK Read partition "main_cdt"... OK Verify checksum... OK Format "UFS_LU2" partition( 0x00008000..0x04107FFF )... OK Format "UFS_LU2" partition( 0x0CA08000..0x0E707FFF )... OK Format "UFS_LU2" partition( 0x10708000..0x16707FFF )... OK Format "UFS_LU2" partition( 0x17800000..0x1787FFFF )... OK Format "UFS_LU2" partition( 0x1B000000..0x1B1FFFFF )... OK Format "UFS_LU2" partition( 0x20500000..0x3B924F7FFF )... error(STATUS_EXCEED_AVALIABLE_RANGE) need help |
03-07-2023, 23:51 | #4 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,055 | Quote:
