05-16-2022, 10:30 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: ...::::GUJRAT::::...
Member: 781860 Status: Offline Thanks Meter: 203 | RMX3085 Realme 8 imei repair issue.... [Solved] Operation: Repair Software version: 3.4 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM33 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x28120304, 0x810EF223, 0xEB6DF006, 0xE1587A25 Get Chip ID... [MT6785] Get SOC ID... [851486D9F330AD818B10A630C780CD9333DFF8A1A15745EA64 C1C2A9999A147D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [12] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM8V9001JM-B813 (0600) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V9001JM-B813 UFS_FWVER : 0600 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6785 Board Platform : MT6785 Build ID : RP1A.200720.011 Build Date : Wed Aug 11 18:36:52 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-07-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1619430602288 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 3501361 IMEI 2: 350136 Write IMEI [NVDATA]... OK Load partiton for patching... OK Save patched partiton... OK Unlock bootloader... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Imei repair done but after it baseband unknown... |
05-16-2022, 22:23 | #3 (permalink) | |
Freak Poster Join Date: Dec 2014 Location: india
Member: 2310117 Status: Offline Thanks Meter: 43 | Quote:
