Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 09-22-2021, 02:26   #1 (permalink)
Member: 1070713
Thanks Meter: 14
Samsung A107m imei repaired but no service [Answered]
Hi, i have repaired imei Samsung A107m but still not service, i have flashed and repaired again, this phone came from another service with imxx modified, is there a procedure to complete the patching of certificate, imei is changed when i realize the process but no signal... thanks in advance for your support.
This is patching cert log:
Selected model: Samsung SM-A107M (Galaxy A10s)
Operation: Patch CERT
Software version: 2.5
Host Power Off... OK
Switch virtual port to NONE... OK
Connect Type-C to HUB... OK
Host Power On... OK
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0]
Device found at COM117 [PRELOADER]
Open port... OK
Send start cmd... OK
Get HW code from device... 0766
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6765]
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Force switch to BROM... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0]
Device found at COM116 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0xAC93BB1C, 0xA4A5A35E, 0x9EE3FDF5, 0x9D4FC20A
Get Chip ID... [MT6765]
Get SOC ID... [39777798FAC256527BFBD2011A18D8656534ABEC00DAC23F77 8C142F123CC133]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [23]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x150100514436334D42035387D24486AF
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x150100514436334D42035387D24486AF
EMMC_BOOT1: 0x0000400000 (4.00Mb)
EMMC_BOOT2: 0x0000400000 (4.00Mb)
EMMC_RPMB : 0x0001000000 (16.00Mb)
EMMC_USER : 0x0747C00000 (29.12Gb)
RAM INFO:
INT_SRAM: 0x000003A000 (232.00Kb)
EXT_RAM : 0x0080000000 (2.00Gb)
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Read partition "nvram"... OK
Read partition "nvdata"... OK
Read NVDATA files... OK
Read NVRAM files... OK
Patch CERT [NVDATA]... OK
Patch CERT [NVRAM]... OK
Write partition "nvdata"... OK
Write partition "nvram"... OK
Patch cert done!
Old 09-22-2021, 09:57   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,031
Hello. Tap *#0011# with sim and attach photo here.
Page generated in 0.15895 seconds with 8 queries
