Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 02-18-2022, 07:52   #1 (permalink)
Member: 839673
Sonork: pastorshaggy
Thanks Meter: 65
samsung A10s ime repair fail [Solved]
Selected model: Samsung SM-A107F (Galaxy A10s)
Operation: Repair
Software version: 2.11
Host Power Off... OK
Switch virtual port to NONE... OK
Connect Type-C to HUB... OK
Host Power On... OK
Connect phone to BOX in BROM/PRELOADER Mode
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0]
Device found at COM42 [PRELOADER]
Open port... OK
Send start cmd... OK
Get HW code from device... 0766
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6765]
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Force switch to BROM... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Driver: [Sony Mobile Communications,usbser,MTK USB Port,usbser.sys,10.0.19041.1202]
Device found at COM43 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0x5127DB81, 0xFA74E886, 0x9F60670A, 0x856D9FB7
Get Chip ID... [MT6765]
Get SOC ID... [559AB70E9960D649512968636D9BD36FD6B6011B787F0D23A1 B3A1C28774E6B9]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [23]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x150100515836334D420020E00635B76D
Load EMI from phone... Skip
Load EMI config from database [DB VER: 192 DB DATE: 01-21-2022] OK [1]
Trying EMI [9C47C7D7, C27E8331, CCFE52E9, 24F30B91, C26ECB0F, 3044B25D, D25991E9, 947DFBD0]
Init EXT RAM... error(2)
Old 02-18-2022, 08:51   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 3,246
Hello. Delete all mtk and preloader ports drivers and install correct driver from pandora box folder. Post result.
The Following User Says Thank You to Z3X For This Useful Post:
Old 02-18-2022, 10:59   #3 (permalink)
Member: 839673
Thanks Meter: 65
DRIVERS SEEMED TO BE PROBLEM ALL OK .....
Operation: Repair
Host Power On... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1633 (Android),usb2ser.sys,3.0.1504.0]
Device found at COM23 [PRELOADER]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0]
Device found at COM39 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_ID : 0x150100515836334D420020E00635B76D
EMMC_BOOT1: 0x0000400000 (4.00Mb)
EMMC_BOOT2: 0x0000400000 (4.00Mb)
EMMC_RPMB : 0x0001000000 (16.00Mb)
EMMC_USER : 0x0747C00000 (29.12Gb)
RAM INFO:
INT_SRAM: 0x000003A000 (232.00Kb)
EXT_RAM : 0x0080000000 (2.00Gb)
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Check A/B state... OK
Read product info... OK
Product Brand : samsung
Product Manufacturer : samsung
Product Model : SM-A107F
Product Name : a10sxx
Product Device : a10s
Product Board : S96116CA1
Board Platform : MT6765
Build ID : QP1A.190711.020
Build Date : Wed Dec 2 18:20:04 KST 2020
Display ID : QP1A.190711.020.A107FXXU7BTL1
Security Patch : 2020-12-01
Version SDK : 29
Version Release : 10
Version Codename : REL
Firmware Version : A107FXXU7BTL1
Read partition "nvram"... OK
Read partition "nvdata"... OK
Read NVDATA files... OK
Read NVRAM files... OK
Read IMEI... OK
IMEI 1: 3569***********
IMEI 2:
Repairing IMEI...
IMEI 1: 35423**********
IMEI 2: 354***********
Write IMEI [NVDATA]... OK
Write IMEI [NVRAM]... OK
Write partition "nvdata"... OK
Write partition "nvram"... OK
Repair Security done!
The Following 3 Users Say Thank You to coolwaindo For This Useful Post:
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.13164 seconds with 7 queries
