03-30-2023, 23:10 | #19 (permalink) |
No Life Poster Join Date: Dec 2004 Location: In Your Room Age: 47
Member: 97299 Status: Offline Thanks Meter: 43 | i have revived the phone with an partial backup "a not finished backup " i was lucky that this unfihished backup (EMMC_USER_00000000_E8F800000_(2023-3-30_16-54-50).bin) 3.21gb contains the needed data in order to revive the phone . now i have try to wipe partitions select just persist , format partitions done but frp still there . p.s. i have removed the frp with other tool here the log elected model: Samsung SM-A226B (Samsung Galaxy A22 5G) Operation: Wipe Partitions Software version: 4.9 Erasing of partitions can damage your device. Make sure that you have a backup created. Continue? YES Work ID: 1253530 Connect phone in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM24 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Read Efuse error Force switch to BROM... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Release testpoint, waiting 2 seconds Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] LibUSB installed Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xE08D6BBC, 0x7D37AA8C, 0x6C938B4E, 0xC7A49474 Get Chip ID... [MT6833] Get SOC ID... [64B18B20DB5644FED9625A832221247005BD8F4CB9C248C66D 405760EF45584F] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [14] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x1501004450364441420051219005C8F3 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_CNAME: DP6DAB EMMC_ID : 0x1501004450364441420051219005C8F3 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0E8F800000 (58,24Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK Read product info... [EXT4] ... OK Product Brand : samsung Product Manufacturer : samsung Product Model : SM-A226B Product Name : a22xnsxx Product Device : a22x Product Board : a22x Board Platform : connac1x Build ID : SP1A.210812.016 Build Date : Tue Aug 16 17:39:28 KST 2022 Display ID : SP1A.210812.016.A226BXXU5BVH2 Security Patch : 2022-07-01 Version SDK : 31 Version Release : 12 Version Codename : REL Firmware Version : A226BXXU5BVH2 Format "persist" partition... OK Format Partitions done! Selected model: Samsung SM-A226B (Samsung Galaxy A22 5G) Operation: Wipe Partitions Software version: 4.9 Work ID: 1253530 Thanks to all wich have try to help me out |
03-30-2023, 23:17 | #20 (permalink) | |
Member: 97299 Status: Offline Thanks Meter: 43 | Quote:
the phone start but no imei .... after write back nvdata back stuck again in download mode - see attachment . Thanks anyway for your help like i write in next post the phone is alive now | |
03-31-2023, 07:55 | #21 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,042 | Quote:
