Samsung A22 5G frp reset without test point [Done] Selected model: Samsung SM-A226B (Galaxy A22 5G) Operation: Erase FRP Software version: 2.6 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,usbser,MediaTek PreLoader USB VCOM (Android),usbser.sys,6.1.7601.22436] Device found at COM47 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0989 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,usbser,MediaTek USB Port,usbser.sys,6.1.7601.22436] Device found at COM48 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3DB2FED5, 0x546A2A95, 0xD098A163, 0x1DEAF3A7 Get Chip ID... [MT6833] Get SOC ID... [2A72274B5491E2DB30C868D84435FF5431F7760DF4DB08D361 B703C02A19BA4D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [32] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445036444142003BCE9098484D Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100445036444142003BCE9098484D EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "frp"... OK Read partition "persistent"... OK Backup saved to PND_LINK_0081 "file:///C:/Program%20Files/Z3X/Pandora/Backup/MTK/Samsung_SM-A226B%20(Galaxy%20A22%205G)/FRP_BACKUP_(2021-10-7_19-24-9)/"directory Format "frp" partition... OK Format "persistent" partition... OK Writting FRP data... OK Erase FRP done! |
