SAMSUNG A31 KG AND FRP LOCK REMOVED by Pandora's Box [Done] Selected model: Samsung SM-A315F (Galaxy A31) Operation: Remove KG Software version: 2.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM26 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x06812A7D, 0x2A6E5079, 0x8713AAE8, 0xBE298D1F Get Chip ID... [MT6768] Get SOC ID... [CB1165C6B17E774C7F3163111262B8CD4203BDAF10269BEE4F DEF45872665AA9] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445636444D4200C242D0C828DD Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100445636444D4200C242D0C828DD EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x1D1F000000 (116,48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Check USB status... USB_HIGH_SPEED Read Write Counter[WC][MAX=0xFFFFFFFF]... 15749 OK Backup RPMB... OK Searching RPMB key... found! [3] WC not incremented if data of page in rpmb same as in file Format RPMB 0x100 bytes (0x1 pages)... OK Format RPMB 0x100 bytes (0x1 pages)... OK Read Write Counter[WC][MAX=0xFFFFFFFF]... 15751 OK Reset (Samsung KG) RPMB done! |
No relock after connect to Wi-Fi network ? |
