Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 02-15-2025, 01:00   #1 (permalink)
Member: 1671798
Thanks Meter: 178
SM-A042M frp error
Selected model: Samsung SM-A042M (Samsung Galaxy A04e)
Operation: Erase FRP And Wipe
Software version: 7.14
Erasing of partitions can damage your device.
Make sure that you have a backup created. Continue? YES
Work ID: 61611247
Connect phone in BROM/PRELOADER Mode
Waiting for device... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1512.0]
You are using driver version 3.0.1512.0, we recommend using version 3.0.1504.0 for proper operation. You can install the correct driver from the program directory.
Device found at COM8 [PRELOADER]
Open port... OK
Send start cmd... OK
Get HW code from device... 0766
Get sec config... OK [00000005]
Active sec flags: [SBC DAA]
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6765]
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Force switch to BROM... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1512.0]
Device found at COM7 [BROM]
Open port... OK
Get sec config... OK [000000E5]
LibUSB installed
Library Version [2]
Init BROM... OK
Force Charge... OK
Release testpoint, waiting 2 seconds
Advanced Bypass Security... OK
Open port... OK
Get sec config... OK [000000E0]
Active sec flags: []
Library Version [2]
Init BROM... OK
Force Charge... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0xBD49B34A, 0x87DB39FA, 0x1B6C7C61, 0x7B301BB1
Get Chip ID... [MT6765]
Get SOC ID... [B8068201C1A0B0662FD471F516E0723DAF167D94166F22F7B6 9E4E3FC1D1F20D]
Load DownloadAgent... OK
Search DA... OK [7]
Send preloader... OK
Start preloader... OK
Checking preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0x150100445036384D4202CF2C6ACA69F5
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
EMMC INFO:
EMMC_CNAME: DP68MB
EMMC_ID : 0x150100445036384D4202CF2C6ACA69F5
EMMC_BOOT1: 0x0000400000 (4,00Mb)
EMMC_BOOT2: 0x0000400000 (4,00Mb)
EMMC_RPMB : 0x0001000000 (16,00Mb)
EMMC_USER : 0x0E8F800000 (58,24Gb)
RAM INFO:
INT_SRAM: 0x000003A000 (232,00Kb)
EXT_RAM : 0x00C0000000 (3,00Gb)
HEALTH:
Pre EOL Info: normal
DeviceLifeTimeEstA: 10% - 20% device life time used
DeviceLifeTimeEstB: 0% - 10% device life time used
Checking USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Checking A/B state... OK
Read product info... [F2FS] ...
Exception: Access violation at address 011A6A72 in module PandoraTool.exe (offset DA6A72). Read of address 0E7C6934
Old 02-15-2025, 09:40   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,765
Again this bug... Untick read info and manyally erase persistent, cache and userdata. What firmware in phone? If not hard - read and upload super partition.
Page generated in 0.11362 seconds with 9 queries
