09-11-2021, 08:58 | #1 (permalink) |
Freak Poster Join Date: Sep 2015 Age: 32
Member: 2460182 Status: Offline Thanks Meter: 7 | SM-A107F Force BROM how?(Update 2.5) [DONE] i tried using Force BROM and did not work for me is there method ? i have tried usb only (vol+) + (usb) (vol-) + (usb) (vol+) +(vol-) + (usb) none of them work and the result is phone showing charge icon after a few second here is the log Selected model: Samsung SM-A107F (Galaxy A10s) Operation: Read PTT Software version: 2.5 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM151 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... error Load DownloadAgent... OK BROM not connected! |
09-11-2021, 10:05 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
working 100 ok bro FALLOW THIS POST https://forum.gsmhosting.com/vbb/f11.../#post14451714 | |
09-14-2021, 21:16 | #3 (permalink) |
Freak Poster Join Date: Aug 2014 Location: south africa
Member: 2243017 Status: Offline Thanks Meter: 29 | hi team please tell us how to connect ,bcoz its not going to brom, by the way in pandora box no help menu,how to connect ,connect with usb or with box.please put instruction also.u launch new box with out any help makes no sense for user with out help Selected model: Samsung SM-A107F (Galaxy A10s) Operation: Repair Software version: 2.5 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM4 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... timeout Load DownloadAgent... OK BROM not connected! Last edited by haider420; 09-14-2021 at 21:23. |
09-14-2021, 21:17 | #4 (permalink) |
Member: 2243017 Status: Offline Thanks Meter: 29 | a107f imei repair fails hi team please tell us how to connect ,bcoz its going to brom Selected model: Samsung SM-A107F (Galaxy A10s) Operation: Repair Software version: 2.5 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM4 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... timeout Load DownloadAgent... OK BROM not connected! |
09-15-2021, 17:06 | #7 (permalink) | |
Freak Poster Join Date: Jun 2013 Location: mexico
Member: 1958094 Status: Offline Thanks Meter: 57 | Quote:
https://forum.gsmhosting.com/vbb/f11.../#post14453695 | |
09-15-2021, 19:18 | #8 (permalink) |
Member: 2243017 Status: Offline Thanks Meter: 29 | i installed drivers from pandora driver folder,but its still same.no change,i tryd 2 different computers with win 7 and win10 but no success,something is wrong with tool.phone disconnect when it try to to covert to brom and show charging |
09-15-2021, 20:04 | #9 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,037 | Quote:
Also you can try recommendations from this post: https://forum.gsmhosting.com/vbb/f11.../#post14453695 | |
09-15-2021, 20:40 | #10 (permalink) |
Member: 2243017 Status: Offline Thanks Meter: 29 | i just wanted to tel.i use direct usb cable to computer,if i uncheck ,use box auth, it force to brom see log Selected model: Samsung SM-A107F (Galaxy A10s) Operation: Repair Software version: 2.5 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM6 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM7 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3C71BC4E, 0x5D298940, 0x5EBAE287, 0x5FE08C64 Get Chip ID... [MT6765] Get SOC ID... [E9EC183C22C0F1464C9254CCA3DC01E1F570E7D324CEB64197 4777344EA665F1] Get sec config... OK [000000E5] AUTH file not found! .but if i check , use box auth,then it dont force to brom, Selected model: Samsung SM-A107F (Galaxy A10s) Operation: Repair Software version: 2.5 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM6 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... canceled Load DownloadAgent... OK BROM not connected! |
09-19-2021, 00:02 | #11 (permalink) | |
Freak Poster Join Date: Jul 2009 Location: México
Member: 1070713 Status: Offline Thanks Meter: 14 | Quote:
