12-01-2022, 12:38 | #1 (permalink) | ||
Freak Poster Join Date: Jul 2021 Location: World Age: 34
Member: 2992863 Status: Offline Sonork: http://wa.me/97470541113 Thanks Meter: 90 | oppo A16 flash error [Answered] Quote:
how to recover this , if cant flash | ||
12-01-2022, 14:13 | #2 (permalink) |
Member: 2992863 Status: Offline Sonork: http://wa.me/97470541113 Thanks Meter: 90 | Selected model: OPPO CPH2269 (Oppo A16) Operation: Write OFP Software version: 3.10 Extract scatter file... OK Read super info... OK Parse scatter file... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM16 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM16 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x6664D785, 0x71BCEC10, 0xD51A6401, 0xFF3CCA4B Get Chip ID... [MT6765] Get SOC ID... [5AFBCC15FF4B1687BBBA275CBA6CAB1B8EE0BD5C7D18D57FCC F5E32EE458EB7D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445036444242025C53CE37B8D1 Load EMI config from preloader... Skip(Preloader file not exist) Load EMI config from database [DB VER: 206 DB DATE: 05-25-2022] OK [1] Trying EMI [7805E65B, 4ECF8C5A, 667E0B28, F1ADA01B, 154C2947, A5FE5CDA, F7711DB6] Init EXT RAM... error(6) |
12-01-2022, 14:17 | #3 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,062 | Quote:
