12-15-2021, 11:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | SM-A326B [A326BXXU4AUJ6] Phone Lock Problem Already Erased User Data But Still Lock ? Operation: Wipe Partitions Software version: 2.8 Erasing of partitions can damage your device. Make sure that you have a backup created. Continue? YES Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM5 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB76252D4, 0x88CC9906, 0x2AA3FD10, 0x914AE740 Get Chip ID... [MT6853] Get SOC ID... [BE05C47839786EFA61222E82769871A7856545C185F4BD9DAE 79FE0BF813840E] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [30] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): MT128GASAO4U219K (0007) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT128GASAO4U219K UFS_FWVER : 0007 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : samsung Product Manufacturer : samsung Product Model : SM-A326B Product Name : a32xxx Product Device : a32x Product Board : k6853v1_64_titan Board Platform : MT6853 Build ID : RP1A.200720.012 Build Date : Wed Oct 20 11:08:42 KST 2021 Display ID : RP1A.200720.012.A326BXXU4AUJ6 Security Patch : 2021-11-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : A326BXXU4AUJ6 Format "userdata" partition... OK Format Partitions done! |
12-15-2021, 11:44 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | manual erase userdata and cache |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
12-15-2021, 12:16 | #3 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,056 | Quote:
The Following User Says Thank You to Z3X For This Useful Post: |
12-15-2021, 13:28 | #4 (permalink) | |
Member: 2825953 Status: Offline Thanks Meter: 246 | Quote:
this mean like S21+ lost mode how to remove by dump, this phone also need dump. image host sites | |
12-15-2021, 14:39 | #11 (permalink) | |
Selected model: Samsung SM-A326B (Galaxy A32 5G) Operation: Unlock bootloader Software version: 2.8 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM5 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0996 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6853] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xB76252D4, 0x88CC9906, 0x2AA3FD10, 0x914AE740 Get Chip ID... [MT6853] Get SOC ID... [BE05C47839786EFA61222E82769871A7856545C185F4BD9DAE 79FE0BF813840E] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [30] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): MT128GASAO4U219K (0007) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT128GASAO4U219K UFS_FWVER : 0007 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : samsung Product Manufacturer : samsung Product Model : SM-A326B Product Name : a32xxx Product Device : a32x Product Board : k6853v1_64_titan Board Platform : MT6853 Build ID : RP1A.200720.012 Build Date : Wed Oct 20 11:08:42 KST 2021 Display ID : RP1A.200720.012.A326BXXU4AUJ6 Security Patch : 2021-11-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : A326BXXU4AUJ6 Read security partition from phone... OK Decrypt security data... OK Encrypt security data... OK Write security partition to phone... error(1) | |
