05-10-2022, 09:10 | #1 (permalink) |
Insane Poster Join Date: Sep 2019 Location: pakistan
Member: 2927217 Status: Offline Thanks Meter: 13 | some bugs in 3.4 [Answered] Selected model: Vivo V2026 (Y12S) Operation: Erase FRP Software version: 3.4 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [Sony Mobile Communications,usbser,MTK USB Port,usbser.sys,10.0.19041.1202] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [Sony Mobile Communications,usbser,MTK USB Port,usbser.sys,10.0.19041.1202] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x4554CFF3, 0x8AB3B50F, 0x9F373530, 0x7CBCDD05 Get Chip ID... [MT6765] Get SOC ID... [6CF79B68D730626EFB3B94D30A2AFF0F67B27DDC3A040E1610 028973F4DCE00C] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445836384D420979EFF4899729 Load EMI from phone... Skip (read preloader error) Load EMI config from database [DB VER: 203 DB DATE: 02-22-2022] OK [1] Trying EMI [667E0B28, F1ADA01B, 703B5CDE, B772E8DA, 4C76F2A3, D8F5BD39, E73BB811] Init EXT RAM... error(2) mobile have just frp |
