Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #62 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2003 Location: Torun, Poland Age: 38
Member: 25996 Status: Offline Thanks Meter: 210 | Quote:
Since it's related with RPMB, can't it be done similar to KG Lock, by wiping, or changing a part of the data, like a serial number or whatever is being sent to Xiaomi servers to verify if lock is active? | |
![]() | #64 (permalink) |
Member: 25996 Status: Offline Thanks Meter: 210 | Are you sure? At some point, i was analyzing the behavior of Find My Phone app on Qualcomm Xiaomi devices, and noticed that they do read some stuff from RPMB, right before it disabled ADB and locked the phone. I assumed it was a serial number or something that is used to identify the phone on Xiaomi servers, then apply the lock if server says so. Blocking find my phone specific hosts prevented this from happening. It was possible to wipe the whole device, then restore if from firmware file, and it would still lock so the information required to identify the device has to be stored in some place that you can't access with EDL (for Qualcomm device) mode, and it has to be unique for each device. |
![]() | #65 (permalink) |
![]() | #66 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Feb 2008
Member: 706257 Status: Online Thanks Meter: 2,970 | Quote:
![]() | #69 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: Heart of Islam Age: 39
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,446 | Please add convert frimware opstions like opf etc to scator , also we face losts problem in meta mode no found mobile, please make a vedio or give me link how to conect samsung new mobiles in meta mode use download mode or volium keys or adb or test point and with drivers, new models imei also sported but not detect in meta mode , most peoples not know about this new type hardware box... |
![]() | #70 (permalink) | |
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,446 | Quote:
but unfounatly its have bugs when unlock with pandora box jazz digit show cracked error on display after 5 sec and restart plz fix the bugs i have a mobile in my hand.. | |
![]() | #71 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Oct 2016
Member: 2635591 Status: Offline Thanks Meter: 26 | Selected model: OPPO CPH2179 (Oppo A15s) Operation: Unlock network Software version: 2.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM102 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xDF358C1D, 0xB7E08185, 0x8F3BCA5F, 0xEECF18E9 Get Chip ID... [MT6765] Get SOC ID... [A2028995F9C133A02010C59CA7138B40ED7FB6B1A1C7A7B1E5 E08E5913E5A4FF] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E03103E0DB27875 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E03103E0DB27875 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Write lock info... OK Write security partition to phone... OK Network Unlock done! but hand set not unlock plz help me |
![]() | #75 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Oct 2017
Member: 2772838 Status: Offline Thanks Meter: 22 | Plz add Huawei ID remove for all Huawei and Honor (MediaTek) based phones. And make firmware download available via Pandora Box. |
The Following User Says Thank You to ayaz_far For This Useful Post: |
