04-29-2021, 15:41 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | Stylo blod plus get error Selected model: Mediatek Mediatek Operation: Read Flash Info Software version: 1.7 Code: Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... FULL Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 6580 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6580] Get sec config... OK [00000005] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM23 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 6580 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6580] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Load DownloadAgent... OK ME_ID = 0xBA79ABAF, 0x02D8248E, 0x7E58FF1D, 0x4F74AD1B Get sec config... OK [00000000] Get BROM version... OK Search DA... OK [12] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Check bootloader answer... OK Wait for answer from bootloader... OK Wait for hw detection... OK Wait DA version... v4.2 Send BROM version... OK Send storage config... OK SyncBmtInfoWithDA... OK Set params... OK Read flash info... OK EMMC_ID: 0x480301D638304442287B3947B1962665 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] error(3) |
04-29-2021, 17:10 | #2 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,554 | Hello, Please try last version of pandora software and post result. Many fixes there. If problem, post log, then we will look exactly to this problem. |
04-29-2021, 17:48 | #3 (permalink) |
Insane Poster Join Date: Oct 2010
Member: 1418749 Status: Offline Thanks Meter: 45 | download this firmware and load firmware then do read info what ever you want .. if work post feedback download firmware https://we.tl/t-RhlX7wLWYE |
04-30-2021, 06:55 | #5 (permalink) | |
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
thanxx ur firmware i hve long already this firmware still no luck Code: Selected model: Mediatek Mediatek Operation: Read Flash Info Software version: 1.7 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... FULL Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 6580 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6580] Get sec config... OK [00000005] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM23 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 6580 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6580] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Load DownloadAgent... OK ME_ID = 0xBA79ABAF, 0x02D8248E, 0x7E58FF1D, 0x4F74AD1B Get sec config... OK [00000000] Get BROM version... OK Search DA... OK [12] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Check bootloader answer... OK Wait for answer from bootloader... OK Wait for hw detection... OK StorageType matched! Wait DA version... v4.2 Send BROM version... OK Send storage config... OK SyncBmtInfoWithDA... OK Set params... OK Read flash info... OK EMMC_ID: 0x480301D638304442287B3947B1962665 Load EMI config from preloader... OK Init DRAM... OK Enable DRAM... error(15) | |
04-30-2021, 12:37 | #8 (permalink) |
Freak Poster Join Date: Nov 2019 Location: South Africa Age: 33
Member: 2934673 Status: Offline Sonork: Still Not Created Thanks Meter: 218 | Bhai need official preloader file read from other box will not working Hope Pandora’s will think make difference way |
The Following User Says Thank You to GSM.AFRICA For This Useful Post: |
05-01-2021, 10:00 | #10 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,554 | Hello. I have send this thread link to developers. They not understand what you need from them. So please explain with maximum details. Then they will answer. |
05-03-2021, 12:28 | #11 (permalink) | |
what they dont understand my Skype address on my profile he can add me we can do test simple tht i will provide him everything | |
05-06-2021, 07:26 | #12 (permalink) | |
i attach preloader and scatter file add this in ur data base | |
