09-06-2021, 17:29 | #1 (permalink) |
Freak Poster Join Date: Aug 2021 Location: Pakistan
Member: 2993836 Status: Offline Thanks Meter: 12 | there are some bugs when i oprate with infinix smart 5 MT6761 [Answered] Code: Selected model: Infinix X657C (Infinix Smart 5) Operation: Format Flash Software version: 2.4 This procedure will erase all flash and can damage your device. Make sure that you have a backup created. Continue? YES Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM10 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x23604AE0, 0x4347941B, 0xA3C028CB, 0x0DB2614E Get Chip ID... [MT6761] Get SOC ID... [CCECDD3A0C01F148CFC4EABC6F5CB750CA7D3AAE8C05122FC5966854026E6E4B] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0xD6010335384B3732316959043936A785 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0xD6010335384B3732316959043936A785 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0E67800000 (57.62Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read partition "preloader"... OK Read partition "pgpt"... OK Read partition "proinfo"... OK Read partition "nvcfg"... OK Read partition "nvdata"... OK Read partition "persist"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "nvram"... OK Read partition "otp"... OK Read partition "flashinfo"... OK Create autoformat settings... OK Format EMMC_BOOT_1 partition( 0x00000000..0x003FFFFF )... OK Format EMMC_BOOT_2 partition( 0x00000000..0x003FFFFF )... OK Format EMMC_USER partition( 0x00000000..0xE677FFFFF )... error(7) Code: Selected model: Infinix X657C (Infinix Smart 5) Operation: Flash (Upgrade) Software version: 2.4 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM10 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x23604AE0, 0x4347941B, 0xA3C028CB, 0x0DB2614E Get Chip ID... [MT6761] Get SOC ID... [CCECDD3A0C01F148CFC4EABC6F5CB750CA7D3AAE8C05122FC5966854026E6E4B] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0xD6010335384B3732316959043936A785 Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0xD6010335384B3732316959043936A785 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0E67800000 (57.62Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Prepare list for upgrade... OK Check upgrade list... OK Prepare format list... OK Prepare final partition list... OK Read partition "preloader"... OK Read partition "proinfo"... OK Read partition "nvcfg"... OK Read partition "persist"... OK Read partition "protect1"... OK Read partition "protect2"... OK Read partition "nvram"... OK Verify checksum... OK Format EMMC_USER partition( 0x00008000..0x00107FFF )... OK Format EMMC_USER partition( 0x00408000..0x05021FFF )... OK Format EMMC_USER partition( 0x07022000..0x0B7FFFFF )... OK Format EMMC_USER partition( 0x0F800000..0x1B2FFFFF )... OK Format EMMC_USER partition( 0x1F300000..0xE63CFBDFF )... error(7) |
09-06-2021, 18:02 | #3 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Online Thanks Meter: 4,986 | Hello. Please install mtk driver from pandora box folder and repeat operation. Post result. |
The Following User Says Thank You to Z3X For This Useful Post: |
09-06-2021, 20:08 | #4 (permalink) | |
Member: 2993836 Status: Offline Thanks Meter: 12 | Quote:
i think there is no isue with drivers, if you suggest must then i shall try pandora drivers. | |
